Old 10-08-2020, 10:36 PM   #1
Shinchan
Default Maximum drive shaft diameter that fits in a 140?
Will a 3-inch diameter drive shaft fit into the tunnel on a '72 140? Trying to figure out if I can use a stock Mustang drive shaft without it rubbing on the tunnel.
Shinchan is offline   Reply With Quote
Old 10-09-2020, 02:12 AM   #2
gsellstr
gsellstr's Avatar
Depends on your ride height. I did run a 3", car isn't real low though. If I had a lot of weight in it, on hard bumps it would scrub the center bolt for the seat belts.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 10-09-2020, 11:51 AM   #3
AndrewNance
Amateur hour!
AndrewNance's Avatar
Lowered? I’d imagine any one piece driveshaft is going to rub if the car is any lower than stock.
Old 10-09-2020, 01:05 PM   #4
Shinchan
It'll be lowered 40mm. I'll probably shorten the seat belt bolt ans see what happens.
Old 10-09-2020, 04:11 PM   #5
You want to run a ~2" 2-piece driveshaft. Going with the single piece 3" is not going to work.
Old 10-11-2020, 11:47 AM   #6
Shinchan
No it is not. I'm going to just get the stock 2-piece resized for the T5.
I'm only making 130hp tops, so the stock shafts should hold up just fine.
Old 10-12-2020, 01:27 PM   #7
gsellstr
gsellstr's Avatar
Yeah, at a 40mm drop, there's no way you'd be able to run a 3". Sounds like you're on the right track.
