Old 11-28-2015, 02:08 PM   #251
AndrewNance
Amateur hour!
AndrewNance's Avatar
That's pretty cool. Probably been floating around in there for a few decades.
'71 142
'80 245
Feedback
Old 11-28-2015, 03:46 PM   #252
Originally Posted by mocambique-amazone View Post
The beads are in reality the rest part of a original part: a chain to save the fuel cap. This chain is fixed on the cap, on other side onto the fuel neck regards, Kay
http://www.ebay.com/itm/Volvo-Filler...-/121381095698
Old 11-28-2015, 03:57 PM   #253
HUB
Needs more cowbell
HUB's Avatar
Thats what I thought it might be. It has wedged itself. Will try to get it out. If I can't get it, it's going to stay in for another few decades. Lol.
Thanks!
HUB is offline   Reply With Quote
Old 11-28-2015, 05:47 PM   #254
V-O-L-V-O
V-O-L-V-O's Avatar
Originally Posted by HUB View Post
The tank is covered with a thick undercoat. Don't know if I want to leave it, or take it off and have the entire tank powder coated.
Paint is "always" nice...seen your current mods, but will you go all the way with the rest of the "underbody"!? Good luck....following from here.
/ sven
64 PV 11234E SPORT
65 PV 11134F
65 Amazon 13134 VE
72 145 SPORT
74 144GL 1444941 A
V-O-L-V-O is offline   Reply With Quote
Old 11-28-2015, 06:15 PM   #255
HUB
Needs more cowbell
HUB's Avatar
I have painted anything that could unbolt from the car. Nothing left really... Now the question is red or black...
Old 11-28-2015, 06:31 PM   #256
evolvo67
evolvo67's Avatar
You've probably figured it out already but the pick up tube at the top of the tank has an internal tube that goes to the bottom.
Old 11-28-2015, 06:36 PM   #257
V-O-L-V-O
V-O-L-V-O's Avatar
If you're looking for opinions (?)...I'd say black
/ sven
Old 11-28-2015, 10:35 PM   #258
HUB
Needs more cowbell
HUB's Avatar
It does?! I'll have to take another look tomorrow. Didn't see that before. Appreciate it!
Old 11-28-2015, 10:36 PM   #259
HUB
Needs more cowbell
HUB's Avatar
/ sven
I'll play around with it tomorrow and make a choice. I'll also talk with the powder coat place near me. They owe me one right now.
Thanks,
Old 11-28-2015, 10:48 PM   #260
HUB
Needs more cowbell
HUB's Avatar
Sway bar came in today thanks to 122power. Thanks again! Will get this painted next week.
Thanks,
Old 11-29-2015, 07:28 PM   #261
HUB
Needs more cowbell
HUB's Avatar
Default Prepping Fuel Tank for Paint
Got the sway bar prepped and working on the tank.
Thanks,
Old 11-30-2015, 11:43 AM   #262
sspony
sspony's Avatar
Awesome build man! Keep up the good work!
Potential, potential, potential....
65' 122s (daily driver)
82' 242 dl
88' 740 "rally wagon"
sspony is offline   Reply With Quote
Old 11-30-2015, 02:05 PM   #263
matt b
Nice work. Is your filler neck loose ? I had mine re-soldered in Kentucky, only requirement was to bring them a tank that had been dipped to remove any risk of explosion from fumes. That undercoating is usually pretty thick, I bet it was no fun to remove.
Old 11-30-2015, 05:51 PM   #264
LloydDobler
LloydDobler's Avatar
Heat gun and putty knife was the easiest combo I found for removing undercoating. Still took a long time, but my arms and fingers weren't trashed when I was done.
'66 122 - Collectible project
Old 12-06-2015, 09:23 PM   #265
HUB
Needs more cowbell
HUB's Avatar
I'm still in the process of removing all the $*** caked on it. Haha.
Thanks,
Old 12-11-2015, 10:09 PM   #266
HUB
Needs more cowbell
HUB's Avatar
Finally had time to work on the tank some more tonight.
Thanks,
Old 12-12-2015, 12:03 AM   #267
nelsonmouellic
Nice work! Almost looks too nice to paint over again
1967 122s Wagon Project
Instagram: @67AmazonWagon & @NelsonMouellic - www.mouellic.com
nelsonmouellic is offline   Reply With Quote
Old 12-12-2015, 08:32 PM   #268
carbonmike
carbonmike's Avatar
The discussion about rear wagon springs got me thinking. I have heard grumblings that the IPD rear sway might be a little too stiff for the wagon. I disconnected it and the car rolled a lot more and i felt it handled better with it, but that was with stock springs and wheels. For kicks I disconnected it with the new suspension. I did not notice any additional roll, less likely to spin the the rear tire in tight corners. Front pushes a little earlier than before but still pretty balanced.
I think the combination of the stiffer springs and shocks were too much with the rear sway. Will try the 175 lb springs sans rear sway. I am guessing it will be a nice compromise.
carbonmike is offline   Reply With Quote
Old 12-13-2015, 09:44 AM   #269
HUB
Needs more cowbell
HUB's Avatar
I don't have a rear sway bar. Don't even have a panhand bar either (will have to make something). I have no idea how it's going to handle for me and nothing to compare it too since this is my first Volvo. I will just have to drive and adjust. I know the setup will be stiffer then what it was ( a lot of worn parts).
Did your setup have poly bushings?
Thanks,
Old 12-13-2015, 12:19 PM   #270
carbonmike
carbonmike's Avatar
Thanks,
New poly bushings. Still have not replaced the hourglass shaped axle mount bushing. I am still a little traumatised from trying to remove bolts rusted to bushing sleeves.
I like the way the wagon handles. It is no racecar but it is a ton of fun to drive in a spirited manner on twisty back roads.
Old 12-13-2015, 08:21 PM   #271
HUB
Needs more cowbell
HUB's Avatar
Default Installation of Ford 8.8 Read End
Got the rear end installed tonight.
Thanks,
Old 12-14-2015, 01:05 PM   #272
cwdodson88
Yeah buddy! Looks great!
The Build Thread
SVEA - PUSHROD TURBO!
Old 12-17-2015, 07:23 AM   #273
HUB
Needs more cowbell
HUB's Avatar
Got the car on the ground to take measurements and see what sort of adjustments I'll need to make to the suspension. Still sitting higher than I wanted. Also, don't like the wheel gap.
Thanks,
Old 12-17-2015, 11:49 AM   #274
cwdodson88
Good stuff! 17" or 18" wheels will take up some of the gap (running a 50 series tire)...but needs moar lower
Old 12-17-2015, 12:53 PM   #275
HUB
Needs more cowbell
HUB's Avatar
Agreed. Thank you.
