coalminer
- Mar 14, 2013
- North Georgia Mountains
I've got a small Volvo clock that I'm trying to repair to put into my 92 Model 240.
I'm going to replace the big, factory clock with a Tachometer out of a 85 Model 245, and install the small clock in the dash.
The problem...or rather the question is.......
How is the clock grounded?
If my suspicion is correct, there is supposed to be a small copper pin that travels through the back of the metal clock enclosure and grounds (by solder connection) the clock housing through a ground wire that is plugged onto the exterior of the housing.
My problem is that this pin has apparently broken off while still connected to the housing.
Where does this pin solder into the circuitry of the clock????
There is a place where there is a small projection of copper pin sticking out of the solder joint in the clock circuitry.
Is this the place??
It looks like it lines up, but I'm still not positive.
If this is not enough info., I will make a picture.
thanks
Is this the place??
thanks
