t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
I've looked at his kits. It seems that Southbend offer similarly rated kits at a lower price.
Southbend doesn't sell flywheels for redblocks.
I see a couple listed on RockAuto for a 95 9000. There are a couple of 9" clutches, and a couple that are shown as 9 7/16:
http://www.rockauto.com/en/catalog/...d,1266375,transmission-manual,clutch+kit,1993
Obv, you'd want the larger. Buying one of those kits gets you a pressure plate (I'm assuming) and a clutch disc that you can't use.
Well then another question is if there's a difference between the viggen and the aero or is it the same as the 850r is to the 850 T5 where it's basically the same thing.
I've been scavenging other articles and found that the 240mm came on the 94-98 9000 aeros, but if they're discontinued then that's an issue. I think pre 1994 they used the 228mm and switched up after that. I called up southbend and left a voicemail to hopefully hear back to see if they can supply the 240mm plate for the aero, hopefully so.
Unfortunately most of the posts about this are 5+ years old so most of the links are dead, so it's increasingly difficult to find solid answers.
