Old 12-28-2015, 09:36 PM   #301
HUB
Needs more cowbell
HUB's Avatar
Originally Posted by cwdodson88 View Post
NICE! A t5 with that 8.8 should be perfect! btw, what ratio rear did you end up with? 3.73 or 3.55?
3.73
HUB is offline   Reply With Quote
Old 01-03-2016, 08:22 PM   #302
HUB
Needs more cowbell
HUB's Avatar
Default Sway Bar Installation
Start working on getting the old gasket material in the car for the fuel tank. Was wanting to get it in this weekend, but parts got delayed from IPD... Got the sway bar in, will make a few adjustments this week. Spent most of my time cleaning with my Ultrasonic cleaner.
Thanks,
Old 01-04-2016, 11:41 AM   #303
cwdodson88
Looking good! Did you score a T5?
The Build Thread
SVEA - PUSHROD TURBO!
Old 01-04-2016, 12:09 PM   #304
HUB
Needs more cowbell
HUB's Avatar
I did. Should arrive at the end of this month. Couldn't believe how hard it is to find one. Also order the adapter. Will need to find a m46 or m47 BH now.
Thanks,
Old 01-04-2016, 12:20 PM   #305
cwdodson88
Nice! I got a little held up with selling my house and trying to work on the car in the snow. Found out that my master cylinder is leaking and after having my car sit for 2 weeks I no longer have front brakes and no paint on my firewall So instead of a clutch with this paycheck, I get to buy a new master cylinder.
Old 01-04-2016, 12:31 PM   #306
HUB
Needs more cowbell
HUB's Avatar
What kind you going to get? I was going to get a Wilwood tandem unit. Will go with Wilwood for the clutch MC too.
Thanks,
Old 01-04-2016, 12:42 PM   #307
cwdodson88
Wilwood tandem is the way I'm going... its the Wilwood 260-8794.
Old 01-04-2016, 01:03 PM   #308
HUB
Needs more cowbell
HUB's Avatar
Yep, that's the one I'm going to get. However, there is a b230ft motor available and I'm fighting the urge to not buy it. Lol.
Old 01-04-2016, 01:13 PM   #309
cwdodson88
you can always buy it and build the sheet out of it for when that B18 lets go
Old 01-04-2016, 01:59 PM   #310
HUB
Needs more cowbell
HUB's Avatar
That was the plan. Was going to build it on the side. Been researching it for some time now.
Old 01-10-2016, 06:10 AM   #311
HUB
Needs more cowbell
HUB's Avatar
Start working on a few things yesterday.
Got the new sender unit in.
Realized I forgot to order a body rubber seal that goes around the neck... So now I'm trying to track that down.
Parts are trickling in for the new transmission too
Start working on some of the rubber seals on the car. Car doesn't really have any rust, but every rubber seal is shot.
Thanks,
Old 01-10-2016, 07:38 PM   #312
carbonmike
carbonmike's Avatar
Before:
After:
Thanks,
I need to replace my seals, sitting in a box somewhere in the basement. I mounted a gas cylinder from McMaster on the lift gate, very convenient.
carbonmike is offline   Reply With Quote
Old 01-11-2016, 04:42 AM   #313
HUB
Needs more cowbell
HUB's Avatar
There is a gas cylinder on the other side that's shot. I'll replace that sometime this week.
My outer seal was really bad, will replace th inner seal soon. When ever I order parts, try to order a few seals too.
I think the vent seals are the worse for me.
Off topic, love your roof rack
Thanks,
Old 01-16-2016, 07:17 AM   #314
HUB
Needs more cowbell
HUB's Avatar
Morning Everyone,
Starting looking through my list and I'm trying sort out what I need to buy to get this T5 in.
What I already have:
Ford T5 Trans (1352-199)
DeeWorks Adapter
M46 BH (LH2.4)
Here is the current list of items I still need (I think):
- Volvo TOB > What year do I use and what model of Volvo? Whatever works with the M46 BH?
- Volvo Flywheel and Pressure plate > Reuse what I have for the B18/ M41?
- Ford Clutch Disc > Yoshifab: https://yoshifab.com/store/8-5-ford-t5-clutch-disk.html
- Ford Pilot bearing > For V8 Mustang (same year as Trans): http://www.autozone.com/drivetrain/c...?checkfit=true
- T5 Poly Mount> Yoshifab: https://yoshifab.com/store/t5-polyur...ion-mount.html
- Gasket- I believe there is a gasket between the BH and the trans normally. What should I use since I have the adapter plate?
Also, for the M46 BH I got, looks like this was a cable clutch and my car was setup for hydraulic. So I assume it needs to be converted?
Thank you in advance for everyone's help!
Old 01-16-2016, 10:56 AM   #315
HUB
Needs more cowbell
HUB's Avatar
Have a picture of how you hooked it up to the bottom?
Thanks,
Old 01-16-2016, 01:13 PM   #316
cwdodson88
If you reuse your m41 clutch PP, its only going to be enough to hold 150-200 ft lbs, maybe less. going to a B21 turbo PP, or SAAB9000 PP and having you flywheel redrilled would be optimal for anything over 150ftlbs. At least thats what Ive been reading/hearing… Talk to JohnV or better yet since you're getting your Ford Disc from Yoshi, grab a PP from them also. The bolt pattern for b21 and b18 PP's are the same.
Old 01-16-2016, 03:37 PM   #317
HUB
Needs more cowbell
HUB's Avatar
I'm also trying to plan for the B230ft later.
Also don't see a PP available on their site. I'll have to do some more digging.
Thanks,
Old 01-16-2016, 07:49 PM   #318
carbonmike
carbonmike's Avatar
Thanks,
Used another female ball joint like at the top. I couldn't find hardware to fit it on the left side like the stock unit using inexpensive generic hardware. Had to trim them down so that the compressed length was short enough. I can get some daylight shots tomorrow if you like. I cannot remember how much it all cost but it was significantly cheaper than a direct replacement.
Old 01-16-2016, 08:35 PM   #319
HUB
Needs more cowbell
HUB's Avatar
That would be great! Thank you.
Old 01-17-2016, 08:20 PM   #320
carbonmike
carbonmike's Avatar
Old 01-17-2016, 09:42 PM   #321
HUB
Needs more cowbell
HUB's Avatar
Do you know the part numbers per chance?
Old 01-18-2016, 11:40 AM   #322
carbonmike
carbonmike's Avatar
I got it from McMaster, less than $20. From my order history
9416K28 Gas Spring with Threaded Ends, 75 Force, 18.18" Extended Length, 7.87" Stroke
And the ball ends
59935K73 Metric Ball Joint Rod End M8 x 1.25 RH Female Shank, 8mm Ball ID, 17mm Long Thread
Like I mentioned before I had to grind down the ball ends to get the compressed length as short as possible.
Old 01-23-2016, 09:37 AM   #323
HUB
Needs more cowbell
HUB's Avatar
Thanks again. I'm going play around with it this week.
The Wilwood MC's came in the other day and Transmission ships out Monday.
Hopefully I can get some work done today (first weekend I haven't been sick).
Old 01-24-2016, 08:55 AM   #324
HUB
Needs more cowbell
HUB's Avatar
Default Brake MC Installation and M46 BH Clean up
Started working on a few different things yesterday.
I did make the main brake line to the back... May redo it late (not happy with it).
Got brake MC put in. Didn't put in the clutch yet (don't know what route I'll be going).
The M46 BH for LH2.4 came in the other day. Will clean it up and drop it off to be powder coated.
Also started wrapping the exhaust. Note to self: next time, wear gloves. Lol.
Thanks,
Old 01-25-2016, 02:26 PM   #325
Old Iron
I Roll
Old Iron's Avatar
Drooling over here!!! Over all of it!
Turbobricked
