Old 11-21-2017, 11:42 AM   #1601
LC4CARL
Aero challenged
LC4CARL's Avatar
I'm a total newb to the turbo scene. Should be a fun adventure.
Built-not-bought: PDXdl Resto-Mod.
Old 11-21-2017, 11:44 AM   #1602
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
They're fun. Just make sure you've got all of the components and fuel and ignition boxes too.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 11-28-2017, 08:14 PM   #1603
LC4CARL
Aero challenged
LC4CARL's Avatar
Have appointment at the dyno shop tomorrow to get a "before" number. Should be fun / never been. Hope it doesn't pretzel a skinny rod. Any guesses?
So far so good on the e-fan.
Old 11-28-2017, 11:13 PM   #1604
MrBrown
You like popsicles?
MrBrown's Avatar
83 hp
GhettoFab build thrizzie
Old 11-29-2017, 01:14 AM   #1605
cwdodson88
79 wheel hp, 99 ftlbs of torques
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-29-2017, 01:38 AM   #1606
75 wheel hp, 92 ft lbs of torque.
Old 11-29-2017, 06:11 PM   #1607
LC4CARL
Aero challenged
LC4CARL's Avatar
That was a total blast!
Old 11-29-2017, 06:13 PM   #1608
How many squirrel powers?
Old 11-29-2017, 06:38 PM   #1609
KeizerBrickGuy
Sh*t pot stirrer
You won't believe him. It's
Old 11-29-2017, 06:47 PM   #1610
cwdodson88
65?
Old 11-29-2017, 08:23 PM   #1611
LC4CARL
Aero challenged
LC4CARL's Avatar
Super fun. $90.
Humid, maybe 45*. Mustang dyno. They do a lot of Subarus, so they left it in AWD mode.
The guys were great. We discussed a redline (5500 rpms), they walked me through what to expect (he would short-shift up to third, then roll in the throttle from about 2k up). If the power had not flattened out, he could add more RPM's on subsequent pulls.
The car has: B cam, TME exhaust, no cat (for now), and magnets on the fuel line to align the gas atoms.
As you know, the same car will generate different numbers on different dynos. They are a tool to measure change. When I go back to the same dyno, with the turbo, they can tell me what the change is.
Apparently the car runs lean. The air-fuel ratio was in the 15 range. The tech was not too worried in my current NA set up, but said if it was a turbo, he would have aborted.
And red is horsepower.
Not bad for an old girl.
Old 11-29-2017, 08:33 PM   #1612
cwdodson88
so Mr Brown wins something... 112/135 is pretty respectable for a 30yo 2.3l 4banger. Especially since stock was like 114/136
Old 11-29-2017, 08:33 PM   #1613
Pro Sneaker Peddler
That's *very* healthy. My 91 put down 92 with a similar setup in a mustang dyno in similar conditions. Pretty good!
Old 11-29-2017, 09:17 PM   #1614
LC4CARL
Aero challenged
LC4CARL's Avatar
I can't take the credit. The RWC temp sender oil drain plug is worth 20 hp alone...
Old 11-29-2017, 09:19 PM   #1615
cwdodson88
and fresh parking lot swapped rear bumper trim has to be at least 5
Great start, makes me wish I got a baseline on my 122 prior to +t...
Old 11-29-2017, 10:09 PM   #1616
Ya 2.2 burns lean and mean.
Old 11-29-2017, 10:58 PM   #1617
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 11-29-2017, 10:59 PM   #1618
LC4CARL
Aero challenged
LC4CARL's Avatar
Ah, good to know.
Old 11-29-2017, 11:15 PM   #1619
MrBrown
You like popsicles?
MrBrown's Avatar
Gas atom alignment! That’s what I’ve been missing.
Old 11-29-2017, 11:46 PM   #1620
Cwazywazy
Cwazywazy's Avatar
112 wheel? Not bad, must be like 130+ crank if that's right.
Old 11-30-2017, 01:15 AM   #1621
LC4CARL
Aero challenged
LC4CARL's Avatar
Yeah, next time I'll connect the plug wire on the #4...
Old 12-08-2017, 06:17 PM   #1622
LC4CARL
Aero challenged
LC4CARL's Avatar
https://www.youtube.com/watch?v=YDyvruLSddk
At last!!
Old 12-12-2017, 11:19 PM   #1623
LC4CARL
Aero challenged
LC4CARL's Avatar
Scored a "smooth shifting and quiet" M47, with about half the mileage as my current unit, delivered for $100. So excited. Be nice to make the 1st to 2nd gear change in under ten seconds. In all seriousness, IMHO, a smooth gear box can make or break a car. Mine is, uh, broken. Really ruins the experience. Should be able to survive my "operation mild tee."
Old 12-13-2017, 12:37 AM   #1624
Cwazywazy
Cwazywazy's Avatar
Nice. Your "broken" one is probably a million times better than mine...
Old 12-13-2017, 12:44 AM   #1625
ORLY?
You've got one of the strongest NA engines we've even heard of and you want to mess with it?
