Old 03-30-2017, 12:09 AM   #51
Default Wrong Coast Alert...
Complete b230ft swap $100!!! - Folsom, ca
Old 03-30-2017, 07:44 AM   #52
Volvling
Originally Posted by PromiseRing View Post
No. You can buy a parts 940t/740t for under $500.
Not where I'm at, cars for that price usually have almost 300k..
86’ 244 DL (Unknown Issues)
87' 244 DL (Stripping Parts Slowly)
89’ 244 DL (Runs Half-Assed)
92' 244 DL (Sold To A Friend)
03' GMC Sonoma SLS
Volvling is offline   Reply With Quote
Old 03-30-2017, 07:44 AM   #53
Volvling
It says it's a broken link
Old 03-30-2017, 08:37 AM   #54
mopar318
mopar318's Avatar
Not (usually) around here. I've only seen one 940t in my whole life and it's the parts car I bought.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 04-10-2017, 11:12 AM   #55
Volvling
So I found out the engine does not come with the ECU so I was wondering what a good price for an ECU is and if I should just get a Gold EZK instead
Old 04-10-2017, 11:23 AM   #56
Post in wanted and find out.
Old 11-20-2017, 05:08 PM   #57
Volvling
Hey all. Update. So I’m just going to go straight to 16v, so far I have 3 16v heads and I now have my Volvo molded Hx40. It’s slowly but surely coming along.
Old 06-18-2018, 09:10 AM   #58
Volvling
Parts Update:
- B230FT from a 1995 940T
- 3 16V Heads
- 16V Timing Belt Adapter
- 16V Upgraded Springs
- 16V Exhaust Adapter
- 16V Auxiliary Shaft Gear
- Yoshifab Intake Manifold
- Yoshifab 4 Channel Ignition Module
- Volvo/Holset HX40
- Volvo 90+ Tube Exhaust Manifold
- Volvo 850 Throttle Body
- Volvo Cam Bore Plug
- Microsquirt ECU W/Harness
- Siemens Deka 80lb Injectors
- 3Bar Map Sensor W/Connector
- Iat Sensor
- Denso Pencil Coil Set (Used)
- Denso Pencil Coil Connector
- Ev1 Injector Connector
Old 06-18-2018, 11:27 AM   #59
Nice list. I think the "doing it all at once" of course keeps wrenching time to a minimum, but if there is a problem you may not know where to start.
