Old 01-16-2018, 11:50 PM   #26
iHateVolvoPeople
Never mind owner is lazy and useless and won’t get anything done. Car will sit broken in his garage until he decides to scrap it. Thank you guys for your help.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 01-17-2018, 03:04 PM   #27
iHateVolvoPeople
Can you adjust ignition timing via the distributor on a Regina car? There seems to be a slot for adjustment.
Old 01-17-2018, 03:43 PM   #28
84B23F
84B23F's Avatar
CPS's position determines timing...getting distributor cap off weakens spark, or if far enough off, send spark to wrong cylinder.
Old 01-17-2018, 05:36 PM   #29
iHateVolvoPeople
Can’t the CPS only go on one way? On lh i just removes and replaced when it failed and never bothered with timing.
Old 01-17-2018, 06:33 PM   #30
No. Computer controls it. It knows where the crank is. Dist mount hall effect sensors do not, therefore those are adjustable manually.
Old 01-20-2018, 05:23 PM   #31
milanomike
I had a Regina 940 for ~20 years, always starts in 0 F weather. Did you check fuel pressure, pump may run but not put out enough oomph. Going on memory you need 35 psi, when blipping throttle it should go up to 43 psi, again going on memory. Car will start with 20 or 25 psi, but hesitate when you want to accelerate. There is a Schrader valve on the fuel manifold, rig up a cheap gauge and check FP.
milanomike is offline   Reply With Quote
Old 01-20-2018, 05:47 PM   #32
iHateVolvoPeople
Schrader valve wasn’t until 93+ i believe. Even if it wasn’t getting fuel that wouldn’t explain why it wouldn’t start on starting fluid.
Old 01-23-2018, 02:52 PM   #33
Ryan_R
I was joking that the no start conditon and intermittent tach are indicative that you have a Regina car, because it’s less robust than the comparable Bosch system.
Biggest. falsehood. ever.
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 01-23-2018, 02:55 PM   #34
Ryan_R
If you have fuel and spark, and it still won't start with a little throttle pressure to bypass the IAC, odds are that it's the MAP sensor. It's a $30 GM part. They go bad once every 300K miles.
-Ryan
Old 05-26-2018, 06:28 PM   #35
iHateVolvoPeople
-Ryan
Would a bad map sensor cause a no start though? Maybe I can grab one from the JY and parts swap. Bet they’re cheap cheap.
Heading to Springfield tomorrow to mess with the car again. Plan to bring some real starting fluid and also swap out a spare CPS I have.
Old 05-27-2018, 02:10 PM   #36
iHateVolvoPeople
So I drove there today, reinstalled the dist, and it started right up. Runs like absolute garbage. Any ideas? Smells very rich. It was in time last time I checked. Adjusting the dist does nothing as expected. Unplugging the map or iat (whatever the thing is that’s located in the amm position) also does nothing at all.
https://youtu.be/pvCQQKBsJ7w
Old 05-27-2018, 05:17 PM   #37
iHateVolvoPeople
Car has spark and kind of runs off of ether but not really. I made a triple jumper to jump the FPR (pump and RSR) and still nothing. Any ideas? Injectors not firing? I’m 100% sure the pump works and pumps a LOT of fuel.
Plugs are dry after pulling them.
Old 05-27-2018, 07:13 PM   #38
iHateVolvoPeople
Smells extremely rich. Got it running on its own. Timed correctly I’m 100% sure. Barely idles but sometimes idles very smoothly. I can hear injectors clicking. Doesn’t respond to throttle at all except for idling even worse and maybe stalling/backfiring. Wtf
Old 05-27-2018, 10:15 PM   #39
iHateVolvoPeople
Car is for sale at $10 firm local pickup only in Springfield, MO. Friends don’t let friends drive 7/9 cars.
Old 05-28-2018, 02:16 AM   #40
MasterBlaster
The one in the air hose is the intake air temp sensor. The MAP sensor is in the left rear corner, hanging off the diagonal strut brace. Needs electrical and vacuum line hooked up. They work together to tell the computer how much air is getting in. Coolant temp sensor for the computer is under the manifold, by intake runner #4. Bad connection or bad sensor might be telling the system that it's -40 degrees. Or +450 degrees.
http://www3.telus.net/neatcrap/volvo/sensors.gif
Smells extremely rich. Barely idles but sometimes idles very smoothly. Doesn’t respond to throttle at all except for idling even worse and maybe stalling/backfiring.
Check the fuel pressure regulator vacuum hose (pull it off while pressurized) for gas leaking from a torn diaphragm. Check the idle switch on the throttle body for proper adjustment. Should click just as the throttle starts to move. Check everywhere else for vacuum leaks.
Maybe it would run better if you stopped "texting and driving while blaring your music", then running into innocent hobos in trash cans?
467,000 km so far...
Old 05-28-2018, 08:42 AM   #41
iHateVolvoPeople
Doesn’t Regina not care about vacuum leaks because it’s map based? But either way I fixed some vacuum leaks. Also i swapped in another MAP sensor and IAT sensor and no difference. CTS is new, crank sensor is new. I don’t think an IAC would stop the car from running either, especially when i give it gas.
The owner of this car used it as a trail rig essentially so who knows what has gotten wet...
Guess I could check the fuel pressure regulator.
Old 05-28-2018, 02:03 PM   #42
84B23F
84B23F's Avatar
Where is distributor located...in the head or the block? If block distributor, and it was twisted about, one has screwed the pooch, most likely.
Smells rich suggests you got the wrong CTS, or spark is weak, but you claimed plugs were dry, which suggests a misdiagnoses.
Disconnect CTS....in warm weather, Regina will assume its upto temperature.
What year?
Old 05-29-2018, 09:52 AM   #43
iHateVolvoPeople
What year?
1991. He’s replaced the CTS with a new unit from iPd. They’re the same as lh2.4 right?
Old 05-29-2018, 11:52 PM   #44
84B23F
84B23F's Avatar
I said unplug it on a warm day, then drive on. See how it runs when engine temp is at operational temp.
I'd have to check, but I think CTS is different on Regina
Old 05-30-2018, 12:27 AM   #45
84B23F
84B23F's Avatar
Volvo Part # 1 346 030-8
Bosch 0280130069
Bosch 0280130032
Old 09-15-2018, 11:20 PM   #46
iHateVolvoPeople
Here’s a ~4 month update. Had my buddy tow the car to my house where i have my own tools and another regina car to parts swap with. Jumped the 91 and it ran, but poorly and would die (as shown in video from earlier). I started it and had it idle for about 30 seconds or so and then measures exhaust temps. 1 and 4 were about 160F, and 2 and 3 were cool to the touch. Pulled cylinder 2 plug and it was getting a very very intermittent spark. Same with 3. So it’s essentially a 2 cylinder.
Swapped ignition coils and cylinders 2 & 3 plug wires from another Regina car (known good) and no change.
So as of now we are basically almost completely lacking spark on 2 and 3. Plugs were wet with fuel and had little to no spark, even after swapping coils and plug wires.
Plans for tomorrow are to first try a different set of plugs. This car has some weird NGKs in there, perhaps iridiums? I know redblocks don’t like those. If that causes no change, I’m going to swap cap and rotor, then distributor.
Old 09-16-2018, 12:00 AM   #47
swedefiend
swedefiend's Avatar
Well, I see it's been a while since you made this post...
Regardless, this is an interesting belief. Please elaborate as to why you feel that the approximate pressure in the manifold would be sufficient for the absolute metering of fuel.
Old 09-16-2018, 12:03 AM   #48
swedefiend
swedefiend's Avatar
Also, redblocks *love* NGK plugs.
Maybe not iridium plugs, IDK about those...
Old 09-16-2018, 08:40 AM   #49
iHateVolvoPeople
I have checked thoroughly for vacuum leaks, and I do not believe a small leak would ever cause a no start like we were having. It was definitely spark related. But anyway, i have seen MAP based cars run without intercooler piping and they can be fully driveable unlike MAF based cars. The MAP sensor accounts for how much pressure is in the mani and makes its calculations off of that as well as input from the IAT. But that’s just what I assume. Not entirely sure if that’s the case with volvos.
Yeah redblocks Love BPR7ES and other heat ranges. I’ll check what his car has but I think he said his problems only really started arising after the plug change. I’ve swapped different plugs in the past with no difference but I’ll try again today.
Old 09-16-2018, 10:37 AM   #50
iHateVolvoPeople
Vehicle has BPR6EGP plugs. Not what I’d normally run but should work.
Here’s where we are:
Swapped plugs, wires, distributor, ignition coil (bendix?), bypassed the RSR to confirm 12v to the injectors, bypassed the FPR to ensure the pump runs, verified cam/crank timing 3 times. Still only running on 1 and 4 barely. So we are lacking spark in 2 and 3 90% of the time, and i also think we are lacking fuel sometimes too. Plug 2 wasn’t very wet after after running for a while. Little to no throttle response while running, which is to be expected because it’s a 2 cylinder.
What would cause no spark on 2 and 3?
Just swapped the computer on the passenger side (bendix) with a known good, and no change.
Is there a separate computer for Rex? Edit I think there is and it’s in the same location as the ignition computers on the LH cars.
