Old 12-03-2017, 12:00 AM   #351
Tuff240
240 Ninja
Tuff240's Avatar
Is your cross member already in the furthest forward holes on the frame rails?
-Patrick
Old 12-03-2017, 12:02 AM   #352
t8fanning
8v are still cool, right?
t8fanning's Avatar
It's in the most rearward holes.
1982 242 Turbo.
Old 12-05-2017, 12:45 AM   #353
t8fanning
t8fanning's Avatar
Crossmember is coming along. But that was a sketchy piece of machining. Lots of vibrations, lots of noise.
I need to shorten the mounting plate, weld it in, and then box the rest of it. I think it'll turn out pretty well.
Old 12-05-2017, 07:46 AM   #354
DET17
Reformed SAABaholic
Planning to box the top side of the X member, or leave it "open air"? Much of the section has been destroyed with the metal removal.
Old 12-05-2017, 12:27 PM   #355
cosbySweater
cosbySweater's Avatar
That nothing compared to how bad my xmember is haha
Old 12-05-2017, 01:31 PM   #356
Stiggy Pop
Stiggy Pop's Avatar
machining?
Don't get too fancy now, that's easy angle grinder work!
'79 242
943 pickup
Old 12-05-2017, 03:10 PM   #357
t8fanning
t8fanning's Avatar
Did you make one or modify the stock one? How big are the 4lx0s anyway?
Originally Posted by Stiggy Pop View Post
machining?
I tried angle grinding first, but it wasn't uniform enough for me. I'm mediocre at machining. I'm bad at grinding.
Old 12-06-2017, 03:59 AM   #358
t8fanning
t8fanning's Avatar
Spent some time with the angle grinder and welder tonight. I think it turned out pretty well. Not as nice as I'm sure some of you could make, but should do the job and look decent with some powdercoat on it.
Old 12-06-2017, 06:40 AM   #359
Pro Sneaker Peddler
Looks pro as duck to me
Old 12-06-2017, 07:18 AM   #360
DET17
Reformed SAABaholic
Very nicely done! Your weld quality puts mine to shame. TIG or MIG?
Old 12-06-2017, 08:55 AM   #361
M.H. Yount
M.H. Yount's Avatar
That dog will hunt. ;)
Old 12-06-2017, 10:37 AM   #362
t8fanning
t8fanning's Avatar
It's TIG, but I didn't do the welding. My good friend is a welder and helped me with this because there were some weird angles and a couple gaps.
Old 12-11-2017, 03:55 AM   #363
t8fanning
t8fanning's Avatar
Got the crossmember back from powdercoat. I think it looks great. I installed it and bled the clutch, but it didn't feel like it was releasing properly. I will re bleed it and if that doesn't work, I'll pull the trans again and check my throwout bearing adjustment.
While I've been doing this transmission stuff, I've also been remaking my engine bay wiring harness. I wasn't too happy about my old harness, I had no idea what I was doing, made some concessions, and wasn't sure it would work like I wanted it to. This time around I still have no idea what I'm doing, but I know a little bit more. This harness has much better splices, is only tefzel wire, and is concentric twisted (at least my ignorant attempt at twisting). In any case, I'm really happy with how it's looking so far. I still need to put some lacing on it, test fit it, cut the branches to length, put Raychem DR-25 and molded boots on, and install the connectors, but the hard part is done. The twisting made a huge difference. It's much more flexible than my old harness.
Old 12-11-2017, 09:31 AM   #364
oldschoolvolvo
oldschoolvolvo's Avatar
much respect. nice work.
-Mike
1998 V70 T5
Old 12-11-2017, 10:14 AM   #365
Stiggy Pop
Stiggy Pop's Avatar
nice work Tate, looks like fun
Old 12-11-2017, 02:46 PM   #366
Sweep
"This time around I still don't know what I'm doing." Pretty much me every time I go to work. Looking good!
Sweep is offline   Reply With Quote
Old 01-07-2018, 01:50 AM   #367
t8fanning
t8fanning's Avatar
Finally finished up my wiring harness. It took way too long because I didn't order everything at once, and messed up a few times with the DR-25 so I had to wait for shipping over the holidays. I had never used the heat shrink transition boots before, and I didn't do them perfectly, but they look good enough for me. The RT-125 epoxy was kinda hard to control, but with my trusty cardboard box, clamps, and a small heater, I think I did ok. I'm really happy with the CAS setup. I put a 4 pin Deutsch DT connector on the idle air valve bracket so I can swap between either style of DSM CAS.
It felt really good driving my car for the first time since before thanksgiving. The transmission feels nice, but I can definitely see why people say the TKO is notchy. During a shift, you definitely feel when it passes through neutral and goes into the next gear. It doesn't bug me too much, and I think it'll smooth out a bit once I get some miles on it.
Old 01-07-2018, 05:42 AM   #368
Funkee
Funkee's Avatar
Looks real good man! Inspires me to do my own
Old 01-07-2018, 12:37 PM   #369
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Default Solid
You're pretty good...
Old 01-07-2018, 02:17 PM   #370
StanleyR
OP, what's the purple switch on your dash for?
IIRC, on the old 140's, it was for the fog lights.
StanleyR is offline   Reply With Quote
Old 01-08-2018, 02:16 AM   #371
t8fanning
t8fanning's Avatar
Purple switch is launch control. I use the green switch for my additional driving lamps.
Old 01-08-2018, 07:37 AM   #372
DET17
Reformed SAABaholic
Very nicely done on the harness. I might have to go to such OCD levels on my 242 Whiteblock build. What engine management in this baby?
Old 01-08-2018, 01:21 PM   #373
t8fanning
t8fanning's Avatar
MS3 Pro. It's good, but if I was to do it again I'd probably use an AEM Infinity or something.
Old 01-08-2018, 01:25 PM   #374
Stiggy Pop
Stiggy Pop's Avatar
wait is there a mounting point on the NIW intake to use the stock brace? I don't think there is on mine.
Old 01-08-2018, 01:28 PM   #375
t8fanning
t8fanning's Avatar
There isn't. I don't use it to mount the intake manifold. Just the idle air valve, and now my CAS connector.
