Old 04-19-2018, 04:26 PM   #1
milmatoro
Question No injector pulse on volvo S70
My volvo s70 has no injector pulse. The problem started when i replaced the turbo due to continuous smoking.
On my trouble shooting, i have spark, good fuel pressure, crank sensor seems oky i can even read the rpm on the engine on OBD2 scanner.
The vehicle would start for just 2 seconds and shut off. I therefore removed the fuel rail with injectors attached then cranked the engine, i saw that the injectors would just spray fuel once, thus one full cycle and stops. Hence starting for just 2seconds. I then grounded the pulse wires to the injectors then they all sprayed. To me it was an indication of good fuel pressure.
I am suspecting the ECU because i tested for continuity on the pulse wire from ecu to the injectors and it was good.
Who anyone help me with a different opinion at solving the problem at hand.i am now clueless.
milmatoro is offline   Reply With Quote
Old 04-19-2018, 04:29 PM   #2
milmatoro
I forgot to mention that the injectors have got constant 12v power supply. Anyone who might have encounted such a problem please help
Old 04-19-2018, 09:07 PM   #3
kampman
dunning-krugersquirt
What year? You might have tripped the immobilizer.
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
kampman is offline   Reply With Quote
Old 04-20-2018, 12:59 AM   #4
gsellstr
gsellstr's Avatar
Cam sensor. The crank sensor determines engine speed but the cam sensor is used for injector sequencing during startup. Common failure with age, won't necessarily throw a CEL.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 04-20-2018, 11:11 AM   #5
milmatoro
It's 1998 model Volvo s70.
Old 04-20-2018, 11:27 AM   #6
milmatoro
That could be true, I will have to take out the cam sensor and replace it.
Old 04-20-2018, 04:02 PM   #7
Or test it first. Spend your money on tools instead.
Old 04-21-2018, 08:00 AM   #8
milmatoro
Any idea on how best to test it, or the most appropriate testing method
Old 04-21-2018, 08:35 AM   #9
tryingbe
Boosting along.
tryingbe's Avatar
Did you test the fuel injector relay near the radiator fan relay?
85 GLH 367whp
00 Insight mpg > yours.
Old 04-21-2018, 01:05 PM   #10
milmatoro
I am not sure if that is the fuel injector relay grey plastic in colour and that is were the fan is also connected.
As it stands I have not yet tested it if thats the one your are referring to, over snd above that my fan is not kicking on when I am cranking like it used to be. if that grey thing is the relay, it might also be a root caur of my problem.
Old 04-21-2018, 01:16 PM   #11
The oscilloscope is my preferred tool. My Hantek scope was $80. Instead of spending $30 on fuel and sweating in the junkyard, one could test the sensor.
Another test method uses the multimeter: measure resistance and look for an open or possibly some huge amount of resistance.
Or try your luck with an LED test light. I would expect blinking, or a solid green light (depending on you light).
What is a logic probe?
Google fu:
http://www.aa1car.com/library/crank_sensors.htm
Old 04-23-2018, 12:34 AM   #12
milmatoro
I will update you as I try all your tips
Old 04-23-2018, 11:36 AM   #13
You also TEST the wiring before replacing a sensor.
Old 04-24-2018, 01:33 PM   #14
milmatoro
Thank you. I will try and work on it this weekend.
