Alright so as long as I had my 1997 945T, I have to manually excite the alternator after starting the engine by pressing a button that was added some time ago from the pre-pre owner.
It's just a wire coming from the battery + terminal, through the button and going to the alternator D+ terminal.
Just a quick push and the ABS and SRS lights go off, which then tells me the alternator is charging (they keep lit after starting until I press the button). I can feel the alternator starting up because there is a noticeable short dip in the idle speed.
The battery light goes out as soon as the engine starts though, even if I didn't press the button yet, which is weird maybe?
It seems there is a bad solder joint somewhere I guess? I don't really know much about the cluster, so could anyone help me out or lead me in the right direction what I could do?
I've had a look at the wiring diagram and found that pin 22 on connector C2 is the D+ wire going to the alternator, but it doesn't say where it comes from the cluster going to connector C2.
Thanks!
Thanks!
