Old 11-12-2011, 09:37 PM   #1
forman621
forman621's Avatar
Default Bottom end? Can it hold?
So I have rebuilt the bottom end on my b21ft with just new bearings and rings and block cleaned and what not. so pretty much a good condition stock bottom end.
My top end is or will be and have parts for.
Volvo 531 penta head
porting
.005 shave on intake
.020 shave on exhaust
Heavy duty valve springs rated to around 7500rpm
New everything else
seal, retainers, guides
I am putting in SS valves
46mm Intake
38mm Exhaust
My question is
Should i have done more to the bottom end to run this head setup?
forman621 is offline   Reply With Quote
Old 11-12-2011, 09:43 PM   #2
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
nope!
boost it!!
But really a much lighter rotating assembly from respectable dealers on this board would be a good option, the b21ft rotating assembly is heaaaaaaaaaaaaaaavayyyyy.
they are bullet proof though.
Old 11-12-2011, 09:59 PM   #3
viking20
I dont think its ideal to have the 531 head on the smaller bore , and esp not the larger valves ?
viking20 is offline   Reply With Quote
Old 11-12-2011, 10:02 PM   #4
forman621
forman621's Avatar
I am thinking about those rsi H beam rods.
But i am not sure what pistons i should use.
And if i get lighter pistons and rods would the crank need balanced?
And i am going to be running an IPD turbo cam
Old 11-12-2011, 10:10 PM   #5
PRVersion
regretting name change
PRVersion's Avatar
i've done effectively the same thing with non-volvo engines, the only difference is that you lose a little low RPM potential. maybe.
Originally Posted by XxJenoxX View Post
PRVersion wins.
accelerate til the last possible moment, then accelerate more...
PRVersion is offline   Reply With Quote
Old 11-12-2011, 10:18 PM   #6
FlyingTog
B6304 douche
FlyingTog's Avatar
How psi a stock can support?
Originally Posted by Crazychopstick View Post
Just a 960 bumper returning to its original form.
97 965R M90 My car! It's Purple! 267K+! 15.66@89.14
83 Group A 242. 7k+ original miles. Long term project.
98 V90 Parts car. Olive Green. 197K+
98 V90 Parts car. Tropical Green. 177K+
59 Austin Healey Bugeye Sprite. Project car.
94 Miata. Weekend car with 66K+ original miles!
94 Miata. LeMons project.
960 build thread: http://forums.turbobricks.com/showthread.php?t=231763
FlyingTog is offline   Reply With Quote
Old 11-12-2011, 10:22 PM   #7
forman621
forman621's Avatar
I dont know what they should be able to hold. i have heard around 15 psi right?
Old 11-13-2011, 01:33 AM   #8
GT_Paul
Elephant in the room
GT_Paul's Avatar
I have has a 531 on a 21 and the gasket was very close to the chamber.
Have read here that they tend to blow under stress. mine didn't but maybe use a 2.3 gasket..
I run 25 psi, no problems....
79 242 GT+T
GT_Paul is offline   Reply With Quote
Old 11-13-2011, 02:51 AM   #9
fast242
I had a Jewish wedding
fast242's Avatar
B21FT head gasket, and go for 30 psi if the rest of your set up can handle it. B21FT's are friggen stout, but as Brett said, heavy internally. The smaller bore and low compression help immensely if you run high boost.
If Budget allows, try to lighten the internals and longer rods and better pistons, but keep the bore size the same and have fun. RSI would be the likely outlet for those goodies.
PJ
84 242Ti 16V build up
83 245Ti daily driver lots of common mods
1992 745Ti stock
16V Block mounted LH2.2 distributors for 16V conversions on 240's, now for sale, just click this link
Pics Of the 242 and other stuff
http://www.pbase.com/fast242
fast242 is offline   Reply With Quote
Old 11-13-2011, 03:31 AM   #10
forman621
forman621's Avatar
Stock rods are 145 mm and they reccomend the 154 with new pistons
Old 11-13-2011, 04:19 AM   #11
forman621
forman621's Avatar
So rsi has a set of pistons that use stock length rods at - 145mm
and they also offer piston set that uses - 156mm rods.
Piston spec is 92.5mm
I have C and D cylinders which range from C 92.6992 - 92.08008 and D 92.08008 - 92.09024
so it will have to be bored is what i am thinking.
I am using a cometic head gasket at 0.036" with a bore size of 94 mm. I bought this from Knox
what would be the difference between running stock length rods VS the slightly longer 156mm rods?
Old 11-13-2011, 04:52 AM   #12
RESURRECTED
back from the dead.
RESURRECTED's Avatar
running the longer rods will lighten the piston end of the rotating assembly (very good thing)
one of the biggest issues when taking a engine to higher RPMs and bringing those RPMs back down in a controlled manner is figuring what,where and how to lighten things up, so they rev faster, and remain intact.
if your going for RSI pistons and rods, go for long rods. though at that point I wouldn't want to run such low compression as factory... I prefer throttle response with my power, unless your takin it to the 1/4 mile.
my brick hauls ass on its jack stands
RESURRECTED is offline   Reply With Quote
Old 11-13-2011, 04:54 AM   #13
RESURRECTED
back from the dead.
really though, you should give RSI a phone call.
Old 11-13-2011, 12:00 PM   #14
forman621
forman621's Avatar
Yeah I probably will tomorrow. Thanks you guys for the advice.
I was hoping to bring the compression up a little. So it doesn't have to rely in boost all the time.
Old 11-13-2011, 01:47 PM   #15
olov
doing something stupid
olov's Avatar
ok, i've got a 130k b21ft with a ported 530 head w/upgraded springs. so i am in the same ballpark as you. the bottom end is fine, i just don't feel ok throwing those big heavy pistons around over 7500-8000. i wouldn't be surprised if some sweeds have done it, but really, i don't need to go that high most of the time. i just wanted the spring upgrade for peace of mind.
the head is basically the same as my 530, it works fine, just use a b21ft head gasket.
to upgrade the rods/pistons.......i wouldn't bother, use what you got and see how you like it. if i were gonna buy rods/pistons i'd build a b230 bottom end, much easier to find in good shape, have piston squirters, much more common parts - so easier to find stuff on the shelf/used, and there were people who found really bad casting flaws in the older blocks - so i'd have it sonic tested/etc
good luck, you'll be fine with what you got. and you can reuse the head later if you change to a b230. mine's easily got 300whp, i made 265whp straight off the wastegate at 20psi on a ebay t3/t4, with megasquirt
opinions are like ***holes, i have one, and they're censored on tb
olov is offline   Reply With Quote
Old 11-13-2011, 02:25 PM   #16
MrBill
fige=500Dollar Mistake
MrBill's Avatar
yeah where's my replacement WG actuator?
I don't wanna be a jerk or anything, but I'd rather a JY b230ft freshened up over a stock b21ft bottom end.
And if I were buying rods and pistons, I'd definitely use a b230 bottom end.
Originally Posted by grnmachine02 View Post
Someone say crazy rays?
93 245 - Kaplhenke Shortened coilovers with adjustable Koni Reds, adjustable rear spring perches with revalved bilstein S-10 shocks. Turbo 2.5 motor in the works.
10 v50 - Unobtainium T5 R-Design AWD M66
Old 11-13-2011, 05:45 PM   #17
forman621
forman621's Avatar
Ok that makes sence I can see how I like it with stock pistons and rods and maybe find b230 to build under it. So I put the stock pistons in and the ring gap I measured was .014" for both top ring and second ring which is the bottom of the range. Which is .014-.022" I think. Is this not a good idea or should I file the rings to get around .016-.018" just to be safe but I don't wasn't it to loose either. I bought the deves rings fron ipd.
Old 11-13-2011, 06:20 PM   #18
Texas240
Prius Owner
Texas240's Avatar
When you're at it bore up the pistons, thats what I did on my B230f project
93 245 LS Engine Swap Project
Old 11-13-2011, 06:31 PM   #19
2fast242gt
Do you have a cobalt?
Bore the pistons? Really?
1983 242dl
*6.0 lq4 swaped* Build thread
Old 11-13-2011, 06:41 PM   #20
Texas240
Prius Owner
Texas240's Avatar
If he wants beefy and stout bottom, might as well go bigger, bigger will achieve power easier with a little less strain on the internals but im sure you already knew that
Old 11-13-2011, 06:45 PM   #21
adrianpike
adrianpike's Avatar
I'm envisioning some sort of ghetto dremeled rollerwave-shaped piston tops
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 11-13-2011, 07:28 PM   #22
Texas240
Prius Owner
Texas240's Avatar
give me one second and i'll whittle you something with my dremel
Old 11-13-2011, 07:35 PM   #23
forman621
forman621's Avatar
I think my plan is to keep my bullet proof bottom end and not over due it on rpm. I got .036 hg so that brings up the cr. Block was shaved .005-.010" ish I think. Piston is out oo the top of Top bore. About .004"
