Old 12-06-2019, 03:40 PM   #1
Wesdunns70t5m
Default Rear windshield trim removal
Hey there all, so the car in question is a 1990 760 sedan...
This morning I bought rear windshield louvers for the car off eBay, and am very excited to get it installed once it arrives! In the description of the item, it claims to install underneath the existing trim. Of course Iíll add some double sided tape for security, but I was curious as to how do I remove the trim around the rear windshield? Is it as simple as sliding the trim piece in towards the center of the glass? Iíve had bad luck removing trim from these old boxes before, so I just want to get a head start before I even get the item. Thanks in advanced!
Wesdunns70t5m is offline   Reply With Quote
Old 12-06-2019, 03:44 PM   #2
You're doomed!
Old 12-06-2019, 04:32 PM   #3
Wesdunns70t5m
Aren’t all of us who own a rwd volvo?
Old 12-06-2019, 04:51 PM   #4
DD Ranch
DD Ranch's Avatar
The louvres I had on my 142 had tabs that slid underneath the rubber seal and hence the trim. Therefore no need to remove it.
Perhaps that is what is meant?
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 12-06-2019, 04:57 PM   #5
The 740/760 has aluminum trim that fits tight against the body shell and the glass. I have no idea how these louvers would be attached.
Old 12-06-2019, 05:01 PM   #6
DD Ranch
DD Ranch's Avatar
Well! You learn something every day!
Old 12-06-2019, 05:41 PM   #7
He's doomed!
Old 12-06-2019, 07:32 PM   #8
Wesdunns70t5m
Thanks for the input all. Hopefully it will just slide under the trim without any trim removal. If that doesn’t work out (which redwood doesn’t make it sound like it will), I’ll just sand it down so it butts up to the trim and double side tape it. I’m not against rigging something, but will try not to when I can
