Old 03-29-2018, 06:09 PM   #1
71142volvo
71142volvo's Avatar
Default 142s split shaft or 1pc
I'm putting in a T9 tranny shortly. Is the split 2pc drive shafts needed or can I replace with a 1pc. Any thoughts and comments would be appreciated...especially if you've done this.
Thanks
71142volvo is offline   Reply With Quote
Old 04-03-2018, 11:19 AM   #2
AndrewNance
Amateur hour!
AndrewNance's Avatar
I don’t see any reason you couldn’t use either one. I swapped to a 2.5” one-piece in my 122 and it’s great. It will move more with suspension travel so just make sure you have the room for it.
Any good driveshaft shop should be able to either mod your two-piece accordingly or make you a one-piece.
'71 142
Feedback
Old 04-03-2018, 11:29 AM   #3
If staying with the 2 piece, you may want to get the larger flange for your pumpkin and convert to a 2" prop, and lose those problematical small U joints especially if you're planning on adding more power.
Either a late 140 EFI prop, and or a 240 prop will probably work since the chassis layout is the same.
Old 04-03-2018, 11:37 AM   #4
JohnMc
JohnMc's Avatar
I put a 1pc in my 240 (with a T5) and clearance gets a bit iffy since the whole length goes up and down, pivoting at the end of the trans.
I also have some nasty vibration issues in my drivetrain (16V B230FT, 15 lb flywheel, T5 trans) that showed up when I put some poly torque rods in, not bad with stock rubber bushings though. I'm unsure how much of that is related to the driveshaft though.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 04-03-2018, 12:06 PM   #5
Dunno when they went to the larger tunnel, 73? and if the back portion ever changed as well?
hiperfauto would know if anybody does.
Old 04-03-2018, 01:55 PM   #6
Tfrasca
Tfrasca's Avatar
I think the change involved a different center bearing and support. The early tunnel won't fit the later style center support. You might be able to find a different bearing that fits on the late 140/240 driveshaft, but still accepts the early support. If you have an early 140, that is.
Old 04-03-2018, 03:42 PM   #7
The tunnel and carrier bearing/bushing was enlarged in '70. His car is a '71 so the large driveshaft is a bolt in.
I've done research to see if there's a bearing that will allow the large driveshaft to be used with the small bushing and there isn't.
Old 04-04-2018, 07:17 AM   #8
71142volvo
71142volvo's Avatar
Thanks everyone! So, I'll be able to install the 1pc with no problem Ian?
TY
Old 04-04-2018, 09:56 AM   #9
gsellstr
gsellstr's Avatar
I had a 3" 1pc in my 74, only issues were the bolt for the seat belts and the e-brake cable routing. Depending on ride height, the bolt may not be an issue. Dropping the e-brake cable hangers was easy enough as well.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
