Old 07-22-2012, 05:29 PM   #151
volvobrage
Originally Posted by rcstdad View Post
Awesome job on everything! I am also quite jealous of the view from your property....
Thanks dude:D The view is at my neighbors place..Our view is even better We live above him and can see even more of the ocean and mountains around!
Originally Posted by Homer View Post
Regarding the throttle placement. This fits great.
http://forums.turbobricks.com/showpo...postcount=1132
Thanks homer!:D That looks greatI will try to find the peaces, if I do I will go for the same solution as you
21.07.2012
Drilled the holes in the exhaust flange
And tested it, it did not fit:p Need to fix the drawing a little bit..
In the back it looked like this(exept from the angle grinder cut)
Cutted away
The start of a new peace
Made it round and started to adjusting it
Finish peace
And on place
Almost finished with all the small welding here and then I will weld the gap all the way
volvobrage is offline   Reply With Quote
Old 07-22-2012, 05:31 PM   #152
volvobrage
Welded in the new peace and grinded
Welded and grinded, but needs the last finish touch
Finished welding here also but need a little bit grinding..The new peace really turned out good!
Welded the other side
And started grinding
Looks like nothing, but this small work takes sooo much time!:p
Old 08-01-2012, 04:32 PM   #153
volvobrage
Picture from moving the car before I left to Turkey on vacationwill stay there one more week!
Not quiiite there but almostLittle bit grinding left
Have been thinking about doing this with the rims!!HmmmmWhat do you guys think?
Old 08-01-2012, 05:16 PM   #154
Pro Sneaker Peddler
Looks awful. Send to me for proper disposal. Soooo sexxyyyyyyyyy
Old 08-03-2012, 03:40 PM   #155
volvobrage
Hahaha didnt see the last part before i quoted it!:p I was going to send it to you but since you seem to like it ill keep it insted;)
Old 08-03-2012, 04:36 PM   #156
TIPSP
Got Boost?
TIPSP's Avatar
paint the white part of the emblems yellow and it will be acceptable.
looks awesome.
82 244T: Modified. (gone)
75 242DL: Modified.
76 242DL: Modified.
Old 08-03-2012, 05:25 PM   #157
550
Those wheels...
wow.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 08-04-2012, 06:03 PM   #158
sn@il
those wheels are so sweet.
sn@il is offline   Reply With Quote
Old 08-04-2012, 06:07 PM   #159
Pro Sneaker Peddler
looks awesome.
Yep, the Bayerische Fahne would actually make the car not look as good
Old 08-08-2012, 06:25 AM   #160
volvobrage
looks awesome.
The emblem are long gone;)Unfortually it broke when i took it of......
Will be the old style volvo emblem there later!
Originally Posted by 550 View Post
Those wheels...
wow.
Thanks guys!:D Glad you like itI like the wheels also..But they will be used a couple of years before I invest in some image or CCW wheels I think
Old 08-08-2012, 06:31 AM   #161
volvobrage
I posted some pics of a ekspansion tank and a oil cathtank I was making for a guy some pages back..They are no finish and mounted on his carHe have also polished them, here is a pic!(I think they turned out awsome!)
Old 08-12-2012, 05:13 AM   #162
volvobrage
Got some parts!Oilpressure sensor
And oiltempsensor
Did the finish job on the weldings here..No they are even and the marks you see I can barely feel with my nails..On the other side you dont feel it so I think its okeyAlso the flange is very straith so I wont bother to take it to the fres(?)..
Made a peace in 8mm alu
Grinded the floorpan, will put the heat sensor her
And weldedNo I need a M10x1 threadmaker before I can put the floorpan on the eninge..
Old 08-12-2012, 09:20 PM   #163
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Snyggt! Gillar bygget skarpt, kommer bli en skitrolig bil.
Bara så du vet:
oljetråg = oil pan
fräs = mill (milling machine)
Old 08-12-2012, 11:59 PM   #164
Homer
OEMplus++
Homer's Avatar
Alex is such a helpful guy.
-Jacob:
2006 A4 - Comfy DD
Old 08-13-2012, 10:25 AM   #165
volvobrage
Bara så du vet:
oljetråg = oil pan
Takk for det Alex!242 prosjektet ditt er ein STOR inspirasjonskilde berre så det er sagtHåper på oppdateringer der ifra snart
Hehe, no veit eg det og!:p Takk;)
Yes indeed!:D
Small updates later today
Old 08-14-2012, 06:31 AM   #166
volvobrage
Drilled with 9mm drill for the threads
Took of everything on the back on the engine and flipped it over
And took of the oilpan and oilpipe
Trimmed the engine mount for the enginefilterbox
Old 08-14-2012, 06:34 AM   #167
volvobrage
Found a m10x1 threadmaker at work!:D
And it fittedThe threads on the sensor are conic
This is from the 850 oilpan, going to make a copy, but 6mm longer
Will be like this with the new pipe
Started on the intake flange..
Found this
Made a nice arc and grinded the welding flat with it
Drilled and made threads in the flange and spotted it on the intake
I think it looks nice when it has the same shape as the intake
Will weld the flange finish today
Old 08-21-2012, 08:03 AM   #168
volvobrage
Welded the intake, was **** alu to weld in so it turned out "ok"
Tok some steel out of the manifoild just for fun
This is going to be put on the wattlink rods, in the end that goes to the body..Im going to use poly from the orginal panhard rod there
16.08.2012
Used m10 bolts and nuts..This way I can adjust after I finish widen the front fenders so I get the look I want
Old 08-21-2012, 08:06 AM   #169
volvobrage
Parts for washing!
Withesprit and diesel
But then I remembered I needed to cut the oilpan here so did that first
Needs a little more grinding
After washing and ready for mounting
Plate in the front with new o-ring
Mounted the oilpipe..Put oil on it first since I flushed it with water after washing
MountedIt fitted also
This tube from volvo kost about 80 - 90 dollarsOrdered it without asking for the price..Used locktite on the bolts also
Starting to look like something
Old 08-21-2012, 08:11 AM   #170
volvobrage
Needed threads in the hole closest to the "oilbox"
Finished
Engine mount mounted
These three holes needed threads on the otherside
FinishAfter making the threads I noticed that the hole to the right in the picture had nothing to do with the engine mount
Here I drilled to fit a m10 bolt instead of m8
Cutted the stearing pin away since I will be changing the mounts after I get lisenceplate on the car anyway
Mounted
Tested the other eninge mount!Fitted very wellHomer is a magician!
Someone knows what this is for?
The engine now..Next I want to mount is water pipe and intake manifold
Got new gaskets for intake and exhaust
And the peaces I made for the wattlink
Old 08-21-2012, 09:26 AM   #171
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
That front bracket is one of the original engine mounts. You can remove it.
Fake Race Car
Old 08-21-2012, 02:45 PM   #172
volvobrage
Thanks karl, will remount it this weekend
Old 09-02-2012, 01:41 AM   #173
volvobrage
Got this for free from a friend, original 240 turbo exhaustWill use this for the test to get the lisensplate for the car and then swap with stainless
Picked up a new radiator!Need some nice parts sometimes to keep the motivation on top
Started on the intake..The car this came from had been run on gas so they had pit some nozzles there..Started to remove one to see if I could fix it
Grinded it good and welded..Just melted it out after welding so it would "blend in"
Old 09-02-2012, 01:43 AM   #174
volvobrage
Finished the intake
Grinded the front plate
Finish welding and grinding
And some temporary paint
Tested the radiator in the car, a guy on the norwegian volvoforum wanted to see..The width is perfect, but need to lower it a bit under the crossover
Old 09-02-2012, 01:45 AM   #175
volvobrage
Fixed the drawing and made a new exhaust flange in 12mmThis time it fit
Got the 3/8 JIC "tool"
Started to do the work in the lathe
Finish result
Made drawings for the throttle ends..Not sure if I will make it in one peace or 5 seperat
Started on a intake for a guy on volvoforum, same operation as mine
