Old 02-14-2009, 01:31 PM   #76
frpe82
Guest
Originally Posted by Mr.Borrie View Post
I dont know how the chipped settings are on the tuned Chips but from what i heared the motronic chips are only used for removing the boost limits of the motronic injection system.[/IMG]
It depends on who makes the chip of course...
Some manufacturers really cheat their way through it.
Old 02-15-2009, 01:23 PM   #77
JR-66
So finally i tested the second ECU i bought for my whole chipping bit. The ECU ran great on the car so i moved on with installing the chip in the ECU.
It was so much more easy then i though it would be, opened the box up flip the chip out put the new on in and back together it goes. no soldering at all!
A little less happy i was with the result though, now i must say that the car was a bit reving up and reving down in Idle (vaccum leak maybe?) but when i installed the chip it really came up.
the engine revved up and down like crazy almost dieing when idling down.. I dont know how the chipped settings are on the tuned Chips but from what i heared the motronic chips are only used for removing the boost limits of the motronic injection system.
here's a pic of the ECU in case you wanna see what that looks like:
Where did you get the chip from? What box number are you running? Is it B230 engine? Idle air valve is quite common fault in those engines, it just worns out and are usually really dirt and sticky inside. Clean it and the throttle body too. Leaky bypass is other common place to cause idle problems.
And yes, most so called chiptuners just mods airmass limiter map, even in LH chips... Motronic chip, when properly done, can give pretty nice gains in power, driveability and even mileage.
Turbopower
JR-66 is offline   Reply With Quote
Old 02-16-2009, 08:27 AM   #78
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Chips is from Rica, not a complete unknown tuner on volvo's but no fred chip quality i am sure
Chip is from rica, box nr is 0 261 200 022. Engine is the B230ET from 86.
Idle air valve had been cleaned and checked less then a year ago (by putting 12V on it and it made the CLICK noise) so could check all the air tubing again soon i suspect a leak before clogged up lines to be honest
Old 02-16-2009, 09:00 AM   #79
frpe82
Guest
Then it is probably done right.
Old 02-16-2009, 12:23 PM   #80
JR-66
Then it should be good, we have here problems with motronic chips, B200ET is not common in other countries and some tuners offers B230ET chips for those, it works but economy, well its not there anymore, and it fails on emission tests too.
Even if it clicks it still might not work properly, contacts worn eventually out, I have opened quite many of those. You should also check earth contacts near the motronic unit, CIS unit earths it self there.
Old 02-16-2009, 05:44 PM   #81
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
RICA are a (very) well established brand. The problem with them seems to be that their power claims for the FWD stuff are...basically...made up. Apart from that, they seem like a good product.
Unless you have the ability to re-map the Motronic ECU, I would ditch Motronic apart from on a standard car. Off the shelf chips for it appear to mean (as JR-66 says) poor economy, bad emissions...AND the thing still doesn't fuel correctly on-boost. It's (early) 80s technology. Throw it away
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 02-16-2009, 05:47 PM   #82
JW240
All idiot, no savant
JW240's Avatar
afaik Boris is swapping to LH 2.4 sometime this year with the M90 swap. I have a complete 940 turbo wiring loom here and some other bits and pieces waiting for him hehe.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 02-16-2009, 05:53 PM   #83
mattsvart
mattsvart's Avatar
Nice car! ;)
mattsvart is offline   Reply With Quote
Old 02-16-2009, 05:55 PM   #84
Mr.Borrie
Mr.Borrie's Avatar
Fingers crossed
I have not cleared the earths near the ECU unit, other earths on the car have been cleaned a while ago (had many issue's like light on, wiper goes on ect )
The cis unit earth i am not sure, is it located next to the battery like the wiper/lights too?
cheers
James
Yes i agree but i got motronic, a chip and need for boost NOW so yeah gonna work this out but i will go LH soon seems like parts are harder to get anyway for motronic
Yes sir, although a 240 loom should be nicer to work with from what i heard, but i am sure you wanna help me with the 940 loom right
Originally Posted by mattsvart View Post
Nice car! ;)
Thanks, i like your ride too.. even more that grill hehe but you knew that already
Old 02-16-2009, 05:58 PM   #85
JW240
JW240's Avatar
probably can get you a 240 loom too, would be easier yeah.
Old 02-16-2009, 06:10 PM   #86
Mr.Borrie
Mr.Borrie's Avatar
Good to hear, i like less work when possible, but about the M90 part. I am going to do the upgrade when i come back from the UK.
My clutch kit arrived there already so I'm taking it back and use the old flywheel, when doing the upgrade i guess I'll have to find a LH2.4 one.
I was driving/racing down the "highway" when my gearbox made another funny noise and i could not get it out of the second gear without using my both hands and really smashing it in the 4th gear.. now i usually don't mind smashing and pushing my way till i get there but with a gearbox that baby doest fly for me
Old 02-21-2009, 07:51 PM   #87
Mr.Borrie
Mr.Borrie's Avatar
The Sachs clutch kit i brought back from the UK:
Sachs kitnr:4000 874 001
Clutch: 186 246 8031
Pressure plate: 3082 204 033
Release bearing: 3151 189 031
(from what i get from the M90 topic is that only the pressure plate seems to be the correct one..)
And here's me in the london underground with the "new" spoiler. Who would have though that having a clutch kit in the luggage and a spoiler the size of a volvo would suck to transport
I wanna thanks some of the UK brickers helping me out with getting the parts to my hotel and drinking the night away till we get kicked out.. good times boys! dont mind hitting me up when in the Netherlands so i can at least return the favor and get some beers!
Old 02-22-2009, 04:09 PM   #88
Eyssej
TWO TIMES
Only if your bring a hearse for me :P
Eyssej is offline   Reply With Quote
Old 02-22-2009, 05:21 PM   #89
J2_
J2_'s Avatar
wat moet je met een lijkwagen ?
J2_ is offline   Reply With Quote
Old 02-22-2009, 05:53 PM   #90
Fivehundred
Fivehundred's Avatar
Don't you know anything about women? Obviously it's her dream car. She told me she thought Boris would look great in it dressed in his grim reaper outfit
Fivehundred is offline   Reply With Quote
Old 02-22-2009, 05:54 PM   #91
Mr.Borrie
Mr.Borrie's Avatar
There are some nice hearses for sale here, the 940 Turbo 2Km from my house doesn't look bad at all! too bad we don't have 4000 euro's
We'll for some odd reason she like hearses, at least volvo is cool enough to be build in many forms.. hehe i think it would be pretty funny to tune the **** out of something like that. And then race the ricers with that
Though i much rater get a stretched limo 700 series and put some carputers and big tft screens in it, and a bar, and a dancing pole and a pool ect
Old 02-22-2009, 05:55 PM   #92
Mr.Borrie
Mr.Borrie's Avatar
Orrly?!
Old 02-22-2009, 06:58 PM   #93
Cojones
Cojones's Avatar
What kind of spoiler did you took home?
Cojones is offline   Reply With Quote
Old 02-22-2009, 07:04 PM   #94
J2_
J2_'s Avatar
Boris, if you pick up the 960 doors, ask for the stretched 145 ... it's 30 cm longer then a normal one is. eyssej must like it :P
You just need tot tint the windows thats all, and you can have some sexy-time in it
Old 02-22-2009, 08:15 PM   #95
Mr.Borrie
Mr.Borrie's Avatar
940 Sedan spoiler OEM in white.. seems like it doesn't want to fit the 760 easy (too round and a bit short.. not sure what i am gonna do with it now)
oh i need to see that, no clue yet on the date for picking those up.. wonder if the lighted switches are still in that 960 though
Old 02-22-2009, 08:42 PM   #96
foggyjames
foggyjames's Avatar
The lighted switches are in almost everything from the late 90s...400s, 940s, 960s...even 850s (although those are soldered together...at least in the central panel). I 'upgraded' the 360 to those a number of years ago.
Edit: Assuming you're talking about electric window switches...
cheers
James
Old 02-23-2009, 06:25 AM   #97
Eyssej
TWO TIMES
That's my fetish!
Old 02-23-2009, 06:27 AM   #98
Eyssej
TWO TIMES
1. Hearses, are nice because you can "do" and "take" everything in that car.
2. Boris, NIET ME AUTO SLOPEN! ik ken je! don't touch my gearbox.
Old 02-23-2009, 12:33 PM   #99
Cojones
Cojones's Avatar
Hmmm... Maybe on the 960?
Old 02-23-2009, 12:50 PM   #100
Mr.Borrie
Mr.Borrie's Avatar
I could but its now in the white of the 760 seems like a waste to spray it 960 gray
