Old 11-11-2017, 10:45 PM   #776
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
congratulations on the progress.
Old 12-06-2017, 04:53 PM   #777
Tompoes
Tompoes's Avatar
Wow man, this is the best build tread i've read so far!
You are an amazing fabricator! I am in love with your gauche cluster
Keep up the good work!
Tompoes is offline   Reply With Quote
Old 01-05-2018, 04:11 PM   #778
Vlaming
Very cool build sir
Vlaming is offline   Reply With Quote
Old 02-20-2018, 04:49 PM   #779
volvobrage
Thanks alot for the nice comments!!:D Will bomb the thread With some Pictures again:p Im really not god at updating on the way.
5/11/2017
Got some parts from a friends partcar. Frontfenders.
Frontplates
Headlights, mostly for testing, but they arent as bad as I tought. A few extra parts and the will work good.
And alot of other small Things.
21/11/2017
Clamps for the pressure pipes!
Fuelpressure regulator from Speeding.se. Check out there site, they have alot of awesome parts!
Original Volvo 19t turbo
Exhaustflange and lambdanut.
And Connection for the fuel rail.
volvobrage is offline   Reply With Quote
Old 02-20-2018, 04:54 PM   #780
volvobrage
Pipes for water cooling.
Tried to take out the pin bolts in the R manifold. Broke both of them:p
Turned the turbo for RWD use.
Tested the New front also!
Old 02-20-2018, 05:13 PM   #781
volvobrage
Made parts for the throttlebody distance.
Cutted and marked the waterpipe, making it out of two 850 pipes.
Old 02-20-2018, 05:14 PM   #782
volvobrage
Drilled holes for the belts
And welded the waterpipe.
Old 02-20-2018, 05:39 PM   #783
volvobrage
Welded in the threaded Things for the belt.
Welded the throttlebody adapter, missing some Mounts.
Old 02-20-2018, 05:44 PM   #784
volvobrage
Got some AN Connections for the turbo. AN4 for the oil and AN6 for the water.
Got a original gearbox Mount and drilled holes for the ZF.
Welded Mount for the MAP sensor. Please dont look at the welds!
Spotted the intercooler/radiator Mount together.
Had to cut away alot from the lightmount plates to get Space for everything.
Spotted With everything in Place!
Started on the New strutbrace, bolted together the parts.
Spotted the first part of the generator Mount.
Borrowed this awesome tool from a friend!
Drawed some parts and had a friend at my old work Place cut them out for me.
Spotted together
Spotted and welded the first pressure pipe:D
Old 02-20-2018, 05:47 PM   #785
volvobrage
Spotted and welded the other pressure pipe.
Finished the strut brace.
Welded the Connections on the intercooler.
Removed the lid from the radiator.
Welded a New pipe With correct OD.
And made the upper cooling pipe.
Old 02-20-2018, 06:24 PM   #786
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
that generator "panhard" is genius!!
Old 02-20-2018, 07:09 PM   #787
Ilvmetal
Ilvmetal's Avatar
Crazy Inspiration!
1973 142 Turbo 16V build
1986 FJ60 V8 conversion "lerch"
1989 740 bunch of stuff done
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 02-20-2018, 07:57 PM   #788
Venlonaer
Venlonaer's Avatar
I'm one hour and a half into your thread reading everything and looking at the pictures. Was well worth the time.
Respect on the attention to detail, car is coming along nicely.
Great inspiration and motivation for my 242 project, also considering to make it widebody now after seeing 2 widened 242s.
Venlonaer is offline   Reply With Quote
Old 02-21-2018, 08:16 AM   #789
volvobrage
Thanks! Its right/left threaded so its easy to adjust
Thanks alot! Really nice to hear
Just do it! Its alot of welding but not so hard. My biggest tip is to buy the wheels you want first. Would have saved me alot of work since I had to redo some small things after testing the wheels.
Old 02-21-2018, 08:20 AM   #790
volvobrage
Decided to drop the airfilter box I made. It didnt fit with the new front and I think the front end is much more important.
Welded a pipe for the filter. Will have a hose from the inner fender and place the filter somewere in the front.
Last two welds of the week turned out awesome in my opinionReally nice to get some time with the tig to practice.
Like this. Will be a plate bolted in the inner fender and welded to the pipe. The pipe goes from 3"-3,5" and from 3,5"-4" right before the end.
When youre working 10+ hours on the car each day its nessesary with good lunch!
Welded some holes I dont need in the front plate.
Old 02-21-2018, 08:22 AM   #791
volvobrage
Spotted togheter a windshield washer tank.
Testing. Think I might move it to the other side, but will look at it more this weekend
And some pictures I took sunday before I left the car for inspiration!
Old 02-21-2018, 10:56 AM   #792
Tfrasca
Tfrasca's Avatar
This is insane! Are you using really stiff engine mounts? There doesn't seem to be much flex in the intake and intercooler piping.
Old 02-22-2018, 03:45 AM   #793
volvobrage
Yes they are quite stiff, my brother uses the same in his 740 T5
But Since there are 90 degrees silicone on both intake and turbo I think it will work fine. They allow pretty much movement The intercooler and radiator stands on rubber mounts so they will give a little bit of movement so the pipes doesnt crack. I hope
If this doesnt work I will replace the connections with movable. I bought these, and two weeks later speeding had new ones(same brand) who can move around some degrees...But since I already had these I want to try them.
Old 02-22-2018, 03:47 AM   #794
volvobrage
Im using ASS, AnderssonSteel&Speed engine mounts!
Old 03-04-2018, 04:27 AM   #795
Stefan940T
No hockey pucks?
Stefan940T is offline   Reply With Quote
Old 03-04-2018, 07:53 AM   #796
volvobrage
Originally Posted by Stefan940T View Post
No hockey pucks?
Nope
Old 03-04-2018, 08:46 AM   #797
Pasis
Cool project! And where do you buy these aluminum elbows?
Pasis is offline   Reply With Quote
Old 03-04-2018, 09:11 PM   #798
evolvo67
evolvo67's Avatar
I've been reading your thread today on your awesome build! I got to pg 26 from 2015 where you mounted the Watts link. Something didn't seem right about how you did it and I don't know if anyone else has addressed it since I've traveled through time to 2018. It's where you mentioned getting both arms to the same angle that seemed wrong. So here is a vid I found about the basic workings of a Watts link:
Old 03-05-2018, 02:25 AM   #799
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
had a look at the speeding shop.. cool parts... i wanted to replace my chinesium FPR through an AEM one, but thats also pretty cool..
Old 03-05-2018, 03:44 PM   #800
volvobrage
Thank alot! Ive bought some from a friend and the rest at speeding.se! They have cones and everything in aluminium.
You are not the first to adress it! And I dont know if you read the Whole thread but I decided to cut away the New Mount I made and just go With a regular Panhard. Becuase of the Things you mention, there was several Things wrong With the way I did it.
But thanks for the heads up anyway! Important to share ideas, espesially when its important corrections!
Yes, they have alot of Nice parts! Everything in my fuel system will be from them
The parts they have that they make themselves are really good quality and they make spareparts for everything
If you are ordering something you can mention my name, that would be really Nice of you
