corivus
Hey Shiny!!
- Aug 19, 2004
- Tempe, Arizona
You guys will have to forgive me, I'm not great at telling stories so this is kind of a short history of what has happened with this car.
Current up to date modification list:
OG RSI Stage 2 Cam, this basically is the stage 3 cam from RSI
K24 Turbocharger reclocked for RWD use
660cc Ford injectors with EV adapters and injector hat adapters
3" Intercooler Piping
Knock-off HKS SSQV BOV
E-Fan conversion
Thelostartof EZK/ECU Chips for ethanol tune
Innovate LC-2 Wideband setup
Full 3" Turboback exhaust with magnaflow mufflers and performance cat
Provent 200 Oil seperator, fully replaced PCV with oil return
Electric Pusher fan wired up to fire when the a/c turns on
Eibach lowering springs in the rear Cut springs in the front
HDI Electronic Boost Controller currently set to 5psi
20 gallon gas tank
940 Gauge Cluster
Maintenance Stuff:
New Oil Cooler, switched to water cooled oil cooler
New Alternator
New Starter
New Ignition Switch
New LH 2.4 Harness
Heater Core
New Evaporator
New Condenser
New Accumulator
New Orifice tube
New Bushings for all Accessory Items
Stock Exhaust
Eibach Springs in the rear
****ty Rattle Can paint job on the hatch
Replace Rear and front suspension (To Do all parts aquired)
Replace cut springs (To Do)
Future Plans
CD009 Install
More boost
Ported head
Custom intake and exhaust
Profit
So I figured after almost 3 years of ownership its time to post this slow build that has been slowly building up into something worth posting. I traded this 740 for my old 850 as I needed something simple and a bit more reliable(I know I know ) and I wanted rwd. This seemed at the time to fit the bill and was straight and clean mostly...
Original Setup:
660cc ford racing injectors
MS1v3
Custom IC Pipe made by JAO
E-Fan Pusher for a/c
Vac Pump for climate bellows
M46 Swapped
Manual Boost Controller
The first couple of post are around the time that I decided to go ahead go through with the trade so some of the photos are from the PO.
Exterior photos
Made a trip over to thelostartof's place and had the stock exhaust added back on since it just dumped out of the downpipe since the old exhaust fell off, sounded like poop at that point but after the new exhaust was on it was much better.
This was the MS1v3 setup and all its wiring glory, I stepped on it a few times and got annoyed chasing down the wires I unplugged so I decided I would need to fix that eventually.
Interior pictures
Now in order to use the electronic 5th gear the switch was wired into the seat heater switch since no seat heaters where installed. This is fine because I was planning on swapping out the m46 anyways after reading multiple threads about them not holding up to real power.
Back to the interior pictures.
So I decided hey thats not so bad it needs to be cleaned up but my 850 isn't in the worlds best condition so lets do this. So the PO drove it to me and got ready to drive off with my car. Looked it over and everything seemed good so I went and got it washed and pulled the Hydra's off. I really don't like them so I sold them to someone on facebook.
Driving home and hearing a loud grinding and suddenly I can only go 10mph...
https://www.youtube.com/watch?v=f96-pHYVHPw
So about 2-3 weeks into ownership M46 blew up but didn't know it yet. Because I figured it was a clutch or pressure plate since he said those where in bad need of replacement. I'll try and dig up the photos of the transmission carnage. Sold off the overdrive to someone local so they could get themselves back on the road. Ended up searching for a while to find a m46, found a local option but it was trashed after some searching I found one on the tb forums that fit the bill of being affordable after shipping. At this point it was time to get it up in the air and get some eyes on what was going on with it exactly.
Pulled the transmission and got some video and pictures of the carnage, for some reason I can't find the video so pictures of the carnage will have to suffice. When rotating the assembly it was very apparent that this m46 was not useable. The bits of gears that I shook out initially was maybe 1/4 of what came out once I took it apart to sell the overdrive to someone.
Overdrive out and ready to help someone else get their volvo on the road.
Ordered a clutch and pressure plate kit online and while waiting I decided to do a couple of things. First task was to get rid of the rats nest of wires that was sitting in the foot well. I thought this worked rather well, no visible wires and the MS1 box sat in the glovebox. I decided to make a box to hide all the wires that just went all over the place.
Years of AZ sun had destroyed these seats till nothing was left and the foam was crusty so I started scouring junkyards for proper seats and found a v90, got the DS seat out but had to come back with a battery for the other seat. They ended up crushing it that day so no PS seat for me
After some back and forth with a few different things I got it back on the road and driving. At this point it still had an issue where it would sometimes not start after running for more then 10 minutes. I did find out that I could push start and it would drive, this worked ok for the most part but really sucked in the summertime.
Then I decided maybe I should put in a t5 if its going to put down power because my goals where to keep up with some of the other faster volvo's here and my other friends who ran much faster newer cars.
Just kidding hope its new owner will use it, before I got the chance to install it fully (it sat for a long time all put together) DeeWorks announced that he was going to make a CD009 adapter, and yoshifab also announced they were doing a driveshaft adapter so the only thing I needed to figure out was the shifter. After reading about the power a stock unmodified CD009 could handle it was a no brainer to make the switch.
Drove it like this for a bit but still having issues with no start while warm but it hauled things when left running just fine.
Got a set of ecodes locally that needed some work, honestly I might just order a new set and use these to experiment with. Wired them in but did not have the adjustment options as the gears were kinda destroyed, if I can find a set that I can scavenge the gears from or just move the hardware to I might do that. Light spread is meh because its not pointed right but it looks alright.
We(TLAO) ended up switching it back to LH 2.4 with some thelostartof chips for EZK and the ECU on a "what if" kinda thing and all the issues with no start, hard start went away pretty instantly. Setup my wideband to feed a narrowband signal to LH and that was that.
For Christmas of 2017 I got a wash and wax kit so what did I do? I Washed and waxed that thing up and drove it some more. At this point I was really loving the car it was running great, no cold start issues and I just put more and more miles on it.
After driving home from my sister in laws I heard a dragging noise.... stopped and found this yay the remote oil cooler was leaking badly so that had to go.
I ended up just removing the whole remote oil cooler setup and swapped to the stock oil cooler setup which used coolant. This also freed up a TON of space in the engine bay. Again I just kinda drove the car around like this collecting parts to eventually upgrade the car.
About 7 months ago I started having issues where the coolant would get over pressurized so I performed a exhaust gas test in my coolant and sure enough it was there. Originally I was going to just do a head gasket on it eventually but things got super busy at home. So I took the 740 over to thelostartof to have him do some work on it. This ended up turning into doing some upgrades and the 16t and t cam got swapped out along with the stock exhaust in favor of the full 3" exhaust.
I'll post more later but that's where I am at with this, a lot of the heavy lifting was done with the awesome help of thelostartof. I may be forgetting some things but I'll update this post later with more showing how I got to where I am now.
E-Fan conversion
20 gallon gas tank
940 Gauge Cluster
Maintenance Stuff:
New Alternator
New Starter
New Ignition Switch
New LH 2.4 Harness
Heater Core
New Evaporator
New Condenser
New Accumulator
New Orifice tube
Stock Exhaust
Future Plans
CD009 Install
More boost
Ported head
Profit
Original Setup:
MS1v3
M46 Swapped
Exterior photos
Interior pictures
