Old 08-07-2017, 11:47 AM   #1
matt b
Default 1965 "Race Car" Amazon
Lofty title for a car that will essentially have a mild drop, a set of IPD sways and some shiny bits but hey, it's fine......
As it sat with the PO:
s-l1600 (17)
Name of the car comes from the fact that this is Amazon #4 for me and I needed to differentiate it from my 4 door black on red Amazon (currently listed for sale).
Back story: bought the car sight unseen out of the Bay area (Richmond, CA) on Ebay. Seller was mildly honest in his description, and even that is a stretch. Passenger side upper shock had sheared off, no mention of that. Car was on 3 shocks, engine and trans were resting on cross member/engine subframe with only the transmission mount sitting in its place. There was rust, far more than was disclosed (trunk area on passenger side, floorboards, etc...)
s-l1600 (12)
s-l1600 (1)
Took the car to a local restoration shop I trust and had them replace the rusty bits.
output-2
output-1
imagejpeg_0-1\
output
The car came with a ton of spare parts, almost all in very good condition. I sold some, kept some and decided to run some of the parts I had here on it.
B20, M41, Classic Swede suspension package, IPD sways, etc....
s-l1600 (7)
s-l1600 (8)
More to come... This one was purchased on mid May, it needs to be my daily by Labor Day weekend (1st weekend of September). It knocked off a solid month with travel and other commitments this summer, so I set myself roughly 30 days to knock it out. Should be fine, this isn't my first Amazon.
Old 08-07-2017, 01:11 PM   #2
Jack
junkman
Jack's Avatar
that's an M46
looks like a good projects, hope you didn't spend too much
Old 08-07-2017, 01:22 PM   #3
LC4CARL
Aero challenged
LC4CARL's Avatar
Neat. What's on the door?
Built-not-bought: PDXdl Resto-Mod.
#carlfeague on IG.
Old 08-07-2017, 01:42 PM   #4
PCH
Originally Posted by matt b View Post
s-l1600 (17)
Interesting vehicles in the background too.
Old 08-07-2017, 02:14 PM   #5
Jack
junkman
Jack's Avatar
better pictures on the auction.
http://www.ebay.com/itm/1965-Volvo-O...p2047675.l2557
Old 08-07-2017, 02:43 PM   #6
matt b
that's an M46
M46 is listed for sale, I won't be using it. Ian went through an M41 for me last year, I'll use that. Spent more than I would have liked given the condition of the car but I am able to use parts I had before this car, I get good rates on work done locally (body shop and machine shop) so all in all, this one won't break the bank.
Old 08-07-2017, 02:44 PM   #7
matt b
No clue, they were some oddball vynil cut outs that didn't look great, weren't centered properly and took away from the car. They went quickly. Heat gun + my 5 yr old, it took 10 mins to get them off.
Old 08-07-2017, 03:00 PM   #8
matt b
IMG_6227
IMG_6225
Engine subframe needed love. I used a spare that had been cleaned and powdercoated.
IMG_6216
Ignore the painter's tape, it's to remind me to finish stuff for that particular part (bleed brakes, align front end, etc...)
IMG_6217
Need to tack the inside of the door, looks like it has split in 2.
IMG_6221
Decided to give the Lowe's window flashing insulation a go, especially since Dynamat isn't cheap.
IMG_6222
Engine is a fairly basic B20B that I grabbed from an estate sale a year or so ago. Had a local machine shop go through it, fresh bearings, checked head, etc.... Oil pan is off while I install gaskets and accessories.
IMG_6223
Using BMW wheels (true 3 piece) I grabbed from Keysar some years ago. I had them on my 4 door but I wanted to keep them. Adapters, some trial and error and Voila.
IMG_6228
And that's mostly it for now. Trying to get better about documenting the builds on these cars, I figured a thread might help.
I'll keep plugging along. A 1959 Volkswagen Beetle is slowing my progress right now.
Old 08-17-2017, 04:07 PM   #9
matt b
Another day, a little progress.
After a whole lot of shuffling, waiting on suspension parts or trying to get the parts from Classic Swede to work, I opted to get the engine and transmission in the car.
I'm weird about working on dirty cars, so I pulled the car out and gave it a quick bath.
IMG_6314
Engine was gone through by a local machine shop I use a lot. It received a fresh coat of the Volvo red used on redblocks and a few other clean up items.
IMG_6312
IMG_6313
Matched up the rear main at a local seals and bearings place and installed it.
IMG_6315
Opted to install the flywheel and clutch but didn't notice that I had grabbed some old bolts from the PO that were not grade 8. One bolt could not handle 20 ft lbs....
IMG_6321
M41 ready to go
IMG_6324
Ran wires now to avoid fighting that once the trans was installed
IMG_6325
Engine jumped in the car, no work at all
IMG_6335
Then the accessories and other bits started going on. I had issues with heat soak on my previous carbs so I opted for some plates on these
IMG_6338
But not everything wants to play nice, most of that contact will be fixed once I tighten everything down.
IMG_6344
Header was of course way off in thickness when compared to the intake manifold from Redline. I had the header coated to avoid seeing rust again.
Other complaints about this set up from before was access to the oil filter. I had been dragging 3 remote filter kits for almost 10 years after a client cancelled his order. Finally put one to good use.
IMG_6342
IMG_6341
I'll need to attach the lines to the fender to avoid rubbing through a brake line:
IMG_6343
And that's how it sits for now. Waiting on exhaust hardware, some random studs, nuts and miscellaneous gaskets that I forgot to order. This one will also get a one wire alternator, it's a simple mod and works well.
Old 08-17-2017, 04:56 PM   #10
kyle242gt
Subtle as a V8 544
kyle242gt's Avatar
Very pretty stuff!
About the oil filter setup - I guess longer lines aren't really a negative, but couldn't you shortcut some of that? Or is it just using the premade lines? And is being that close to the header going to be a problem?
Always neat seeing someone do stuff right instead of the junkyard hacking I perpetrate.
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
I built a 5.044! Then EJ-swapped a Sand Rail
Now playing with MSD Atomic EFI
kyle242gt is offline   Reply With Quote
Old 08-17-2017, 06:59 PM   #11
matt b
Manufacturer says no turns smaller than 5 inches in radius, which limits me. But I agree, it would look much better without the massive bend up top. I may run another filter mount instead, with inlet and outlet being on the side and not the top.
Old 08-17-2017, 07:12 PM   #12
Jack
junkman
Jack's Avatar
If you want shorter oil lines use more AN fittings but you can do that once it's all done
What size carbs? 45 or 40?
Where did you get the heat shield plates ?
What header are you using? There's a bunch on eBay but I don't have any experience with them
Keep up the good work
Jack
Old 08-18-2017, 09:52 AM   #13
matt b
Jack: headers are old 4 in 1 IPD headers that Greg (Keysar) sent me. He had them on his 142, I believe. 4 door car has the Patriot header. Summit carries that header P/N: PTE-H4850
Heat shield plates are from carbsunlimited.com, I'll have to either trim and bend the edges though. Both plates hit.
I'm running 40's on this car, some dude in CA bought my 45's.
Old 08-22-2017, 08:42 PM   #14
matt b
Slow progress this week since I have to focus on exports and finding the cars needed there.
Did fix the driver's door and installed new rubber all around. PO apparently included some 140 door scrapers which won't fit the 130 so I'll need to source those before I can say the door is done.
IMG_6428
IMG_6429
IMG_6427
Some of the guides in the door had broken off, causing the window to rattle.
IMG_6423
Bled the brakes, got to the last calipers and found out that even with 60 lbs of air pressure the thing was clogged. I have some rebuild kits and I'll rebuild it when I have a few hours to spare one evening.
IMG_6401
IMG_6402
Despite assistance from Dai, a shock is seized and won't budge. I've tried to get it to move but it will need to get pulled apart in order to see why it's seized. Until then, I'm running some KYB oil shocks. Good travel, they usually hold up well and the car should be comfortable with them until I get the GAZ units figured out.
IMG_6399
Old 09-14-2017, 03:47 PM   #15
matt b
It's all fun and games until a mistake is made.
Long story short, got the car buttoned up and ready to head down to the upholstery shop for a headliner. This was thanks to some massive help from Ian, JohnMC and a few others who chimed in on a no spark issue I could not figure out.
Even after figuring that out, the engine was having issues (odd noises, etc...) Shop I've used in the past took a peek at it: low compression on 3 of the 4 cylinders. What's really odd is that the engine was rebuilt, I never suspected anything would be wrong with it.
So, look like I'll be running a spare engine I have for now while I get this issue figured out with the machine shop. Bummed, I was hoping to have this thing done and running around 2 weeks ago.
Old 09-14-2017, 04:43 PM   #16
How low is the compression?
DCOE's have an accelerator pump jet for every cylinder. This can wash the oil from the cylinder walls making it difficult for the rings to seat on a new engine.
Old 09-14-2017, 05:36 PM   #17
matt b
Cylinders 1 and 2 have 120 psi. Cylinders 3 and 4 have 60 psi. Valves were so misadjusted on those two cylinders that they had no compression at first.
I do have a spare block that came with the car, rotating assembly is in it and untouched. I'm tempted to roll the dice and run it, with a head that has been milled. It's basically 3-4 hours of my time to swap engines, it seems worth a shot.
Old 09-14-2017, 05:43 PM   #18
matt b
Come to think of it, I'm not sure that the shop ever pulled the pistons on this engine. I think they pulled the head, checked cylinder walls and re-assembled it that way. That would point to a head issue. But the other problem is the whining that we're hearing, which seems to come from the front of the engine. Here is quick video:
https://youtu.be/0rcWRJJ7tY8
Old 09-14-2017, 06:25 PM   #19
cwdodson88
What cam gear did you use? New retainer? New thrust washer? To me it sounds timing gear or alt/water pump bearing whine.
The Build Thread
SVEA - PUSHROD TURBO!
Old 09-14-2017, 06:49 PM   #20
matt b
I don't think the alternator is the culprit.
Either way, I'll run it down to the machine shop tomorrow and will let them touch it. They want to do a leak down test first before pulling the head. Works for me.
Old 09-14-2017, 11:19 PM   #21
cwdodson88
A leak down won't tell you what's whining. I'd be looking into what's causing that as well, not just the low compression.
Old 09-15-2017, 10:48 AM   #22
matt b
Yes, I'm heading there in a few minutes. I grabbed a couple of videos of the car idling and the whine is hard to miss.
Old 09-15-2017, 10:51 AM   #23
matt b
I'm 99% sure now that they re-used the retained and thrust washer. Water pump is new (Volvo OEM) and felt smooth when I installed it. No excessive tension on the belt, and alternator is quiet (I swapped it out to rule that out and it didn't stop the whine)
Old 09-15-2017, 11:01 AM   #24
cwdodson88
Run it for a second with no belt, but I'd guess that whine is cam gear, either too much play, unmatched set, or it's missing something.
Old 09-15-2017, 02:48 PM   #25
classicswede
Volvo upgrades
Nice thread, looks like a lot of set backs at the moment. Drop me a message so we can see what we can do on sorting that shock for you if the advice from GAZ has not worked
