I.M. Weasel
- Sep 21, 2011
- Driving the No Malarkey Bus
You might want to brace that up, all that jiggling might affect the floats and needles.
Idling on gravity feed, started up no choke, no starting fluid first time. I have to work on my fuel system, for some reason I'm not getting fuel anymore even though my pump is on.
^this
But at least it started, idles nicely considering it has four individual carbs.
Also, have you considered going mechanical fuel pump? Just like on my B21A? Or these K-Jet cars don't have a machined cam on the aux shaft? Fuel supply would be pretty easy then, reliable and oem.
Nice work!
So..... what was up with the ignition / dist timing? Gonna leave us with no explanation after pages of back & forth over that ??
There is no explanation, I bought an adjustable timing light but I haven't touched it since the last video (which is, think, one tooth down from factory setting). Everyone keeps telling me different things about the proper aux shaft location. Now that the car will idle on its own, I'm going to reset the timing to factory greenbook specs (44 teeth down from the cam TDC mark, or the white line on the timing belt) and go from there with my timing light.
^this
Something else to think about is getting a 4 port mercury stick or Vacuum gauge set so you can balance the carbs. This will improve the idle and the throttle tip in will be nice and smooth once you have things jetted right.
There should be a vacuum port you can plug each line into the then a screw with a lock nut to adjust the vacuum seen at idle. See if you can find the procedure for whatever bike the carbs came off of.
