Old 02-14-2010, 11:40 PM   #76
Jerd
Jerd's Avatar
If i buy another car for a DD i will be doing pretty much the same exact stuff. Awesome, simplistic, and clean build. Keep up the great work! You're going to love the cam! Big difference. But i do have to warn you it is in essence like the t25 vs the 15g that cam will have a lot less low end power but much more up top. It will change you're driving style. Also after the cam your car would benefit from a 3" downpipe.
What plugs are you running and how old? I changed my plugs the other day and was surprised to find how much smoother my car ran.
And what octane of fuel are you using?
Old 02-15-2010, 12:43 AM   #77
700volts
Word on the low end/top end difference as far as the cam goes, I am expecting just as you say. The plugs are about a year old, that's about when I arrived at Stage Zero. I remember doing a lot of searching here and ended up installing NGK brand, I don't remember what type, I think I stayed away from the platinum but I can't remember. I just looked at them a few days ago, they are nice and tan and wearing as they should be. A 3" DP is part of the plan but I want to lose the conical turbine housing and mate the DP to a flat flange housing because it looks to flow way better than the conical.
1990 740 Turbo THREAD - 1967 122 - 1989 780
700volts is offline   Reply With Quote
Old 02-16-2010, 12:43 AM   #78
700volts
Added a few pics to the NPR install section, apparently my install is something to shoot for. I've seen a couple installs that looked just as good though, there's a Green car somewhere that looks just as clean.
Old 02-19-2010, 08:21 PM   #79
klr142
Turbo, what?
klr142's Avatar
Haven't been in to see this thread before, but... Everything looks great! Except the "trick" with the springs. Seriously though, car looks good, I like what you've done with it so far and am excited to see it on the dyno soon!
We need to have a work day to get rid of your lowering job and do it the "right" way by cutting coils. Haha.
Old 02-22-2010, 02:21 PM   #80
700volts
Originally Posted by klr142 View Post
Well, my clutch failed the 4th gear stomp test this morning, it slipped, so I won't be on the dyno. :(
Old 02-22-2010, 04:14 PM   #81
klr142
Turbo, what?
klr142's Avatar
Get it replaced! Or turn down the boost!
Old 02-28-2010, 12:54 PM   #82
tomwas
Oldbie
tomwas's Avatar
Great job on that sweet ti, just curious, what size and type of clamping did you use on the coil srings to drop it, are the clamps just around 2 coils?
tomwas is offline   Reply With Quote
Old 03-20-2010, 02:12 PM   #83
700volts
I'm not supposed to talk about it
Old 03-20-2010, 02:17 PM   #84
700volts
So anyway the 15G swap went very well but,
I noticed when I got it all on I could spin the cold side a little with a bit of force, I was OK with that but it seems to be getting more loose. I know I got the ring clip seated nicely. Any one have this same problem. The housing doesn't really move by itself and it could only move an inch or two in either direction anyway but it's making vibrating sound and it's bugging me.
Old 03-20-2010, 09:20 PM   #85
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
The fan blade on the cold side isn't moving freely? It's bound to happen when you reclock the housings, because the coldside housing can easily be put on at a bit of an angle and won't sit completely flat, even with the ring clip. What I did was put the coldside on, tried to spin, felt which side of the housing it was hitting, and tapped that side with a rubber mallet. You'll just have to keep tapping it until it spins freely. Should only take a couple of minutes.
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 03-20-2010, 09:20 PM   #86
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
Actually now that I read it again I see you're talking about the cold side housing not the cold side fan.
Old 03-22-2010, 01:04 AM   #87
700volts
Made me laugh when you said fan. I guess you could call it a fan. BTW I like the new wheels.
Old 03-22-2010, 09:57 PM   #88
tomwas
Oldbie
tomwas's Avatar
I did it to mine yesterday while putting my summer rims and tires back on, Auto Palace had the stuff so I thought i'd give it a try, pretty pleased with the outcome.....
Old 03-28-2010, 08:39 PM   #89
Maximator
Trying to sell the 240!!
Maximator's Avatar
Location: Halifax, Nova Scotia (sometimes Kingston and Ottawa, Ontario)
Auto Palace?? Is that a place you guys have in the US? Kinda curious as to what this stuff is. Looks like the lowering is decent. Got a website for the parts?
RIDES:
1993 945 Turbo:
351 000kms, IPD Sways, Rear OL Coils, Biltstein HD all around, 2.5" SS Cat-back exhaust from IPD, NOW WITH ECODES, EIKER E1's and M46 Tranny
1985 245 NA: M46, stock, and older than me! in (slow) progress...
1992 245 NA FOR SALE
1992 Toyota Camry V6 Wagon
Maximator is offline   Reply With Quote
Old 03-28-2010, 11:59 PM   #90
700volts
Google this....... lowering spring clamps dangerous
Old 04-24-2010, 01:30 AM   #91
700volts
#9 PROJECT - NEW SPRINGS AND STRUTS/SHOCKS:
*Out with the old
*In with the new
BEFORE -
AFTER -
The front is now down where it should be, the rear came up a bit but it looks right to me. Went with IPD lowering springs and Sachs Turbo Gas shocks/struts to keep the daily ride not too stiff. I can't even make a decent comparison because the original shocks were so toasted. All I can say is it feels like a new car. I have a few bushings under there that need replacing so add those to the list.
Another shot messin' around...
Old 04-24-2010, 01:37 AM   #92
klr142
Turbo, what?
klr142's Avatar
Looks great, and I'm sure you feel much more confident bombing around in it now!
By the way, if you wanted, you could probably get away with chopping off the bottommost dead coil of those there progressive rear springs... It'll drop the car less than the height of the coil diameter... But, then again, it really is a perfect daily driver setup, because you have the height in the back to get a full load without issues.
Nice!
Old 04-24-2010, 02:43 AM   #93
spruill244
Mahalos
spruill244's Avatar
looks great man, need to respray those bumpers though
Image and video hosting by TinyPic
68' 145S-Sold
90' 745T-Sold
95' 850R-Sold
83' 244T-Sold
96' 850R- Sold
spruill244 is offline   Reply With Quote
Old 04-24-2010, 12:39 PM   #94
klr142
Turbo, what?
klr142's Avatar
"Re"spraying would require them to have been painted in the first place, lol.
I tried the heatgun trick on my car for a couple of seconds, worked a little bit but the gun shut down before I got very far.
Old 04-24-2010, 01:12 PM   #95
700volts
I'm thinking about using the dye that IPD sells. I think it's called 'Showroom New' in grey. Anyone have any input on that stuff?
Old 04-24-2010, 01:12 PM   #96
700volts
Old 04-24-2010, 01:36 PM   #97
nextproject
used showroom new on an 850 i had. works great, they sell it in grey and black. i did both trims on the f/r bumpers and had plenty left.
nextproject is offline   Reply With Quote
Old 04-24-2010, 03:43 PM   #98
700volts
I think mine are supposed to be grey, but way less oxidized.
Old 04-24-2010, 09:39 PM   #99
spruill244
Mahalos
spruill244's Avatar
they look so much better black
Old 04-24-2010, 09:50 PM   #100
700volts
I tend to agree...but then the bumpers would be black and the grill would still be grey. That stuff probably wouldn't work on a hard plastic grill, I'd hate to mickey mouse the grill with a coat of black paint.
