Old 05-28-2008, 07:03 AM   #26
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Originally Posted by hokman View Post
Wow Mr. Borrie, you still have that old radio? May I have that please?
I love your wood trim, my '84 does not have them.
I sold the woodtrim a long time ago, the radio i still have, since its the original and most expensive one to get back in the days. Think i like to keep that radio around
Mr.Borrie is online now   Reply With Quote
Old 06-01-2008, 07:22 PM   #27
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
If you plan on cranking the boost and keeping that engine together, I suggest you get a wideband oxygen sensor on that thing. Ryan's car on chipped Motronic was running pretty lean at ~15psi, although ping wasn't audible. Good call on the intercooler - Motronic is very sensitive to input from the intake air temperature sensor when it comes to applying ignition advance, so lowering IAT will free up quite a bit of power.
It sure is pretty I think it needs lowering, too
cheers
James
'13 V70 D4
'89 740 Turbo Intercooler
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'70 164 - Under Restoration
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 06-01-2008, 07:37 PM   #28
Mr.Borrie
Mr.Borrie's Avatar
Thanks for the tip, i will consider getting the wideband when i get the engine rebuild, but what will i do about seeing that it runs lean? getting adjustible crankshaft?
Oh and about getting the car lowerd i was working on that
Old 06-01-2008, 07:49 PM   #29
foggyjames
foggyjames's Avatar
Cool
If you find that the engine is running lean (say leaner than 13:1 when on-boost), you may need to start experimenting with a rising rate fuel pressure regulator. The 'correct' solution is to get a better mapped chip (or something programmable like MS)...but that may not be possible. By increasing the fuel pressure, you can run the engine richer when it's on boost. Most good quality RRFPRs are adjustable, so you can 'tune' it to give you a nice solid 12:1 AFR when you're on-boost.
cheers
James
Old 06-11-2008, 05:54 AM   #30
Mr.Borrie
Mr.Borrie's Avatar
Car is up and running again, heres a pic of the car on the track of zandvoort
Old 06-27-2008, 12:46 PM   #31
Mr.Borrie
Mr.Borrie's Avatar
Yay i got my first speeding ticket for white-rice in the mail today.. along with something a bit more awesome:
Im hoping that a friend of mine will take along a calibrated boostgauge and a sender for the oiltemp with him from the US.. you guys get aswesome deals
Old 06-28-2008, 04:49 PM   #32
Mr.Borrie
Mr.Borrie's Avatar
okay so i made a list of stuff i need to do/fix, might as well put it up here:
Its fun you'll never get bored with a old car.. then again when i all do this it be much faster/cleaner looking then stock ever was
Rust(only plates no real damage done luckily:
-Behind the headlights
-Engine bay near the airco dryer
-Danger-to-the-manifold *In progress*
-Sunroof, the closing stays wet, so ill have to replace that too *Fixed*, just surface rust, sanded and coverd in white paint that eats the rust and turns it into lead"
-trunk, done but needs a few welds to cover up the holes that remained
-some small spots not yet rusted near the wheels
-Sidemarker driver side *done* just surface rust, needs new paint
Enginebay
-Install K&N Open Air Filter *fixed*
-Get and install E-fan.., the OEM one is broken and always on :S
-Install dumpvalve, its been lying here for too long already *done*
-Install the EBay inter cooler*done*
-Get a catch tank and install it
-A new Battery
-Install a wide band *In progress* JAW is partially soldered just need to get the wideband sender
-Install the chip/ get a new chip the one that was sold to me was useless apparently (they are made for each car on the dyno, getting one from another could work or blow ya engine to little pieces)
Interior
- Get a new dash or pain the old one (its cracked and some wood that did not came off nicly is still there, yugh)
- Glue the sealing, its still intact but saggy *In progress, new sealing is here but needs to be cleaned and installed*
- properly mount the steering wheel horn bit *fixed*
- install the Gaugepod with calibrated boost, oil pressure and temp gauge *In progress, waiting for the senders, wires and gauges are installed*
- fix the RPM meter
- Get the backlight of the gauges working again *fixed*
- Mount the fire extinguisher
Trunk:
-Secure the sub
-Secure the amp
-install the red neons in the amp
-fix that damn voice coming through the sub (its on momoblock and still the voices come through)
Under the car ect
-Fix leak in the exhaust / get a 3" one
-Foglights that will fit the SE kit *orederd, Or not...?*
-Install the Hausser Lowering springs
-RED Led undercar
-Repaint and attach the SE skirts
Old 08-18-2008, 10:24 AM   #33
Mr.Borrie
Mr.Borrie's Avatar
Back at the Euro meet we worked on White-Rice.. We started to clean up the "Danger to the manifold" rust spots installed the K&N filter and fixed the heater valve
Heater valve was broken and Non turbo version... nice
DANGER TO THE MANIFOLD!!!
Old 08-23-2008, 10:04 AM   #34
Mr.Borrie
Mr.Borrie's Avatar
Well last night i had my first hill race, went pretty good.. but on the way i lost boost, checking today learned me that the wategate came lose of the housing, also the turbo housing keep coming loose so i can move it up and down. Luckily this is not my DD so i can go back to working on the garage for now.. i forced the wategate back with some chopper wire but it still looses boost so it might me broking or its the housing coming loose again.. like always your feedback is always welcome!
Put back on with a bit of force
How its hanging loose
iWTF is this sensor?, first time i saw that: EDIT coolant drain /EDIT
Old 08-23-2008, 10:20 AM   #35
J2_
J2_'s Avatar
Thats no sensor, thats your coolant drain !
J2_ is online now   Reply With Quote
Old 08-23-2008, 10:20 AM   #36
volvo940tuner
volvo940tuner's Avatar
its the the coolant drain?
'93 944-SOLD
'91 745 TIC- PARTED OUT
'97 854 R- SOLD
'96 854T Platinum- SOLD
'98 S70 GLT- SOLD
'98 V70R-SOLD
'95 854 T5-R--teh yellow
'90 744 TIC SE
'96 854R-winter car
'88 BMW E30 325IS
volvo940tuner is offline   Reply With Quote
Old 08-23-2008, 10:33 AM   #37
Mr.Borrie
Mr.Borrie's Avatar
Aah thats what that is ... cool the more you learn
Old 08-23-2008, 10:35 AM   #38
volvo940tuner
for sure.
its a pretty neat coolant drain too, because you just loosen it up and you can hook up a small vacuum hose to it to have a nice and tidy removal of coolant into a bucket or something, instead of just having coolant spill all over your hands and all over everything
i thought it was funny that my 1990 volvo has this nice drain, whereas the new BMWs that i service daily @ work just have the standard drain plug, which causes me to get coolant all over me every time i do a coolant flush
Old 09-20-2008, 12:26 PM   #39
Mr.Borrie
Mr.Borrie's Avatar
So its time for a small update, i fixed a few issue's on the car like we started working on the rust and got some of it down, welding will still needed to be done but the surface rust is almost under control.
Also i good a new sealing for the car, its beige and dirty so need to clean that up first before installing it in the car.
Also some other small things have been done like installing the dumpvalve and wiring the gauges and installing the gaugepod. will add pics later on
Old 09-24-2008, 02:17 PM   #40
Mr.Borrie
Mr.Borrie's Avatar
Pic of the gaugepod installed. im not too happy with the way it "fits" so i think i wanna get a IPD one for a decent price when i find one ( 50 USD shipped like)
outside:
Some parts my dad bought me need some work as you can see but awesome non the less:
Old 09-24-2008, 02:57 PM   #41
Turbosteen
I was born at a young age
Turbosteen's Avatar
Nice!
I think it's such a cool car (all 760's are) with the carputer, gauges, etc.!!
Nürburgring.... here we come
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 09-24-2008, 04:29 PM   #42
frpe82
Guest
You have an obsession
Old 09-24-2008, 04:38 PM   #43
Mr.Borrie
Mr.Borrie's Avatar
Nice!
Thanks, and you bet I'll be there with White-Rice next meet. to bad she had a bad case of danger2the manifold back then.. driving the ring on your own i a totally different thing then riding shotgun trust me!
Its not his fault 760 just rock!
You'll be at the ring next year with the V90 right? ..I wonder how those ringbilder pics will look like ( 760's V90's 240's awesome!)
Old 09-24-2008, 04:46 PM   #44
Turbosteen
Turbosteen's Avatar
I wonder who will be the fastest down the straight
(Probably a porsche or something)
Old 09-24-2008, 05:52 PM   #45
JW240
All idiot, no savant
JW240's Avatar
240 ftw
looking good as always, nice that you took care of the sunroof!
Old 09-25-2008, 08:56 AM   #46
frpe82
Guest
Yes.
Old 09-25-2008, 02:36 PM   #47
Turbosteen
Turbosteen's Avatar
Next year:
2x 760 Turbo
1x V90 Turbo??
2x 940 Turbo
1x 240 Turbo?
1x 960 Turbo
At least
Old 09-25-2008, 02:43 PM   #48
JW240
JW240's Avatar
Next year:
2x 760 Turbo
1x V90 Turbo??
2x 940 Turbo
1x 240 Turbo?
1x 960 Turbo
At least
don't forget the Aachen crew.... they seemed to be interested!
/offtopic
Old 09-25-2008, 04:54 PM   #49
frpe82
Guest
1x V90 Turbo??
Probably.
If I don't pass the 300HP mark as NA.
Old 09-26-2008, 03:42 PM   #50
volvo78244
Ring apprentice
volvo78244's Avatar
1x 960 Turbo
I hope not! I want to take one on the trailer ...
2005 V70 - 2.4D
2003 S60R (sold)
1998 S70R (sold)
1993 960 B204FT
1992 740 B230FD
1990 960 B204FT
1987 340 B14E Variomatic (sold)
1982 242 B230FK
volvo78244 is offline   Reply With Quote
