Old 07-02-2012, 02:10 AM   #101
volvobrage
"New" bars for the front fenders
Cutted this of a part car and cleaned it
Finished welding and started grinding
volvobrage is offline   Reply With Quote
Old 07-02-2012, 02:12 AM   #102
volvobrage
More parts!
This I will combine with 740 turbo front shaft and 740 bearing for the shaft
Old 07-02-2012, 02:14 AM   #103
volvobrage
Finish grinding on both sides
And some paintIt looked good, under the car it will be grinded 100% flat..
Welded all holes on the left side also
Accident when pulling the engine and gear out..
Fixed
Old 07-02-2012, 02:18 AM   #104
volvobrage
Picked up some parts from blasting!Complete front suspension for my friends 740 also
My parts
This plate also!
Cutted out this from the part car..Hoped it looked good!
And it did!
My floor
Finished welding and grinding
And fixed some small holes after taking the plate inside the car out..
Here also, some small things that I didnt finish under the widening prosecc because of the bad time..
My mothers 245 in the background
Welded eight holes in the trunk
Some temporary paint
All the welding on the floor finished!
Old 07-02-2012, 02:19 AM   #105
volvobrage
Grinded down on the underside, it looks really good now!
Old 07-02-2012, 02:22 AM   #106
volvobrage
Painted a little bit here..The lines you can see are not welding, but that **** that is under the car..Im really satisfied with this weldings!
Some paint other places I welded
The seamwelding is starting to look like something
Some grinding here also evetually
Old 07-02-2012, 02:23 AM   #107
volvobrage
Finished the seamwelding and grinding in the front of the car!
Grinding here also
Started on the peaces for the wattlink
2 meters of alu pipe for the intake manifold
Old 07-02-2012, 02:25 AM   #108
volvobrage
Took this from the part car since my had been pulled a little hard
Seamwelding..Decided to do like this in the back, wasnt exactly sure how to do it here..
And all the way back
Old 07-02-2012, 02:28 AM   #109
volvobrage
Got the measurement on were to put the new peace for wattlink from Exerqtor!
Welding and grinding
Grinded more here
And the seamwelding is FINISH
Old 07-02-2012, 02:30 AM   #110
volvobrage
Got this reinforcement plates on
Had to bend a little bit, but I think it looks good still..
To holes here when I grinded the thick grey **** away
Welded both sides here, leftovers after the widening
Old 07-02-2012, 02:32 AM   #111
volvobrage
Started on my floorpanHow will this end?
It turned out ok
Here it has perfect measurment between the holes
Here I need to grind a bump, because it needs to come a little bit closer also
Old 07-02-2012, 02:33 AM   #112
volvobrage
Grinded a little bit inside the car
Old 07-02-2012, 02:35 AM   #113
volvobrage
Moved the car to my place again, since my neighbor wanted his workshop back again for the summer
Really nice to see the car outside!Will take pictures the same place when its finished
Here it will stay for a while..In good company with my Amazon
Old 07-02-2012, 02:37 AM   #114
volvobrage
Piced up the last rims also!Now I have officialy bought themNice hight!!
Old 07-03-2012, 02:13 PM   #115
volvobrage
Spotted on the reinforcements
And welded
Took this old peaces out..Welded four strings inside and just knocked them out with a hammer
And grinded
Old 07-03-2012, 02:16 PM   #116
volvobrage
Picked up the engine:D Took a 115 norwegian miles roadtrip to get it:p Drove 5 a clock after work and returned the next day 9 o clock and took of straight to work..Tough day at work!
The guy I both the engine from had a "ok" car!
Safe homeMy mothers 245 runned like a clock the whole way!
Took the wireharness off the next day
Old 07-03-2012, 02:18 PM   #117
volvobrage
Got the engine out of the car
Took of this since I not need it..
And took the intake manifold away, need the other type like the s60r have
Took of the old engine mount and the heatshield to
Old 07-03-2012, 02:21 PM   #118
volvobrage
Took off the tire on one of the rims, are going to start to fix this
Made my floorpan ready for welding but had no alu left for welding:(
Took this from a 6cyl engine and cutted it for the 5cyl engineWill use it for the new intake manifold
And pressed new bushnings in here
Old 07-03-2012, 02:22 PM   #119
volvobrage
Small update since my back is ****ed, took the bolts out from the rim
Old 07-03-2012, 02:24 PM   #120
volvobrage
Drilled this with 30mm holeTo put the bolt in place
New nuts for the rims!
And welded my floorpan!
Need some comments no to get a new page for more pictures!:p We are soon in the presens of this project
Old 07-03-2012, 02:45 PM   #121
M.H. Yount
M.H. Yount's Avatar
Comments, comments, comments!!!! Have really enjoyed following along on this one. Anxious to see it continue to come together.
Old 07-03-2012, 03:05 PM   #122
Roy 940
The onliest comment I can made is : WOW!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 07-03-2012, 03:32 PM   #123
shaved240
shaved240's Avatar
you get stuff done!
nice work.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 07-03-2012, 04:08 PM   #124
volvobrage
Thanks alot guys!!Im really looking forward to getting the body togheter also!!I have a really nice vision in my head
More pics!!
17.06.2012
Did some floorpans for two guys on the norwegian volvoforum to
Took the manifold off to get to the water pipe
Started on the oilpipe, a little bit to long
After cutting, grinding and washing
Nice fitment!
After weldingThe floorpan actually fitted also:p
Old 07-03-2012, 04:10 PM   #125
volvobrage
Started a littlebit on the waterpipe
Need the engine mount before I can finish
