Old 11-11-2016, 04:33 PM   #1
p18002.5t
Default One more white 945 T5
My mane is Andreas I grow up all Volvo with my father building and racing Volvos for fia rally and long distance rallying, mostly 544s and 122s but now and again the ode 142 (26 cars built in total). Iv been my fathers gofor and co-driver from the R.A.C (544) to the East African (122) right now my father is building a 122 for the Peking-Paris rally and my brother is building a 242 t5 too.
Volvo runs in the family.
My first car was a 745gl and Iv only every once veered from the beaten path (a G60 passat) for my daily driver. Iv had many a 745 and 945 and a few 850s and then V70 t5s but I wanted to go back to rwd.
I went out a bought a newly built B5234t that was mated to a m90h gearbox and planed to put it in to a P1800, well that never happened and the engine just sat there for years.
After getting rid of my V70 I found my self looking for a RWD car and my friend asked me why I dont just put the old engine in a old Volvo and here I am.
The engine
Block B5234t bored to 2.5 liters.
Every rotating part is from a S60R
Balanced and blueprinted.
Injectors and fuel rail are also R.
Head is ported and has GLT cams.
Apr bolts every were.
Holset HX40 turbo (after tec ) t19 for tec
94 ecu with autotech stage 4 chip
I have no idea that kind of power it will put out but hopefully close to 450 with the Holset and no more than 350 with the t19
I started out with a 945 from 1993 with a 190hp b23 turbo.
In Europe every car built after 19930101 has a form of certification/homologation so to say, this really puts a stop to things when it comes to engine swaps or even rim size in some European countries, the only solution is to buy a Volvo registered prier to 19930101 or you could just Swap engine, gearbox, rearend and the hole brake system.
Most people go for option one and get a Volvo registered prier to 1993 as the technical inspection will accept and pass a 745/945 with a 225hk B5234t engine swap, in fact Volvo has said that its ok.
The Car
Well there is not much to say its white and has 5 doors however it took forever to find a good 945 registered prier to 1993.
It took weeks of looking at one rusty 945 after the other and just when I was going to start looking for an alternative a white 945 registered 1992-12-23 (well some one got them self a x-mas present ) I was the seventh owner however it had been in the family for the last three owners and in very good shape.
Got there had a quick look for rust and found very little, it was lowered with koni yellows and springs and had been looked after even if with the garage re-spray.
Brakes
As for brakes shes getting the R treatment on all four corners hiding behind 18" BBS Nebula
rims.
Interior
S60R seats up front and V70 T5 rear seats
V90/960 Door sides .
Im close to finishing this build so if any one wants to know any thing just ask.
p18002.5t is offline   Reply With Quote
Old 11-11-2016, 04:46 PM   #2
Blowbig
Blowbig's Avatar
Nice. Look forward too seeing more of this.
Blowbig is offline   Reply With Quote
Old 11-11-2016, 04:50 PM   #3
okoye
okoye's Avatar
Post more pics!
Old 11-11-2016, 04:51 PM   #4
p18002.5t
the ONLY rust
The rear end
Old 11-11-2016, 04:53 PM   #5
p18002.5t
Pulling the old engine
Old 11-11-2016, 04:56 PM   #6
p18002.5t
Empty....ish
Old 11-11-2016, 05:01 PM   #7
p18002.5t
B5234t going in
IN
Old 11-11-2016, 05:11 PM   #8
p18002.5t
In order to use the 850 ecu box I had to move the batteri and a 850 batteri fits perfectly..... here!
Old 11-11-2016, 06:03 PM   #9
p18002.5t
random pics of the 68 142..she did the tulip rally this year ....never welded
Old 11-11-2016, 06:16 PM   #10
Blowbig
Blowbig's Avatar
That ratchet strap holding the engine made me cringe.
Old 11-13-2016, 01:06 PM   #11
p18002.5t
Did some work on the air box as things turned out there was a few cm between the air box and the 850s MAF that needed to be filled.
I cut of a section from a 960 intake hose/pipe and it fit perfectly.
Here are some pictures of the 850s ecu box were the batteri used to be.
I have only thrown it in there so to give a ide of that it will look like.
Old 11-13-2016, 04:54 PM   #12
p18002.5t
Im looking schematics for a direkt fire box over load relay ??
If any one has one ....please share
Old 11-13-2016, 05:17 PM   #13
p18002.5t
its hard to hide ones passion
Old 11-18-2016, 01:46 PM   #14
DET17
Reformed SAABaholic
Was that engine a B5244T5 with the 81mm bore, prior to your increase to 2.5L?
Old 11-18-2016, 05:25 PM   #15
p18002.5t
Block is a B5234t...I really dont know what the original bore was but its been bored to fit s60r internals.
Old 11-18-2016, 05:32 PM   #16
DET17
Reformed SAABaholic
Previous owner of the engine/trans did your modified oil pan? Any pictures of how it turned out? I understand keeping them flat / holding oil is a bit tricky.......
Old 11-18-2016, 07:33 PM   #17
p18002.5t
Yes i have been told that welding them can be tricky.
the white block has two parts to it ( i dont know what to call it in english)
When welding the oil pan you should bolt it on to the lower part of the block and then weld it, that will keep it flat.
I bought my engine turn key ...Ill see if i can get some pics of the pan for you next week.
Old 12-02-2016, 06:20 PM   #18
p18002.5t
Time for a update
got two 850 seats free and while i was in there i fished out the rely/fuse box ...
The seats will be used to fit and weld the seat frame so that when the right sets show up it will be an easy swap
As for the rely/fuse box, well the one i was given was so cut up that i felt that it would be easier to just start over.
Old 12-08-2016, 06:49 PM   #19
p18002.5t
The electrics are done, just a few things to do.
Extend fuel line and connect.
Connect oil lines to oil cooler.
Build something to hold oil cooler.
Move oil filter and re-connect.
Build new downpipe.
Hook up shifter to gearbox.
Figger out how to extend or move throttle cable.
Start her!!
Old 12-12-2016, 12:30 PM   #20
p18002.5t
Started of with a original 850 relay/fuse box
This is what it will look like after you hack away at it.
this is what the relays look like.
Fuel relay (GREEN) 103
The pink wire gos into the 945 relay/fuse central, just after the original fuel relay and get spliced into the original pink wire that feeds the fuel pump(s)
The yellow/gray wire is the signal from the ecu (contact B27)
Blue/red wire is the power source
black is earth
Overload relay
Power in from red wire via fuse 8
look closely at the middle left contact it has two blue/red wires...one gos to fuse "one" and then on the the ecu (A12) the other blue/red wire gos into the 945 electrical center and I hooked it up to fuse 13.4 (thats fuse 13 out on point 4)...why because these blue/red wires power the ecu and they need power on start and run (position 2 and 3 on the key)
the blue/red wire coming out of the top of the relay gos to fuse 3 that is bridged to fuse 2, fuse 2 out going is blue/red and it feeds the fuel relay (green to the left) ..NOW fuse 3 is also bridged to fuse 4.
fuse 4 out going is blue/red and that feeds the ignition coil !!!!
Black is earth.
this might help some one in the future
Old 12-15-2016, 12:47 AM   #21
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Cool! Looks tricky
'91 744t...it's fast as phuck
Old 12-15-2016, 06:21 AM   #22
p18002.5t
Originally Posted by Wilford Brimley View Post
Cool! Looks tricky
It was ...but the hardest part was leaning how to read the schematics and then finding out were to hock up the power ...it only toke about 100 hours to get my head around it and after i grasped the concept it toke about 4 hours to connect everything.
Old 12-15-2016, 01:28 PM   #23
p18002.5t
More progress.
The oil filter on the t5 engine is right were the swaybar is located, it actually hits the swaybar.
There are a few solutions, one is to try to find a swaybar from a 760 but those are about as easy to find this days as rocking horse poo, one could go all Sellholm but that is really really over the top.
So i bought a oil filter adapter and holder, that way i can move the oil filter from the engine and put it next to the oil cooler.
pics to come
Its geting really close to start up ...tomorrow Ill weld the downpipe and 850 cat (for tec inspection ) after tec I will weld the 200cell cat back on.
Monday we will fit the oil cooler and oil filter will get moved.
Still have to sort out the fuel rail and fuel line extension but that should be done asap.
Old 12-20-2016, 04:03 PM   #24
p18002.5t
Fuel rail done.
I modified the original fule rail.
before.
After.
We welded shut the original fuel line in and drilled a hole strait in to the fuel rail using what was left of the original in line, threaded it and poped the fancy stuff in
Old 12-21-2016, 02:40 PM   #25
p18002.5t
Here are the pics of the oil pan ....a bit later than promised.
