Rusty_ratchet
- Apr 14, 2015
- Southwest
1997 Volvo S90
The fuel tank filler neck (Volvo p/n 3531814) is leaking. The small diameter section of the part connects to the tank some distance away from the inspection plate. The hose clamp for the small diameter section is pointed so that I cannot access the bolt. I don't see how I can replace this part. Any suggestions?
The part (3531814):
The broken part in situ (note small diameter section veering off to the right):
Small diameter section connecting to gas tank. Bolt does not appear to be accessible from inspection plate.
The part (3531814):
