chrisc734
- Jan 24, 2017
- North Carolina, Outer banks
1989 Volvo 245 N/A LH2.4 Pink label Fuel and ezk computers with M47 Trans.
I have no injector pulse to my main injectors but i do have a pulse through my cold start.
The voltage when cranking with the positive multimeter test probe on a constant positive and a negative test probe on fuel ecu pin 18 (Green and white) is 0.90 volts constant and tested the signal at the injector with also 0.90 volts. When i ground out ecu pin 18 injectors do tick when car is in on position but not running. I do have spark at all 4 cylinders, compression is around 120psi at all 4 cylinders. The car with no timing advanced was reading 75 psi at all 4, so we advanced the by one or two teeth to bring the up the compression. The car also acted like it had no power at all two days prior and had stalled and wouldnt start but after letting it sit about 3 hours it started still had no power. I drove the car about 30 mins stopped to fill up gas and went to pull out and it stalled on me and hasnt started since. i have changed power stages, Crank position sensors, swapped a turbo ecu in to check that since i have no spare N/A computer. I have also pulled the maf plug for ****s and giggles and still nothing. I also dont have an o2 sensor hooked up because im running just a glasspacked side exit exhaust. Ill get a stumble out of the motor once in a blue moon. Car ran great until it started losing all its power two days ago.
Any help is appreciated because im still a newb to volvos.
Thanks in advanced
Thanks in advanced
