View Poll Results: Would you buy them?
Noisy 10 11.36%
Quiet 32 36.36%
Improved handling 67 76.14%
No difference in handling 3 3.41%
Worth the money 55 62.50%
Not worth the money 9 10.23%
Multiple Choice Poll. Voters: 88. You may not vote on this poll
Old 02-01-2010, 08:41 PM   #1
gsellstr
gsellstr's Avatar
Default Poly Bushing Feedback
Mod's - please move if you see fit.
Okay, so there seems to be a lot of yay or nay on poly bushings. A lot have run them with good luck, yet some have had bad luck as well. So....let's see who has had what.
Please use the following format so we can keep this simple and easy for people to read.
Vehicle Model (i.e. 240, 740, etc)
Bushing location (i.e. full rear, front, torque rods only, etc.)
Pros (handling, etc.)
Cons (noises, vibrations, articulation, etc)
Vehicle usage (autox, DD, track, etc.)
Side notes
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-01-2010, 08:46 PM   #2
smokeyfan1000
Guest
Will be a bit before I can get mine in.. Will vote when I do though.
Old 02-01-2010, 08:49 PM   #3
gsellstr
gsellstr's Avatar
Guess I should start this out as well...
1974 144E
Full poly front and rear
Pros: Improved handling, less slop between accel and decel, ride is more stable compared to new OEM rubber.
Cons: Very minute difference in ride harshness, not nearly as severe as springs and shocks made.
Vehicle useage: play toy.
1990 745T
Pros: Improved handling, less slop between accel and decel, ride is more stable compared to new OEM rubber, shifts feel much crisper due to improved design of torque rod bushings.
Cons: 1 squeak from a previously installed poly bushing that hasn't been greased.
Vehicle useage: DD, play toy, 1/4-mile, load hauling.
Old 02-01-2010, 08:50 PM   #4
andysbeta
thrsh
andysbeta's Avatar
Location: Mancos, CO (no longer the Central Valley Smog Bank)
Did rear trailing arms (both front and rear) torque rods, panhard rod. Notice signifigant improvement in handling. Best way to describe it - no delay in handling response, car tracks alot better too. 245 BTW. Noise? A little bit more but nothing bad at all. Note no squeaking bushing noises either.. But I did grease them up good before installation.
Costs, yes that's the only factor here for the gains.. For best $$ to ratio fresh rubber bushings go a long way say 80% of what the poly do. I don't regret going to poly though, it should be the last set of bushings my 245 will ever need..
andysbeta is offline   Reply With Quote
Old 02-01-2010, 08:51 PM   #5
745 TurboGreasel
745 TurboGreasel's Avatar
cone bushings
huge improvement over the worn out slop they replaced
I did not notice any change in noise whatsoever, but braking shudder was eliminated.
Feedback
Old 02-01-2010, 09:08 PM   #6
GabAlmighty
GabAlmighty's Avatar
motor, and full front and full rear i believe
didn't get a before and after of the car but I had no complaints with it in at all
not that I know of, heard some people crack their motor mount polies though..
DD
'12 Raptor
GabAlmighty is offline   Reply With Quote
Old 02-01-2010, 10:21 PM   #7
towerymt
the real Towery
towerymt's Avatar
Almost mandatory for the rear bushing on the front control arm, and the rear torque rods. Those two bushings take the most abuse. Front control arm SuperPro have lasted 7+yr. and 100k miles Unknown brand red poly torque rod bushings lasted 4-5yr before two split. The other two are still in use with over 100k miles.
Pros: precision, stability under braking, improved traction from the rear tires on a launch, requires no maintenance, heavy duty long lasting solution.
Cons: initial cost. Never noticed a change in ride quality or noise with the other mods I already had (tires, springs, shocks, bars, etc all contributing to a change in ride from stock).
Street, autoX, track, drag, drift, snow, and once or twice on dirt.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 02-01-2010, 10:35 PM   #8
sdturbo
sdturbo's Avatar
Poly all around.
Pros: better handling, more solid ride quality, and they hold up a lot better than the replacement rubber bushings
Cons: Cost and labor intensive install.
I went with new rubber bushings in my beater 242 and that was a false economy. The handling has never been as good as my 245 and the rubber bushings are already showing signs of death.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 02-02-2010, 12:50 AM   #9
carnut1100
carnut1100's Avatar
Poly bushes in late type torque rods
Stock suspension apart from torque rods and -30mm King Springs
Definite improvement in rear end stability, no increased noise.
Worth the money? HELL YEAH!
Had poly engine mounts but they died. OEM rubber ones are quiet and durable so far, but motor moves around a lot more.
1973 164E 1978 244DL 1973 142DL
1979 242 GT 1977 245L van
carnut1100 is offline   Reply With Quote
Old 02-02-2010, 08:40 AM   #10
blu92in99
I hate you all, equally
blu92in99's Avatar
Vehicle Model - '83 242Ti
Bushing location - full poly front & rear, plus engine, trans & accessory mounts
Pros - handling, ride quality, durability of the bushing itself
Cons - occasional squeak
Vehicle usage - street, drag, spirited mountain driving. play toy.
Vehicle Model - '71 142E
Bushing location - front LCA and steering intermediate shaft currently, soon to be full poly front & rear
Cons - none yet
Vehicle usage - street. DD.
-Justin
blu92in99 is offline   Reply With Quote
Old 02-02-2010, 04:19 PM   #11
deetmar
deetmar's Avatar
Vehicle Model - 91 745
Bushing location - all front poly except inner control arm (the expensive one)
Cons - cost
i plan on replacing all of the rubber suspension bushings at some point. i think it's worth the extra $$$ for the poly upgrade.
deetmar is offline   Reply With Quote
Old 02-02-2010, 09:07 PM   #12
stylngle2003
stylngle2003's Avatar
85 744GLE/93 945T (both cars, same set of bushings)
All front poly (not endlink mount eye bushings, though).
Pros - they're made for a 7/9 series volvo...good enough reason to put them in. More durable/better performing than stock ****e. Allows me to get a much more consistent alignment. Durability is better than stock.
Cons - Hard to get the front bushing to conform to "Castermod" geometry. nature of the beast...poly resists flex more than rubber. Moderately expensive, but I have more than 50K miles on my set. Very happy with durability.
Trackdays, Autox, Rough road daily-D use.
Have Bne torque rods and subframe, so won't exactly need them for my rear torque rod bushings. But again, they're being made for us, so support the people that make them!
-Billy
1990 Mazda Miata (track toy)
Old 02-03-2010, 03:35 AM   #13
JERIC
full poly front suspension
steering shaft bushings
DD ,auto x, soon hillclimb car as soon as rollbar is done.
all my bushings were wasted when replaced with poly so no comparasion to stock, but no noise and the steering shaft bushings were 1/3 the price of the parts from volvo to fix. cant wait to up date the rear suspension to full poly and will be buying from gstellar again
JERIC is offline   Reply With Quote
Old 02-03-2010, 07:57 AM   #14
icebrick
one lesson after another
icebrick's Avatar
'91 240
full poly rear
OEM bushings on control arms
poly stabillizer links
Ipd 25/22 mm sways
This is my summer DD. I live in a city plagued with rough, seasonally potholed streets. I installed Bilstein HD's and lowering springs on both ends at the same time as I did the bushings, so I can't blame the stiff ride all on the poly. I love the way the car handles when pushed, .....but we don't drive Grandma around in this car anymore.
Originally posted by Barefoot
A low-mile Volvo is really only a psychological benefit.
kind of cool, but still grandpas' car
icebrick is offline   Reply With Quote
Old 03-06-2010, 07:36 PM   #15
Jeh
Wants a V12
Jeh's Avatar
240 DD and autox and track use.
I have a full poly setup and have been happy with it. The sway bars are noisy in the cold but otherwise its all quiet.
The question of how it compares to rubber is almost impossible to answer as even though I have driven a 240 with only 50k on it the rubber is still old.
Are the ploys 3-4x times better ie like the cost and-or will they hold up longer to the abuse?
I would have to think they would be firmer and last longer under most situations and therefore be worth the cost IF you are going to the track but it you are just a hard street driver better springs/struts would be better bang for the buck.
That's why I love this place.
Truly an information warehouse.
Originally Posted by kyle242gt View Post
I post not for information, but for ignorant entertainment.
1994 Jaguar XJ6
Jeh is offline   Reply With Quote
Old 03-07-2010, 03:54 PM   #16
villageidiot8709
i have a 91 240 with full poly. not too harsh and i drive some really horrible roads everyday
villageidiot8709 is offline   Reply With Quote
Old 03-07-2010, 04:21 PM   #17
Forg
Forg's Avatar
I have an '80 GT with full poly.
I don't find it too noisy in terms of rumble or general road-noise; I'm probably running smaller tyres than a lot of people with modded 240's are (ie. 40-series 215mm-section on 17's). However, everything binds up & it does go 'clunk' a lot more than it should.
This car has so many long-term repairs & fiddles needed, but ditching half the rear poly & replacing it with rubber is on my list (not all of it ... just some).
It does feel good on the road in terms of general cruising, but it's never been finished enough for me to punt it through any twisties so I've got no notion of handling in it.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 03-07-2010, 05:00 PM   #18
volvogeek
'86 245 with JUST poly on the panhard rod. I didn't grease the body to bushing areas, and it squeaks like a mother going over speedbumps. It was fine for a little while but kept getting louder and louder day by day.
volvogeek is offline   Reply With Quote
Old 03-07-2010, 05:36 PM   #19
villageidiot8709
grease is your friend
Old 03-07-2010, 05:55 PM   #20
stylngle2003
get waterproof synthetic marine grease. we like to use green grease brand. works great and sticks around for a long time. the poly gets attacked by petroleum-based greases.
Old 03-07-2010, 06:16 PM   #21
TIPSP
Got Boost?
TIPSP's Avatar
Vehicle Model: 1982 244T
Bushing location: Poly in Front control arms (F+R), Rear trailing arms (F+R). Everything else is a solid mount.
Pros: Performance and Endurance.
Cons: not a solid mount.
Vehicle usage: Hardcore DD, Track use will vary depending on funds.
UPDATED
Finally, got the 240 finished. Install of the poly went very smooth. Everything fit great. I modified the bushings and arms for zerk fittings so I can gease them when they need it.
THe only annoying parts to mention:
1- have to burn out the old rubber on the front a arm cups, and also the rear axle bushings.
2- grind off the little metal stops in the rear trailing arm to body tabs to allow the poly to work with out interference.
3- Superpro screwed up in packaging the rear trailing arms axle bushings, and they gave me 3 road side bushings and 1 inside bushing. that was and easy fix, but time was wasted.
Everything else is perfect.
Car feels great on the road. the ride is not harsh, even with the other solid mounts. Handling is nice and controlled. I haven't noticed any problem with axle movemnet with the poly in the trailings yet, but then again, I haven't pushed the car to the limits yet.
Recommended for sure!
Old 04-30-2010, 01:42 PM   #22
buzz
To inspamity, and beyond!
buzz's Avatar
'95 944T
Driven hard daily driver over anything from new roads to patched pothole rural roads and gravel logging roads.
Car had poly in the front for a couple years and I wanted poly in the rear also. Car has HD's and springs so the ride didn't noticeably change. What did change very noticeably is the now lack of the front tires constantly 'hunting' over every little bump. The bushings in the rear were on the way out and the poly bushings are holding the rear in place so the 'hunting' has stopped.
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 05-02-2010, 03:56 PM   #23
SteveMD
Membro
SteveMD's Avatar
Speaking of which, who here sells Super-pro poly these days?
Old 05-02-2010, 03:58 PM   #24
smokeyfan1000
Guest
There is a TBer selling them, but do not remember who. IPD also sells them. Where I got mine.
Old 05-02-2010, 04:17 PM   #25
SteveMD
Membro
SteveMD's Avatar
Thanks. Just found out FCP groton does, too. Will wait to find out who TB'er is. Buy local and all that jazz....
