Old 07-03-2012, 04:13 PM   #126
volvobrage
Started on some s38 throttle body i want to use on the new intake manifold
Did not fit so good
Cutted a little bit more, no it looks betterMust be able to fix something with this
Er det dumt for luftstrømmen og kone runnersa?Ser mange som selger trakter har dei kona..
volvobrage is offline   Reply With Quote
Old 07-03-2012, 04:15 PM   #127
volvobrage
Cutted the peaces for engine mountsHomer style!But wanted to make them myself with 1mm thicker plate
Old 07-03-2012, 04:17 PM   #128
volvobrage
Used my lunch at work to drill the engine mountsWelded two and two peaces togheter when i drilled
Nice package in the mail! Turbopressure gauge, oilfilter adapter, 7/940 engine pillows
Old 07-03-2012, 04:19 PM   #129
volvobrage
Started on welding the engine mounts
Finish welded
Welding inside also
Old 07-03-2012, 04:20 PM   #130
volvobrage
Welded the other also
Finish grinded
Totally finish!
Old 07-03-2012, 04:30 PM   #131
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
looks good, i'll have to consider those mountpoints when i do something.
Old 07-03-2012, 05:37 PM   #132
volvobrage
The rubber engine mounts?They are reinforced also, kosts about 25 dollars
Old 07-04-2012, 05:13 AM   #133
Burnsy
Looking good. When are you coming to Australia to widen mine?
Burnsy is offline   Reply With Quote
Old 07-04-2012, 11:32 AM   #134
volvobrage
When you pay the trip and stay for me and my girlfriend!!
Old 07-04-2012, 11:49 AM   #135
Homer
OEMplus++
Homer's Avatar
Looks good! For the lower bolts I just ended up using some M12x30mm bolts on either side. I ditched the through bolt idea so I wouldn't have to clearance the control arms.
I'm going to go measure that engine mount for you right now!
-Jacob:
2006 A4 - Comfy DD
Old 07-04-2012, 03:12 PM   #136
volvobrage
Hmmm, I see your idea..Will bring some m12x30 bolts also and check the option!Thanks Homer
Very nice of you to make the drawings also!Save me for alot of work I dont have the tools to do at home
Old 07-09-2012, 04:02 AM   #137
volvobrage
Paintstripper I bought for the rims!
Started splitting the rim
Put on the paint stripper, before I could find my cellphone it had started working
10 minutes after
Starting to look like something
And almost finished
Old 07-09-2012, 04:05 AM   #138
volvobrage
Started taking apart the doors
Everything out, exepct the windows
Windows gone also
On the left door both these weldings were cracked, somebody closed the door to hard a couple of times!I suspect a female driver!!!!
Old 07-09-2012, 04:06 AM   #139
volvobrage
Picked up some parts at Volvo!
From now on the updates will come as I workThe car will be moved to the workshop the next wekend and continued on some bodywork!New pics then
Old 07-17-2012, 11:17 AM   #140
volvobrage
Tested a turbo from 940 on the manifold..Will maybe use this in the beginning, will see
A friend fixed me an intake manifold!:D Waiting for it in the mail
And spent some time with autocad after work one day
Old 07-17-2012, 11:24 AM   #141
volvobrage
Intake manifoldWill remove the nozzles on the runners(the car have been driven on gas)
And I need a new gasket, didnt know it was a different flange on the new intake manifold..
Took the car to the temporary "workshop"
Soon to be best friends!
Cutted a little bit here..Will not use the trimmings here anyway
Grindend away old broken welding and welded againAll the way through the corner
Welded some holes in the engine compartment
Been crashed here aparently:(Not decided if I will cut it away and replace it..
Welden holes in the front fender
The old weldings on the doors fixed
Welded holes in the door also
Fixed the problem here
And took this away, will replace it with black hoses or alu pipes
Old 07-17-2012, 11:28 AM   #142
volvobrage
Spotted it togheter again, cutted away little bit more because of rust
The other fender fixed
Also the other door
Crack in this door also:p But not on the welding itself
Spotted on a new peace, but big gap to fill:(
Finished welding and grinding
Some temporary paint
And started here again, can finish no that I know what I will do in the back..
Old 07-17-2012, 11:30 AM   #143
volvobrage
Paint on the last frontfender
Not finished grinding, but you get the picture
Some overall pictures!I think it look really cool!
Favorit picture
Old 07-17-2012, 11:51 AM   #144
Chuck W
Chuck W's Avatar
Nice work.
On the cracks on the doors. I think that those are more due to people closing the doors by pushing on the large, mostly unsupported window frame, instead of the door itself. Had to fix a couple like that on my 242 as well.
'80 264GLE - (B21FT-MS'ed/M46)
'97 854 T5 (Eventually to be 5spd)
'77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 07-17-2012, 12:28 PM   #145
volvobrage
Originally Posted by Chuck W View Post
Nice work.
Hmm, that sounds very likelyI tought it was beacuse of somebody smashing the doors shut to hard many times, but your thought is goodAs you say, the window frame is not so stabile on the 242 doors--Maby a combination of the two also?
Old 07-20-2012, 02:22 PM   #146
shaved240
shaved240's Avatar
handling business!
Nice build. Following this thread for sure.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 07-20-2012, 05:26 PM   #147
volvobrage
Originally Posted by shaved240 View Post
handling business!
Thanks:D Im glad you like it
16.07.2012
Throttle from 960, its 2,5 inches..The original 850 I was planning to use are only just over 2"
Washed the parts a little bit, need stronger things on the "wheel"
Do not fit
Drawing for adapter plate!
Thinking something like this..
Old 07-20-2012, 05:28 PM   #148
volvobrage
Cutted in 25mm aluminuA bit rough surface, but that will be fixed
Will be like this..Will weld the adapter plate to the intake manifold
Finished drawing for the exhaust flange
And cutted it outWill redrill the holes with 9,5mm cutted them in 8mm..
Old 07-22-2012, 12:56 PM   #149
rcstdad
Awesome job on everything! I am also quite jealous of the view from your property....
rcstdad is offline   Reply With Quote
Old 07-22-2012, 02:19 PM   #150
Homer
OEMplus++
Homer's Avatar
Regarding the throttle placement. This fits great.
http://forums.turbobricks.com/showpo...postcount=1132
