cwdodson88
Well-known member
- Oct 27, 2011
- The Dalles, Oregon
lol. Looks good to me, J-pipe off the 4>2 stock manifold, putting the turbo over by the wiper motor and a fender exit downpipe.
Since your carb is pre-turbo and not pressurized, you really just need to worry about what the carb you end up with wants. I think most holley's are like 4-7 psi, so your in block mechanical pump and a carb pressure regulator will do just fine.I have a 4-2 manifold I bought last year actually. I can def use it for mock up.
What kind of fpr should I be looking at?
Pulled a few measurements. The carb base plate and water meth injection plate are already 6" tall when combined. I still need the 2-4 barrel adapter plate (1"), carb (3-4") and air filter (2-4"). So I'll need around a foot of clearance from the tom of the Dgv intake to the hood.
I agree. But for some reason I'm kinda attached to the nostalgia of the accel kit. I think a 142 with a chrome ram air scoop coming out of the hood offset to the passenger side could look awesome!
