Old 01-29-2011, 02:29 AM   #101
funky_monkey58
funky_monkey58's Avatar
Originally Posted by gross polluter View Post
Then why are you so adamant on holding the OP back from his choice in EMS that you clearly have no experience with, while trying to persuade him to use another ecu you know nothing about?
I used MS once in a build several years back and absolutely hated it, the quality at that time of the system was **** and it was never able to satisfactorily control what I was trying to run. And this was with a MS system that was built to engine spec by DIY, and not myself. As well two separate tuning shops were unable to get it working with any success either.
To me MS is only good when you have no other options or have a serious cramp on money. As far as HP tuners go it is what I am going to run on my LQ4 as good friends of mine have convinced me to do so with example from their cars and the interface is top notch.
If the OP is going to keep the LQ4 stock a stock ecu will function perfectly and cost ~$50
funky_monkey58 is offline   Reply With Quote
Old 01-29-2011, 02:45 AM   #102
gross polluter
They see me trollin'
gross polluter's Avatar
You can't just plug in a stock ecu and expect it to work. You have to delete VATS which requires a $100 mail order tune, or at best a $300 used hptuners in addition to another $100 to license the VIN.
Carry along junior, you know not of what you speak. I deal with hptuners and efilive 8 hours a day, 5 days a week. I'm TELLING you that you're wrong. Just because you can't figure out the worlds most easiest standalone doesn't mean nobody else can. I'm also telling you if you don't have the aptitude to figure out MS, you're not going to get very far with hp tuners.
Old 01-29-2011, 03:09 AM   #103
Bigbegum69
slab rider
Bigbegum69's Avatar
Hey bud, how about you do the op a favor...
stop trying to be such a hard ass and cluttering up this guys thread.... we all know your an amazing tuner now!
Originally Posted by 55superbeetle View Post
Some crappy pics of measurements for Bigbegum69,
Thanks for the measurements! I had a lt1/th350 in my bertone, going turbo ls2 now and was curious about how your engine placement worked out.. keep up the good work
It may not lift the tire while turning in but...
Bigbegum69 is offline   Reply With Quote
Old 01-30-2011, 04:30 PM   #104
Mark
sex lights
Mark's Avatar
Ima say shut the hell up about ECUs and let's see what the OP does. I can extrapolate that, based on the quality of the fab work thus far, that whatever he chooses is not exactly going to be a "duct tape and zip ties" solution.
Fantastic build- Looking forward to more!
M.
Originally Posted by Double02 View Post
Classic TBricks - pages of discussion debating whether or not to spend $20. On a tractor.
Incorrect, the Frigidaire is Mark's 86 745. It's in appliance white and it is Best Car.
The Fridge; '86 745 DD-with full '94 LH2.4 swap. Now with M90!
2000 AMG E55 wagon.
'78 Honda GL1000- naked Goldwing.
'76 265 wagon with Megasquirted 350 chevy and T56. Scrapped
Mark is offline   Reply With Quote
Old 01-30-2011, 08:20 PM   #105
Dug strickler
Mr $ bags(but not really)
Dug strickler's Avatar
This car rocks... no short cuts. Just clean and classy. Steelies FTW! Massive props to you sir...
LS1 TT Volvette www.TheAntiTeam.com CLICK HERE 4 VIDEOS!
89' 745 w/ 544rwhp! Twin Turbo LS1 motor, Garret T040E's, 6-Speed trans, All Stainless Plumbing, Tial 38mm Wastegates, Custom Intercooler, Griffin Rad, All Fuel Upgrades, Bilstien/IPD Suspension, Swede Body Kit, 18x10/8 BBS LM Wheels.MYSPACE/VOLVETTE
Dug strickler is offline   Reply With Quote
Old 01-30-2011, 09:12 PM   #106
TerribleOne
ZoomZoom
TerribleOne's Avatar
If you ever decide to throw a 4L80/85E in there I can help you sort out options a standalone TCU.. This thing would be all kinds of awesome with an overdrive!
75 242GL - LS turbo, 4L80E, narrowed four linked 9"
89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters
94 945- Beater
93 965- For sale
91 940SE- Roller, for sale
TerribleOne is offline   Reply With Quote
Old 05-14-2011, 12:53 AM   #107
sikbrik
Sorry to revive...but it's a cool build and amazing fab, so probably not a bad one to bump.
Are any of you V8 guys running any driveline offset (side to side) or did you just center everything up and the custom diffs make it all centered? Or am I imagining the stock offset on the 1031 rear seeming to be about 1.5" to the righ (pinion centerline)?
Thanks!
sikbrik is offline   Reply With Quote
Old 05-20-2011, 10:11 AM   #108
i drift volvos
cracker
Most of the 240 v8 guys run a shortened ford 8.8 that is centered. (See post #33)
I'musing a one piece driveshaft on a centered differential. The tunnel seems off center to me. I had some rubbing issues on the driveshaft I had to address....but nothing major.
1986 Volvo 245 v8 drift project
i drift volvos is offline   Reply With Quote
Old 06-02-2011, 12:27 AM   #109
55superbeetle
Really small update as I have been busy as hell with my new baby girl and helping a few friends with their projects, as I haven't been wanting to spend any money on mine.
I did manage to get my wiring harness all done though which I was dreading. Thomas also got some of my parts powder coated in return for my doing a megasquirt setup for his bug. I took advantage of half off at pick n pull and got a small honda alternator and gm power steering pump that I will work on mounting this weekend. I also bought a torque converter (3500 stall) and a 87 vette radiator so the last big piece of the puzzle I need to buy is a driveshaft.
Progress has been slow but it's getting there.
Few pics
55superbeetle is online now   Reply With Quote
Old 06-08-2011, 03:11 AM   #110
toms_elleck
toms_elleck's Avatar
Now that I've helped you with the harness for my car, I realize how much work goes into making the harness come out that cleanly. Excellent work, man!
-Thomas
toms_elleck is offline   Reply With Quote
Old 06-09-2011, 02:17 AM   #111
Bigbegum69
slab rider
Bigbegum69's Avatar
looks good with that style loom and heat shrink... I use the same style stuff and always have people asking where they could get some
two thumbs up!
Old 07-04-2011, 04:39 PM   #112
55superbeetle
I finally got a full day to work on it, it has been 102 degrees here all day but that didn't stop me. Got my honda alternator and power steering pump all mounted. Also got the brakes plumbed and then put it all back together. Looks good all clean and shiny! Progress should be a little faster now....I hope
Some pics of the progress,
Old 07-04-2011, 04:48 PM   #113
2fast242gt
Do you have a cobalt?
that really looks great! i wish you could produce a few of those x members they are awsome!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 07-05-2011, 11:20 AM   #114
euroshark
euroshark's Avatar
Very nice work! Looks right at home in there.
euroshark is offline   Reply With Quote
Old 07-05-2011, 01:12 PM   #115
toms_elleck
It's coming along nicely! Hard to believe that alternator and power steering pump aren't factory for that engine. They look like they belong there!
Old 07-05-2011, 04:13 PM   #116
SvedSled
In the gray
SvedSled's Avatar
Very nice! Super clean fab work! I can't wait to see how you resolve the header/steering shaft clearance. Keep up the good work!
I has nothing to contribute.
SvedSled is offline   Reply With Quote
Old 07-05-2011, 05:44 PM   #117
doucheNozzle
doucheNozzle's Avatar
What coil packs are those?
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 07-05-2011, 05:50 PM   #118
toms_elleck
From the previous page:
Coils are off a ford explorer, same coils all the edis stuff uses. Just used them because I am familiar with them and there is at least 50 of them at every pick n pull. Plus I scored a set of new motorcraft plug wires for 5 bucks on ebay!
Old 07-05-2011, 05:50 PM   #119
doucheNozzle
Answered my second question too! Thanks Señor T.
Old 07-07-2011, 12:20 PM   #120
nohbudi
Jesus Christ...
nohbudi's Avatar
Jeff, I can't believe you are building a volvo... I thought you would have learned to avoid them for as long as you messed with Jons 16v build. Congratulations on the new baby, I have three now (Kiri).
I might be interested in one of those 8.8 setups if you are interested in building one...
Originally Posted by MacRaperLinuxBoy View Post
Can I convert my car 740 to front wheel drive? I really want to keep my PRV so please suggest ways of converting my car to FWD while retaining my Renault motor.
nohbudi is offline   Reply With Quote
Old 07-07-2011, 11:33 PM   #121
NONHOG
equal opportunity car guy
NONHOG's Avatar
Nice work! Makes me want to stop the 5.0 install and toss it in the garbage.
Old 07-08-2011, 01:15 PM   #122
doucheNozzle
I would.
Old 07-08-2011, 01:31 PM   #123
2fast242gt
stock 5.0? i wouldnt ever unless it was some type of stroker. im a huge fan of lsx swaps though such beasty motors they make power and they will do it all day reliable! thats why theres so many lsx swaped nissan drift cars now
Old 07-08-2011, 02:24 PM   #124
doucheNozzle
You wouldn't throw a stock 5.0 in the trash?
Old 07-09-2011, 02:50 AM   #125
2fast242gt
I would recycle it I ment wouldnt ever run a stock 302. It would have to atleast be a stroker but ls is my dreampower plant!
