Old 10-06-2020, 03:32 PM   #1
jstblz
jstblz's Avatar
Default 242 2.3L Ecoboost 6spd Swap **Picture Heavy**
I think my IAC valve failed so I did what anyone would do... Swap in a 33 yr newer drivetrain without having a walk-through or template. I have the kinda of friends that won't talk you down from a silly idea so here we are.
The donor: 2017 Mustang 2.3L Ecoboost/MT-82 6Spd with 13k miles on the vehicle. Purchased for $2500 from Copart.com
The destination: 1984 Volvo 242 TIC
A lot more pictures to come!
84 242 TIC
jstblz is offline   Reply With Quote
Old 10-06-2020, 03:43 PM   #2
megulon-7
Culbero put one of those motors in a Merkur xr4ti, it was beastly!
megulon-7 is online now   Reply With Quote
Old 10-06-2020, 03:44 PM   #3
Neat! That seems like a good price on the donor-stang. How messed up was it?
Old 10-06-2020, 03:47 PM   #4
jstblz
jstblz's Avatar
Every panel was mangled because it rolled. Rear windshield was about the only good exterior piece. I saved 3 good wheels, taillights, the HID projectors out of the headlights, fog lights, a bunch of modules, PCM, motor, trans, 1 perfect seat, 1 ok seat, and a few interior pieces.
Old 10-06-2020, 03:49 PM   #5
I guess a side impact bag went off on one of the seats.
Yeah, I didn't look closely enough at those pics, I thought it was pretty straight other than a mashed front end.
Old 10-06-2020, 04:13 PM   #6
Chuck W
Chuck W's Avatar
$2,500 for the donor! That's a sweet deal!
This is going to be a fun build!
'78 264GLE
'97 854 T5 (Manual swap/COP/16T/P2R brakes)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
My feedback thread
Old 10-06-2020, 04:38 PM   #7
jstblz
jstblz's Avatar
2.5 days of work and we get the motor, trans, and any potentially needed or sellable parts out of the car. The wrecker came and picked it up and paid me $95
Teardown was super fast when you dgaf. I assume this is how a chop shop feels lol
Old 10-06-2020, 04:50 PM   #8
xorox_88
oh this i am exited for
xorox_88 is offline   Reply With Quote
Old 10-06-2020, 04:55 PM   #9
GTJordan
Been here for too long
GTJordan's Avatar
Awesome. This swap is probably the only non-Volvo swap I'll get excited for. Very cool.
Jordan
Old 10-06-2020, 04:57 PM   #10
jstblz
jstblz's Avatar
With the motor on the stand and the trans on the table, it's a perfect time to do some upgrades.
Go Fast Bits DV+
MGW MT-82 Short shifter conversion (short length model - Call or email for the special version)
So short, I sits in the stock shifter position.
Radium Engineering baffle with port for catch can
Tune+ upgraded wastegate actuator & NGK 1-step colder plugs (not pictured)
Old 10-06-2020, 09:48 PM   #11
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Neat project! Looking forward to seeing progress.
also, do you have three more of these and are they for sale?
Alex Buchka is offline   Reply With Quote
Old 10-06-2020, 10:37 PM   #12
jstblz
jstblz's Avatar
The engine is narrow enough, but it's pretty tall so some work went into getting it under the stock hood.
I ended up taking off the sound deadening foam off the vacuum pump and high pressure fuel pump for more room. (Hope I don't regret that)
Happily there were no cuts to the fire wall but the cross member was ultra hacked. May make a new one some day.
It ended up pretty well.
Old 10-06-2020, 10:47 PM   #13
jstblz
jstblz's Avatar
Unfortunately that was a freebie off a racecar. Shop decoration only.
Old 10-06-2020, 10:51 PM   #14
doucheNozzle
doucheNozzle's Avatar
Subbbbed
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 10-06-2020, 11:38 PM   #15
Where’d the shifter end up w/ relationship to the tunnel opening?
That high pressure fuel pump stocks off the back a lot, glad you’re able to make it work.
FYI: there are a few rear sump steel oil pans that are pretty low profile that would allow the engine to sit lower and reduce/eliminate cutting the x-member.
Also, be prepared for some fuel line pressure hammering if you don’t have a fuel pressure damper in the system. Even with a return type FPR the steel fuel lines in the Merkur rattle like crazy from the rapid fuel pressure fluctuations caused by the high pressure pump.
Old 10-07-2020, 07:16 AM   #16
volvowagoon
volvowagoon's Avatar
Ooooo I like this.
2010 C30 T5 - My daily
IG: @v6buick
Old 10-07-2020, 08:19 AM   #17
jstblz
jstblz's Avatar
Trans pictures coming today! I honestly never thought about water hammer (or knew it had a name) until today so thanks. I ran all new soft lines with AN everything so hopefully that won't be as much an issue. Are you getting rattling in both feed and return?
As far as a different pan is concerned, the only thing I found was Motunes $2300 dry sump kit. It's super cool, but kinda expensive for this project.
Old 10-07-2020, 09:25 AM   #18
jstblz
jstblz's Avatar
Here is the connected package. It looks way longer than the B21ft/m46 w/ OD setup, but it worked out great.
Initially thought I could get away without any cuts, but that turned out to be false.
These mounting brackets/braces contacted the tunnel. Also it's easier to remove the trans with access to the top of the shifter.
Made a simple access panel. Once it's in place, there is no flex in the end of the tunnel.
For the trans crossmember, it was important to be able to use the OEM mount for simplicity.
It's a tight fit between the rails with no flex and it made to I can tuck the exhaust high on the passenger side with a bit of heat shielding for the body.
The shifter was too short in height so I put on a 4" extension and im so happy the OEM rubber boot fits nicely.
Oem shift knob with some modification should make all this have a stock look.
Old 10-07-2020, 09:50 AM   #19
poulrais
poulrais's Avatar
Nice build and interesting engine!
I will follow this for sure!
1990, Volvo 740 16v +T
Old 10-07-2020, 09:59 AM   #20
With soft lines you might be (probably will be) okay.
Here’s a link to a rear sump oil pan: https://www.retroford.co.uk/product/...wet-sump-d007/
The trans tunnel and shifter look great!
Old 10-07-2020, 10:01 AM   #21
Marvelous3
Who engineered this?
Marvelous3's Avatar
This is the best build in a long time.
Old 10-07-2020, 10:19 AM   #22
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
A+ for sure on this one, sticking with the stock ecu or getting something aftermarket?
Megasquirt Tuning!
Old 10-07-2020, 10:30 AM   #23
LC4CARL
Aero challenged
LC4CARL's Avatar
Wow!
Another shot of the car in the background with aviation-style riveted panels?
@PDXvolvo on IG
LC4CARL is online now   Reply With Quote
Old 10-07-2020, 11:29 AM   #24
jstblz
jstblz's Avatar
Wow!
This is my buddy, Nate's 300ZX. It even made it to Jalopnik Build of the Week
This is his shop's site - https://www.misfitautowerks.com/
Old 10-07-2020, 11:30 AM   #25
jstblz
jstblz's Avatar
Ford Performance Parts wiring kit with a OEM PCM that has a special flash on it.
