Old 09-11-2019, 07:36 PM   #1
Haystack
Default Sad day
Well I was driving my 87 240 home from work today when all of a sudden there was some vibrating and a loud noise. No dash lights came on so I limped it to the off ramp thinking it was a flat tire, got out to inspect and found that all of the tires were fine. I went to start it up again and it sounded like a straight piped tractor. I didn't want to investigate too much on the side of the freeway off ramp so I got it towed home. Once home I popped the hood to check the oil which looked fine, go to check the plugs only to find one of the spark plug boots just dangling, yep blew a spark plug right out of the head. Checked the coolant and it's mucky. Pour some out for my baby guys, shes dead for now
1987 244DL
Haystack is offline   Reply With Quote
Old 09-11-2019, 08:41 PM   #2
Rusty_ratchet
Rusty_ratchet's Avatar
I'm sorry to hear of your car troubles
Rusty_ratchet is offline   Reply With Quote
Old 09-12-2019, 12:25 AM   #3
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Use a spark plug thread chaser to clean the threads up, reinstall the plug, which may still be in the engine compartment somewhere, then change your coolant. It may not be a blown head gasket. Same thing once happened to me on an '84 245GL. Blew #2 out the plug hole. No acceleration, sounded like a lawnmower. Pulled off to the side, and discovered that yes, there was no plug in that cylinder. Installed a spare that was in the car, reconnected the plug wire, and kept driving.
Old 09-12-2019, 12:41 AM   #4
Throw a cylinder head on there and soldier on.
Old 09-12-2019, 04:18 AM   #5
Otto Mattik
Otto Mattik's Avatar
Originally posted by Jack
_________________________
Feedback Link: http://forums.turbobricks.com/showthread.php?t=323689
Old 09-12-2019, 07:23 AM   #6
rwb
Perfectly normal, perfectly natural, it's basically routine maintenance
Originally Posted by DaBossk View Post
have you ever used YouTube for more than 5 minutes in your life?
rwb is online now   Reply With Quote
Old 09-12-2019, 11:06 PM   #7
They all pretty much need a head gasket by 200K, and they mostly all have that by now.
Old 09-13-2019, 03:38 PM   #8
it is a lot easier to repair plug threads with the ehad off. If the threads are really trashed. A timesert is the best permanent repair. Number four is basically impossible to repair in situ.
