Right. I should have been more specific about my current setup and what I'm aiming for.
The car is a 96`, originally auto with a 13c turbo and LH2.4.
Trigger system is crank (60-2 on flywheel I think) and an empty distributor.
Current setup -
531 head, 16t on a 6cm straight exhaust housing,
2.5" intake, large IC from classicswede
3" DP, cat delete, 2.5" to a single muffler from a 4.6L Jeep,
380cc (at 3bar) inj + FPR set to 4bar (effectively yielding 440cc), 255 in-tank walbro
EZK + ECU chips scaled to 440cc
MBC, AEM Wideband O2 with analog logging
Manual 5 speed transmission (Type9 from a Ford sierra ... stop laughing)
Welded 4.1 rear axle and a bunch of suspension stiffening stuff.
Moare unrelated goodies (oil cooler, oil filter relocation, air filter, etc, etc, etc)
Currently used for -
This has started out as a car to learn going sideways, properly.
It has turned out to a test bed, i'm basically trying out all kinds of stuff with it, and learning a lot.
Make no mistake - it's a runner, and I am keeping it that way. No matter what am I experimenting with.
Aiming for -
I want to develop my engine management and tunning skillz on that test bed.
Continue going sideways.
But mainly, I want to teach myself engine management and tuning A-Z.
Right now I write code for living and play with cars for fun. I try to leave no stone un-turned while I'm at it. I like getting down to the bits and bolts of every aspect of whatever it is I'm currently fiddling with in the car. Sometimes to a ridiculous level of researching the living **** out of everything.
I hope to do cars (electronics, software and even mechanics) for living and fun.
So, I will end-up experimenting with more than one EMS, on that car, as I progress, eventually.
But, I need to start somewhere.
For the first system I want one that has as much community support as possible, as much docs as possible, as user friendly as possible and so on and so forth.
Thank You for your time and wisdom TBers
