Old 11-01-2017, 04:33 PM   #3001
justjim
justjim's Avatar
So you need to start a "going for 8s" thread!
Past: 1995 855. 1989 780. B230ft with T3, Megasquirt (thanks Kenny)
Current 1998 S70 T5 MANUAL (with a busted manual)
1996 Ford Bronco 4x4. 35" tires, 5" lift, much badassness
justjim is offline   Reply With Quote
Old 11-03-2017, 10:43 AM   #3002
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
nah. block #1 is up on the bench. Will be filling-possibly today, but sometime this weekend. considerations: cooling system for head/top of block. will be worked out.
Also, re-use old pistons (that look more or less fine) or get a new set. options options.
Megasquirt Tuning!
Old 11-03-2017, 02:29 PM   #3003
BillyMaysHere
BillyMaysHere's Avatar
dammit, I cam here hoping there was no progress and to post another weldy pic. Can't argue with meeting the goals tho.
Old 11-05-2017, 09:54 AM   #3004
linuxman51
linuxman51's Avatar
It's sunday. work slippage yesterday (general malaise in the afternoon, family stuff in the morning). Today though. Today we start down the fill path in earnest.
Old 11-05-2017, 05:21 PM   #3005
Stiggy Pop
Stiggy Pop's Avatar
How far up ya gonna fill the block?
'79 242
943 pickup
Old 11-05-2017, 06:37 PM   #3006
haltechsupra
haltechsupra's Avatar
Lmao @ BillyMayshere. Good luck Kenny.
If you had the audacity , to doubt my veracity, and even to insinuate, that I scrupulously prevaricate ,such an insignificant question. Then you must hallucinate before you comprehend.
haltechsupra is offline   Reply With Quote
Old 11-05-2017, 10:38 PM   #3007
linuxman51
linuxman51's Avatar
1.25 to 1.5 inches from the deck. I'll know for sure when it's done setting up. The instructions say to give it 24 hours, I'll let it sit for a few days (What's a few days at this point anyway?). Need to order up the bmw squirters I reckon as well; and call weisco & see what kind of clearances I need for the pistons in a filled block.
Old 11-07-2017, 12:57 PM   #3008
linuxman51
linuxman51's Avatar
it's still drying/setting up (took the tape and plate off the lower wp hole to see what's up, it was still moist but hard), may have put a little too much in there vs what I intended, but it should still work out fine. some creative plumbing will no doubt ensue.
Old 11-08-2017, 02:56 PM   #3009
linuxman51
linuxman51's Avatar
probably pretty dry now. playing plotting scheming to commence regarding cooling. The fill was a little higher than I initially wanted it to be, however, a cursory test reveals that air (and by proxy, water) should flow around the tops just fine.
What I've seen/read about from the swedes is running the water lines from a "manifold" into the block beneath each cylinder. The return path to the top of the radiator (reckon now I can probably get one of those honda radiators now like all the cool guys) will require some consideration, and I'll have to plug off the return to the top of the pump, but that should be fairly easy. (thinking tap and pipe plug).
Old 11-09-2017, 12:27 PM   #3010
linuxman51
linuxman51's Avatar
mockup time to get a gauge for spacing out the coolant pipe/log/whatevs that I'll be using in conjunction with block-o fill-o. Will also be working an oil cooler into the setup, and that should keep things cool enough for what I do with the car (which is drag race it primarily with an occasional cruise). Lookin' at what the swedes do, it's apparently not as big of a deal as I've made it out to be in my mind.
anyway, PICS!
the spinning thing just because, need to know where things are.
space!
mallet for reference
Not sure yet what size fittings I need to drill/tap into the block, I think no more than 1/2in really since I'll have more control over the speed/volume of water going through the system (as well as pressure). fuuun times. Not sure what fittings I want to use yet, there is an appeal in having everything more or less easily serviceable, but a whole gang of AN **** would be spendy as well. Rubber use will be as minimal as possible though, just in case
Old 11-09-2017, 12:36 PM   #3011
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Have you looked at Technafit's catalog for fittings and adapters? They're a fraction of the cost of Earl's and are high quality. I use them for everything these days. Oil, clutch, brakes, power steering, whatever.
Fake Race Car
Old 11-09-2017, 02:06 PM   #3012
linuxman51
linuxman51's Avatar
never heard of em. that's a nifty site, thanks for the heads up!
Old 04-25-2018, 01:35 PM   #3013
linuxman51
linuxman51's Avatar
kicking rocks again.
did that a few weeks ago, but life has been... hectic (and customer work takes priority).
got a hit in to weisco to get the ptwc numbers for the filled block, then it can go to the machine shop and get punched and skimmed. Need to get started on the cylinder head next.
Old 04-25-2018, 02:13 PM   #3014
t8fanning
8v are still cool, right?
t8fanning's Avatar
Did you/are you going to drill the head for all the coolant passages in the gasket and block?
1982 242 Turbo.
Old 04-25-2018, 02:57 PM   #3015
linuxman51
linuxman51's Avatar
probably ought to given the change in direction of coolant flow.. Hadn't really gotten there yet.
Old 04-25-2018, 05:40 PM   #3016
haltechsupra
O hell yes! Your exhaust manifold looks awesome! Did you make that beautiful piece?
Old 04-25-2018, 08:27 PM   #3017
linuxman51
linuxman51's Avatar
I outsourced that to captain bondo (the other kenny), I can't weld that nicely lol
Old 05-14-2018, 04:01 PM   #3018
linuxman51
linuxman51's Avatar
finally got off my dead ass and got ahold of the folks at weisco (after sitting on hold for what seemed like an unusually long period of time), got the info I needed. not too bad, said for a filled block with those pistons, an extra thou to thou point five. so, the recommended clearance was 0035, so a bump to 0045 to 005.
bouta order new rangz and I reckon cart the block over to the machine shop with the new info.
hashtag progress hashtag maybe.
Old 05-14-2018, 08:07 PM   #3019
JohnLane
Four to five thou will be easily heard. Lol.
This will be amusing.
Old 05-15-2018, 09:37 AM   #3020
linuxman51
linuxman51's Avatar
probably not over the up pipe. I think it was 35 or 4 last time anyway haha.
rangz ordered. we finna do this thing (for about 10 minutes, and then it'll sit for a month haha)
Old 05-22-2018, 08:49 AM   #3021
linuxman51
linuxman51's Avatar
dem rangz shipped finally. need to figure out which machine shop around here I can take the block to for accurate borin' and honin'
Old 05-22-2018, 09:42 AM   #3022
doucheNozzle
doucheNozzle's Avatar
Gonna use a honing plate?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 05-25-2018, 02:51 AM   #3023
quillc
yv1a.com
quillc's Avatar
Here we go again.....
Chris
www.yv1a.com
Old 05-25-2018, 08:15 AM   #3024
doucheNozzle
What?
Old 05-25-2018, 09:25 AM   #3025
linuxman51
linuxman51's Avatar
I didn't last time, I dunno. I did get the other two sets of rings yesterday. Summit.. two boxes with two sets per, shipped from the same place a day apart.
