Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
The engine I'm working on has vvt pulleys on both cams and neither are spring loaded. I changed the seals and have it back together, I'm not sure its right. I have the cam locks on it and the crank at TDC. The belt is on with the slack on the tensioner side. All the timing marks line up.
I haven't done anything with the three bolts on the face of each pulley. They both look like they are close to maxed though.
For the pulleys, I figured out their range of motion and installed them in the center of it. One gear moves 3 teeth and the other one moves 2. I installed the first one with the timing mark set correctly and can turn it 1.5 teeth advanced or retarded. Same with the second one but its only one tooth each direction because it has less travel.
With the belt on and the cams unlocked, I can turn each cam the same distance, 1 or 1.5 teeth forward or back from the lock position without moving the timing marks or belt.
Is that right or are they supposed to be more in one direction?
I think I need to re do it and set them at their clockwise limits with their timing marks lined up, so that they can turn counter clockwise a little with the belt off.
I'm not sure about that, just that the correct way to set them up is how that video shows. Make sure the center bolt is tight or else the hub can free spin when you're finding the max position, loosen the bolt to adjust how much you think it needs to move then tighten again and rotate it. Might take a few tries to get it right.
I got it back together, but not water in it yet. I cranked it up and let it run for 20 seconds, let it cool down and did it again. No check engine light, am I in the clear?
How long does it take to detect a cam crank correlation problem?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
