Old 10-16-2020, 06:01 PM   #151
wtarkington
Originally Posted by matt b View Post
Low compression wouldn't cause a high idle, but as others have said: an air leak definitely will. Is the linkage returning fully, right away or is it a little sluggish ?
The linkage pulls back immediately as it should. Got new bushings on it, too.
wtarkington is offline   Reply With Quote
Old 10-16-2020, 06:05 PM   #152
wtarkington
Originally Posted by c1800 View Post
Do you have a timing light? Check the timing is set to 17-19 deg @1500 rpm?
I redid the timing and it’s perfectly set to 17 at 1500 rpm.
Old 10-20-2020, 02:42 PM   #153
cwdodson88
Originally Posted by wtarkington View Post
Glad to hear from you Dodson. My manifold is the one where the intake and exhaust are all connected. No extra flaps etc. I actually just changed the gasket recently and installed all new studs. The surface looked good to me.
Surfaces and finish generally arenít the problem. Sometimes you canít see it, but after machining, if someone dented the side it will raise a spot on the mating surface. Running an oil stone over it and youíll feel the hang up and rub it a bit more and it will polish the raised up bit.
All the things youíve looked at point me to an air leak. Do your throttle butterflyís have the poppet valves? Or are they a solid disc?
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-20-2020, 08:55 PM   #154
wtarkington
Theyíre a solid disc. No TOV valve or anything like that.
I did a compression check today just for giggles, and at first got almost exactly 125psi across al cylinders. Redid the valves and psi rose a bit on all, between 135-145.
I noticed the last cylinder spark plug was clean as a whistle. No burn, no black, just silver. All other spark plugs were a normal brownish.
Old 10-22-2020, 01:19 PM   #155
cwdodson88
That seems low
Old 10-22-2020, 01:28 PM   #156
wtarkington
That seems low
Thatís what I was thinking. Itís supposed to be at least 175-180, correct? I know burnt valves can cause you to lose up to 25% compression. 25% of 180 is 45. 180 - 45 = 135, just about where the compression of my cylinders are. I know thatís probably a far reach, but itís an idea. Could I have some valve issues?
Old 10-22-2020, 02:00 PM   #157
wtarkington
Speaking of which....I just did the ďdollar billĒ test, where you hold a piece of paper at the exhaust. It would occasionally get sucked back into the exhaust really quickly. More indication of valve issues?
Old 10-23-2020, 10:34 AM   #158
cwdodson88
One other thing would be a wet vs dry compression test, or a good leak down test.
Old 10-23-2020, 11:34 AM   #159
wtarkington
Yea thatís not a bad idea. Iíll look into that.
Old 11-27-2020, 02:27 AM   #160
wtarkington
Two bent valves!
I ended up just pulling the head and brought it over to the guy that rebuilt it the engine for me, at Engine Components & Machine (ECM) in Santa Ana. He knows these engines and did a good job with the rebuild. He took the head apart and told me I had one bent intake valve and one bent exhaust valve. Should be finished with it any day now.
I was so relieved when I heard this. Finally found something real, that can be fixed. No running around in circles trying to find something to fix or hunches.
I plan on completely cleaning the engine bay while the head is off. I’ll report back once the head is back on and everything is buttoned up and I run it.
The pistons looked good and move good in the block. I understand bent valves can be the result of them hitting the piston. Could this have happened due to maladjusted timing?
Old 11-27-2020, 03:15 AM   #161
wtarkington
FB0-CE210-8-ACA-4497-A0-CE-B83-E2-EBFD619
Waiting at the body shop
30015-AC7-E381-4-D30-ADF6-554657-CE61-B3
A0-EC7104-4234-4-DEE-A13-B-AE380-BF66-E70
Old 11-27-2020, 03:25 AM   #162
wtarkington
I donít remember how to post pics on this forum anymore lol
Old 11-28-2020, 06:26 PM   #163
wtarkington
Came out good!
DAADAC2-E-37-AA-4177-9-CA5-F8-CE585-AAEA4
Old 11-28-2020, 06:31 PM   #164
wtarkington
The kids car fits inside my car. Been enjoying this car all summer, all while not realizing I had valve damage.
63-E7-F240-9-FD6-49-F6-9285-F4-B8-B7-FF5-D1-B
9-D2-A6-E69-0935-4-AE1-982-A-A2386907-D5-C6
544-B61-B5-93-B1-4-F36-A9-A6-A014-FA2-EF4-D4
Old 11-28-2020, 06:46 PM   #165
wtarkington
Sorry for the large pics. Still figuring this out.
1227-DF24-C0-A4-4-EE0-A7-E1-C9458-C8-D24-FA
My copilot
943483-BF-0-F21-4522-9196-286-EC5392-F41
Steering coupler old vs new
C77-BC3-AB-75-ED-4-CBC-B38-C-D4-AA1-E632-CE6
Her first show
D850-D612-823-B-4-B10-B01-B-DC1-D7-BFE8827
75058-A1-E-5-D10-4-FDF-829-A-10730-E47051-A
F11-D9641-D633-4-FD2-8-F7-D-3-D398563-D9-E6
Old 11-28-2020, 06:59 PM   #166
wtarkington
I’m a tattoo artist by day, so every once in awhile I have time to screw around and draw some stuff. I decided to see what an Amazon might look like with big 50’s style fins
087-FFABD-98-B1-4-A55-BADF-11-FFA9-C15700
Another sketch from a few years back
957-ACC38-2701-4-D48-AA74-D59705-A5414-C
Finished this one at a tattoo convention a few years back
F84-E7-DFB-850-F-4-B2-B-B9-C1-AE6781-FA53-B0
