Old 01-19-2017, 03:26 PM   #176
madeRus
madeRus's Avatar
Arch then drank under the fenders! But inversion is small (
then I will increase the inversion wheel, but for now I will not do it!
madeRus is offline   Reply With Quote
Old 01-19-2017, 03:32 PM   #177
madeRus
madeRus's Avatar
We do dry sump crankcase!
Old 01-22-2017, 05:54 AM   #178
madeRus
madeRus's Avatar
bought 4 pieces EGT sensor
http://www.auberins.com/index.php?ma...roducts_id=182
Old 01-22-2017, 06:34 AM   #179
InTheWhite
InTheWhite's Avatar
Now this is a cool project!
Old 01-22-2017, 06:44 AM   #180
madeRus
madeRus's Avatar
Old 01-25-2017, 12:18 PM   #181
madeRus
madeRus's Avatar
We did shafts valves on the basis of family, by welding and milling
Air intake 281
Release of gas 285
Old 01-25-2017, 02:21 PM   #182
Gnomestur
Gnomestur's Avatar
Jesus,this build is insane. what other masterpieces you got laying around!
Gnomestur is offline   Reply With Quote
Old 01-25-2017, 03:21 PM   #183
InTheWhite
InTheWhite's Avatar
Really nice!
Old 01-25-2017, 03:52 PM   #184
madeRus
madeRus's Avatar
got laying around?
Old 01-26-2017, 09:54 PM   #185
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
So sweet
Old 01-26-2017, 11:19 PM   #186
wgusler
wgusler's Avatar
Unreal, I am impressed.
"I had to go get mustard for my cat."
wgusler is offline   Reply With Quote
Old 01-27-2017, 04:52 AM   #187
p18002.5t
spectacular!!!
p18002.5t is offline   Reply With Quote
Old 01-27-2017, 08:52 AM   #188
BDKR
Section 9
BDKR's Avatar
Yeah.. The intra-webz lore has it the early B230 has what TBers call "the 9mm rods"* which are flat scary weenie....and it has a crank with 55mm main bearings which is supposedly terrible and worst of all it has the dreaded "Center thrust bearing" which is guaranteed to ass-splode and kill everybody in 50m radius..
Now if anybody just happened to actually look around they might see plenty of modern engines with main bearings in the 55-57mm range...
And if they noticed that the thrust bearings (these things)
(but not flanged bearings like that, instead like-a dis
loose)
were only 180 degrees per side kinda like you see in the photo RATHER than like this**
which are what old B20, B21, B23, and later B230 have---that is to say a full 360 degrees
then they might begin to wonder if the alleged thrust problems were related to the sting 180 degree design or the lack of 360 degrees---rather than the placement at center or rear..
Shirley, I could not comment myself...
As for where the 16v came from or on, some later maybe just 88-89 model 7 whatever...
* this is in shocking contrast to the just flat absurdly beefy---and outrageously heavy---"M" rods in the early motors and the "only slightly less appallingly wimpy so called 13mm rods" which came at some impossible to say when time in late 89 maybe..
** astute reader may notice the little tang thing stickin out..They may further notice that if there were a little relief ground into the block or main cap that a second set of thrust bearings could be slid home and make a early crank into a 360 degree thrust.. It sure looks super easy..But evidently its impossible to do since none of the Volvo hero shops that have come and gone has ever done it....Then again no Volvo shop figured out how to easily add under-piston squirters in a easy and fool proof way either...So it must be impossible.
Phuking Hell John! You're a fount of information, but who the phuck wants to deal with the delivery???!!!???
That information should be a thread by itself!
For all you Dijkstra fanboys:
Old 01-27-2017, 09:07 AM   #189
BDKR
Section 9
BDKR's Avatar
Originally Posted by madeRus View Post
it was February ! )
The coordinates of the historic center of - 59 ° 57 ' s. w . 30 ° 19 ' in . d
St. Petersburg city is the northernmost of the world's cities with a population of over a million people . City of St. Petersburg is located in the northwest of Russia , within the Neva Lowland , on the adjacent to the mouth of the river Neva shore of Neva Bay and the Gulf of Finland on the numerous islands of the Neva delta. The area of ​​the city - 1439 km² .
Gosh DAMN I would love to visit St Petersburg!
And strangely enough, flights there are pretty cheap compared to say London or Gatwick which is half the distance. $750 vs $1100. And never mind that flights leaving here to St Pete, RU "layover" in Heathrow or Gatwick.
Great build man!
Old 01-28-2017, 07:41 AM   #190
madeRus
madeRus's Avatar
We made a center of the front brake discs
Old 01-28-2017, 07:48 AM   #191
madeRus
madeRus's Avatar
Great build man!
Arrives for a visit! all show! The best in summer
Old 02-02-2017, 03:08 AM   #192
madeRus
madeRus's Avatar
Carter tank dry! (All Feng Shui, 10 liters) made in AMC
(IT COMPANY champion in drag racing IN RUSSIA)
AND THEY STILL DID FUEL REGULATOR
Old 02-02-2017, 03:45 AM   #193
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i likyliky that you made your own centerdisk for floating rotors what material did you make them from?
Oh.. and how mucn is that FPR in euros?
i cant read kyrillic :( but the stuff they make really looks nice.. not overengineered.. more like form follows function
/edit got it.. 100€.. thats killer! could you please check with them if they are willing to ship to europe? and what shipping would be to germany?
Old 02-02-2017, 05:29 PM   #194
madeRus
madeRus's Avatar
steel grade for Europe
ENAW-2117
ENAW-AlCu2.5Mg
I cost is 12,000 rubles
7000 and 5000 work material
Course 65 p = 1 euro
Old 02-02-2017, 05:30 PM   #195
madeRus
madeRus's Avatar
ENAW-2117
ENAW-AlCu2.5Mg
Old 02-09-2017, 04:49 PM   #196
madeRus
madeRus's Avatar
I began to repair the car body!
he in 31 years decayed places!
Old 02-09-2017, 04:53 PM   #197
madeRus
madeRus's Avatar
Old 02-09-2017, 04:58 PM   #198
madeRus
madeRus's Avatar
Hole finished brewing!
Now we do mount a chair!
chair of the Ford Focus RS
floors leveled!
otherwise the chairs got up very high!
Old 03-09-2017, 11:29 AM   #199
madeRus
madeRus's Avatar
I bought a generator for 120 amperes from the LADA Shevi Niva, EGT sensors from Auber and made an adapter to the cardan from BMW
Old 03-09-2017, 11:34 AM   #200
madeRus
madeRus's Avatar
Center self-made of aluminum d16t, disks 330 mm D2Racing
The support rises perfectly
