Old 07-01-2017, 09:12 PM   #126
babbit bearings
I would suggest other Photobucket users download all of your photos before they go broke and you no longer have access.
babbit bearings is offline   Reply With Quote
Old 07-02-2017, 09:36 AM   #127
Texas240
Prius Owner
Texas240's Avatar
I can still see your photos
93 245 LS Engine Swap Project
Old 07-02-2017, 10:49 AM   #128
babbit bearings
http://photobucket.com/pricing
Old 07-02-2017, 10:52 AM   #129
babbit bearings
It will look like this soon.
https://ls1tech.com/forums/conversio...ls3-525hp.html
Old 08-11-2017, 03:34 PM   #130
babbit bearings
So Photobucket won't cut me off immediately because I paid for the storage in advance, I guess they are trying to avoid a lawsuit from paying customers...
Anyway:
The heater core leaked, when replacing it I found the blower motor was worn out... Oh well.
On the bright side, this showed up.
And a fake light, still looking for the bezel for the other side.
I also got the stock shifter to work, including the reverse lights and neutral safety switch.
Still need to finish a bunch of wiring and then find an electric speedometer and try to run it off of megasquirt.
Old 09-02-2017, 06:41 PM   #131
babbit bearings
We had some crappy weather at the house, so my wife decided we should evacuate....
Challenging my rather limited driving ability.
But it all worked ok, pretty much everyone there drinks lots of beer, so I fit in pretty well.
And thankfully even though we got about 40 inches of rain, the water stopped about 10" below getting into the house.
Old 09-02-2017, 06:46 PM   #132
babbit bearings
And wandering around in a slightly sketchy part of Dublin I found a guy to stamp me some EU license plates with anything I wanted. One for the wall in my garage, and one for a very close friend who likes cheesy car movies...
Old 09-02-2017, 08:40 PM   #133
Texas240
Prius Owner
Texas240's Avatar
Thats so coooooool
Old 09-04-2017, 11:37 PM   #134
2fast242gt
Do you have a cobalt?
Mind posting pictures of how you did your stock shifter?
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-06-2017, 08:25 PM   #135
babbit bearings
Not very sexy, but I am tired of dumping money into this thing.
Old 11-11-2017, 05:46 PM   #136
babbit bearings
I couldn't find a reasonable price on an electronic speedometer so I gave up and put in a full display using a Pi & tunerstudio
Trimmed the plastic to fit the 10.1 diagonal screen.
Old 11-11-2017, 05:59 PM   #137
babbit bearings
Only dissappointing setback is the 4l80e pump whines a little too much for me.
Pressures and shifts are perfect, but the whine pisses me off so the transmission is going to have to come out again....
Old 11-11-2017, 07:50 PM   #138
Funkee
Funkee's Avatar
It sounds amazing man, we need more videos of it building boost.
Before you take out the tranny again, sometimes its just a clogged filter (though I assume you thought of that).
Old 11-11-2017, 10:50 PM   #139
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
congrats, see you on the streets.
Old 11-12-2017, 12:38 AM   #140
cosbySweater
cosbySweater's Avatar
What converter are you running? Are you sure the shifter adjustment is dead on?
Old 11-12-2017, 03:33 PM   #141
babbit bearings
Billet triple disc Circle D
The whine is there even if the shifter is unhooked...😟
Old 11-13-2017, 12:41 PM   #142
cosbySweater
I do not recall exactly if this cured the whine, but I had the same issue with mine and this helped, my memory is a tad fuzzy as to if this was all I did but im pretty sure it was a combination of this valve and the shifter adjustment. I had that whine on my 80e as well and it was pretty unbearable
https://www.summitracing.com/parts/s...SABEgLMQvD_BwE
Old 11-15-2017, 09:20 PM   #143
LC4CARL
Aero challenged
LC4CARL's Avatar
I had a front-pump whine on my GM car years ago. My brother-in-law said it sounded like a blower...
#carlfeague on IG.
Old 11-27-2017, 09:05 PM   #144
babbit bearings
I need to find some 15x8 wheels. It looks like with a little trimming on the lip a 26x8.5 ET Drag may fit at stock ride height.
Old 12-23-2017, 04:08 PM   #145
babbit bearings
15x10 - 6.75" backspace wheels + 26x8.5 et drag tire + 1.25" thick adapters clears ok on the outside, but the sidewall touches on the coil spring mount on the inside.
Tomorrow I am going to get some 15x7 wheels from an XJ Jeep, they are supposed to be 5.25" backspace and should pull the sidewall in enough to clear everything, maybe without even having to roll the fender lip.
Old 12-25-2017, 10:09 AM   #146
babbit bearings
Just FYI. Either the internet lied or jeep people do not know how to use a tape measure... the jeep wheels are 15x7, 5x4.5" Pattern but they are not 5.25" backspace, they are only about 4.75" backspace, so with the adapters, they stick out wider than I would have liked. I am going to have to roll the fender lip, but they should still work, on the bright side, zero chance of rubbing on the inside, and the center caps are easy to convert.
Old 01-07-2018, 07:10 PM   #147
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Subbed! Awesome work!!! I like your dedication to non-Chinese junk parts, there is a definite quality difference.
#79WDP
Old 01-23-2018, 09:59 PM   #148
babbit bearings
Finally broke down and bought the missing headlight trim, so it is done. Drove around a bit...suspension is sort of soft compared to my other car and the tune needs some cleaning up but not bad for only a few miles total... The 1-2 shift with the D1 brake and fixed line pressure is a bit harsh even for me... car will definitely be traction limited.
Anyway, the fun part is over... probably time to let go...
Old 02-18-2018, 08:20 PM   #149
babbit bearings
The end.
Old 02-18-2018, 09:53 PM   #150
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Aw, was hoping to see a dyno at least.
Glad to have been able to watch this one.
