Old 10-13-2017, 03:31 PM   #976
55superbeetle
Yeah most likely mustang struts and a manual steering rack of some sort. I plan on keeping some resemblance of the factory front frame rails so it doesn't get called a racecar. Hoping to just tie in some good subframe connectors and a chromoly 8.50 cage. My biggest motivation on the mazda now is getting it done so I can start on my car.
Got the floor filled back in with room for the diff and driveshaft tunnel raised up, going to knock out the cage this weekend.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 10-13-2017, 03:38 PM   #977
SquareD
An Anomaly
SquareD's Avatar
Killer stuff.
Originally Posted by 55superbeetle View Post
6.0 with twin s366's. Reaaaaalllllly want to have AC in the car too, planning on rear mount radiator, but that could all be a pipe dream once I start mocking everything up. Probably going to move the firewall back some to make room. Lot's of dreaming that might not become reality.....but number one goal is to be able to drive it anywhere i want and run 8.50's, we'll see.....
Sheeeesh. Would you start it already.
Old 10-26-2017, 12:07 AM   #978
55superbeetle
I bent up half of an 8.50 cage to tie the back of the car back together, tied in the 4 link mounts too. Went back and forth on doing the full cage but decided I can add it in the future if he decides too. Found a perfect 14 gallon steel tank to go back in the stock spot and stay under the floor, even get to plumb the stock filler neck back it for super street car status. Added a small sump for the 044's.
Old 11-11-2017, 10:29 PM   #979
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
thank you for sharing. inspiring as usual.
Old 11-21-2017, 08:36 PM   #980
55superbeetle
Going back together for the last time I hope. My father in law who owns the car is pretty handy with a rattle can, turned out pretty decent. The cage was done with brush on hammer paint, probably wont use it again.
Old 11-21-2017, 09:33 PM   #981
soclosenotnear
Seconded.
Old 11-27-2017, 02:25 PM   #982
55superbeetle
Originally Posted by soclosenotnear View Post
Seconded.
Thanks guys
Old 11-27-2017, 02:53 PM   #983
Pro Sneaker Peddler
That looks awesome.
PS: I used the same paint you used on the cage for my wagon's roof rack
Old 11-27-2017, 04:04 PM   #984
55superbeetle
That looks awesome.
Thanks! I have seen the same paint used on other internet projects with better results, don't know if it was applied wrong or what. I should have done some test pieces first. It's not horrible but seems like it should have flowed better and been a little more uniform. At least its nice and hard and will keep it for rusting.
Old 11-28-2017, 10:15 AM   #985
boosted12a
weapon of mass detonation
boosted12a's Avatar
as much as i hate to see this done to a 1st gen RX-7, you did an awesome job. id like to see the final weight of the car.
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 11-28-2017, 11:44 AM   #986
Pro Sneaker Peddler
I think it's part of the "hammered" look. Looks like the intended finish to me anyway. Either way it's nice to use consumer-grade paint that takes minimal effort for fiddly, out of the way stuff like this!
Old 11-28-2017, 02:32 PM   #987
55superbeetle
Still needs the kirkey bolted in, driveshaft and fluids, not light but not a pig either.
Old 12-06-2017, 11:55 AM   #988
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Where did you find the tank?
Old 12-07-2017, 03:11 AM   #989
55superbeetle
http://www.tanksinc.com/index.cfm/pa...cat/cat133.htm
Old 01-17-2018, 02:11 AM   #990
55superbeetle
Bunch more progress, and it's a runner now, hoping to take it out on it's first drive this weekend.
