Old 06-13-2012, 10:33 AM   #26
volvobrage
Originally Posted by 550 View Post
Well, when TIG welding, you are using an AC power source. The properties of the AC wave actually can clean the aluminum depending on how you have the AC balance set. (On my Miller, 3 is balanced.) But with the AC balance, you can adjust the amount of penetration vs amount of cleaning action needed. (More cleaning action for aluminum that is dirty, like cast aluminum tends to be)
There depending on the aluminum, you don't need as much cleaning action, which is indicated by the white border on the weld bead.
Doesn't mean anything is wrong, just think you probably don't need much cleaning on that aluminum.
Aaaah I seeI think i understand
But the bigger the white line is the more dirty is the aluminium?Or does it mean that the welding machine has godd properties on the AC wave?
volvobrage is offline   Reply With Quote
Old 06-13-2012, 10:51 AM   #27
550
You are getting it, essentially. But you can change the size of the white border around the bead by using AC balance. So if you have really dirty alum, your white border will be larger with more cleaning action. But on clean alum, you would have a smaller white border.
I looked up your machine,
You don't have an AC balance knob, so that may be the reason why. But you do have SP % which seems to control the balance of the AC Sine wave.
Check out this link,
http://www.goodsdirect.net/200adc.htm
SP% Dial
is the length of welding time versus cleaning time, set to max cleaning at 30% welding time and 70% cleaning,
So, if you have that knob set higher (like 70%) you will have a bigger white border, good for dirty aluminum. But for clean metal you can probably bring it down a little bit more and reduce the size of the white border on the bead.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 06-13-2012, 01:55 PM   #28
volvobrage
Thank you for the good explanation!I learned alot from thisWill try to adjust next time I weld alu and see how it goes
06.11.2011
Started on a rotation device for the bodyOnly pictures this time
Old 06-13-2012, 01:56 PM   #29
volvobrage
Old 06-13-2012, 01:57 PM   #30
volvobrage
Old 06-13-2012, 02:32 PM   #31
Homer
OEMplus++
Homer's Avatar
Welds look great. Very consistent!
I'd love to have a MIG around.
I'll be measuring that engine mount this weekend I think.
-Jacob:
2006 A4 - Comfy DD
Old 06-13-2012, 03:00 PM   #32
volvobrage
Thanks Homer!Its nice to hear thatI put alot of time into try making good weldings..
That would be great!Then the engine would be in the car soon
Old 06-14-2012, 08:25 AM   #33
volvobrage
So, now we soon start on the widening part!
Took the car down to my neighbors workshop were I'll be working on it
Ripped off some more peaces
And took out almost the rest of the interior
Took down the gastank
And the rear suspension
Started to clean a little bit inside the front fender just to see how it will turn out eventually
Old 06-14-2012, 08:29 AM   #34
volvobrage
Finished the rollers, had to attache the pipes that are going into the bumper hole
Took out the "rear door panel"
Grinding and new paint to see how it looks likeWill be nice to see the whole underside like this!
And got the car up!Took of the front suspension also so it would be easier to turn
Cutted a little bit
Drilling
FinishExept from the front there, but need to replace the piece in the inner fender anyway so I didnt bother..
Here I ****ed up, but it will be changed anyway because of rust inside between the plates..
Old 06-14-2012, 08:30 AM   #35
volvobrage
The rest of the welding parts I need to widen the carI only work on the body in the weekends and vacation, thats why the "long" time between the dates on body updates..
Old 06-15-2012, 07:20 PM   #36
volvobrage
Started cutting the wheel arc
Cutted away the bad part, grinded a little bit and put on some welding paint
Spotted on a new plate and welded it..
Took away the plate in the wheel house front
And the wheels house it self dissapeard
Not sure what this peace is called in english, but I cutted it awayLooked good inside!
Adjusted the new one and put clamps on it
Cutted a little bit and found the jack! Here its 4cm but i wont be doing so much..
Old 06-15-2012, 07:22 PM   #37
volvobrage
Made the "finish" cut on the wheel house and knocked it strait so it will flush with the new peace..
And made the inside here..I make all the parts in paper first and transfer that to metal
Old 06-15-2012, 07:23 PM   #38
volvobrage
Cutted a flange for the turbonetics turbo on the cnc plasma and drilled the holes
Old 06-15-2012, 07:25 PM   #39
volvobrage
Whent to the carscrap(??) and found a 960 thereMe and a friend pulled down the front and engine
Pulled away the geardbox and all the garbage
And the parts for me!:D My friend will take the front and engine for his 740 turbo project
Old 06-15-2012, 07:27 PM   #40
volvobrage
Finish welding and grinding on the wheel house!!
And removed some tectyl on the inner front fender
Old 06-15-2012, 07:30 PM   #41
volvobrage
First in paper!I will make to pieces so it will be easier to shape it and put it in
And then in steelplate
Made new plate her
And welding
And grinding
Tried to take some pictures to show the rear fender, but not easy to capture in photo yet..
Old 06-15-2012, 07:34 PM   #42
volvobrage
Finished on the piece without a name
And the inside..Welding all the way through
Finished the wheelhouse
And after grinding it will look like this!
Attached the rear fender here again
welding and grinding, welding and grinding
A little problem here I need to fix
Old 06-15-2012, 08:47 PM   #43
corivus
Hey Shiny!!
corivus's Avatar
Wow you get work done, nice job and looking good so far
corivus is offline   Reply With Quote
Old 06-15-2012, 10:00 PM   #44
vagabond
vagabond's Avatar
i am suddenly very interested in whats happening here
-Vagabond
1980 242 DL - shake a tail shaft!
1980 242 DL - (the ugly twin) sold :-\
1986 s10 blazer, smallblock, bagged, suicide doors.
RIP 1991 244 N/A - stripped and left for scrap.
vagabond is offline   Reply With Quote
Old 06-16-2012, 04:44 AM   #45
volvobrage
Thanks for that!Since I borrow my neighbors garage I have no choice other than working like hell when im there!Thats nice, because then I get things doneI have worked 8 - 10 hours every weekend when the car have been there(exept when something more important came up)
Just stay tuned, as I sayed I have alot of pictures!As of today I am finished with the widening part on both sides..Exept from minor fixes, welding some places and grinding some places
Old 06-16-2012, 07:30 AM   #46
volvobrage
As I said before, I borrow my neighbors workshop..Since he needed it for himself i pulled down the car againIt was nice to have a look at the work so far with the car on the wheels!
Original side
And the widened side
Looks cool I think!There is alot of bondo on the fender from the horrible paintjob so I think thats why the paint is so "flurry"
Old 06-17-2012, 12:11 PM   #47
550
Lookin awesome!! Keep it up
Old 06-17-2012, 12:31 PM   #48
M.H. Yount
M.H. Yount's Avatar
That piece 'with no name' -- I think we'd call it a rocker panel extension.
Old 06-17-2012, 12:35 PM   #49
Mueller
Mueller's Avatar
Very impressive...looking forward to seeing how this turns out!
Old 06-17-2012, 02:06 PM   #50
2fast242gt
Do you have a cobalt?
nice clean job on the widening!
1983 242dl
*6.0 lq4 swaped* Build thread
