Old 06-15-2017, 11:44 AM   #1
Maligantblue
Default B230fk + Borg Warner K28
So... as the title suggests I have a B230fk and a Borg Warner K28 turbo.....
(the k28 for those not in the know, is a turbo used regularly on rather large diesel engines anywhere from 6 to 12L)
my question to you turbo wizards out there is:
Would such a massive turbo spool up? is there a way to calculate the spool and or efficiency of said combo?
Maligantblue is offline   Reply With Quote
Old 06-15-2017, 01:16 PM   #2
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
It's Borg Warner not KKK?
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 06-16-2017, 02:09 AM   #3
Maligantblue
All i know is it says Borg Warner K28 on the turbo housing
Old 06-19-2017, 09:39 PM   #4
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Aren't they the same? Bw/kkk
Old 06-20-2017, 02:01 PM   #5
Lankku
Lankku's Avatar
Easiest way to roughly estimate how it spools and what kind of power can be expected is knowing a couple of things. Compressor intake side size, turbine(exhaust) housing size, turbine extruder(outlet) size, what type of exhaust manifold and is the engine stock or modified.
BW and KKK are basically the same. I think KKK as a name has been dropped(?) and models live on.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", 965 -93 B6304T, V90 -98
Old 06-29-2017, 06:45 AM   #6
Janspeed
K28 is a similar size as the stock turbo on a 3.0L 911turbo and a 3.2L/3.5L e23 BMW 745i, both are 6 cilinder cars.
I doubt that K28 will spool up fast on a small 2.3L 4cil. Not before 3000-3500rpm anyway.
But you could do this: spray the engine with nitrous so that big ass turbo will spool up quickly.
Old 06-29-2017, 09:26 AM   #7
ryan242v
ryan242v's Avatar
K24 is the stock 911(930) turbo size and a K27 is the common upgrade, typically on a 3.2 or 3.3 liter six cylinder with lots of lag.
ryan242v is offline   Reply With Quote
Old 07-06-2017, 12:52 PM   #8
Maligantblue
nitrous is kinda of the menu for me, planning a rebuild though, whats the best things to upgrade to get the thing spun up around 3k? i was thinking very aggressive cams plus many other goodies.
Old 07-11-2017, 04:17 AM   #9
Maligantblue
these are the turbo specs as far as i can tell:
K28
Compressor
Inducer: 54,5mm
Exducer: 82mm
Turbine
Inducer: 81mm
Exducer: 71,5mm
Knowing this where can i go from here and how efficient/ laggy will this be, assuming i have a custom equal length exhaust manifold, and a 3" down pipe.
Old 07-11-2017, 09:58 AM   #10
Mogly
280WHP Regina
Mogly's Avatar
You'll be fine slap It on.
Mogly is offline   Reply With Quote
