Old 05-02-2015, 12:25 PM   #201
Hodginsa
Always
Hodginsa's Avatar
Strip the chassis, remove NVH, fix all the holes/paint, rewire, drive.
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 05-02-2015, 01:10 PM   #202
amerbritcan
Hnnnnnng
amerbritcan's Avatar
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 10-24-2016, 11:53 PM   #203
Hodginsa
Always
Hodginsa's Avatar
Car is currently for sale: http://forums.turbobricks.com/showthread.php?t=326522
Old 06-20-2018, 08:59 AM   #204
Hodginsa
Always
Hodginsa's Avatar
Bump. Sold my truck to save my car, so this thread will be updated soon.
Old 07-13-2018, 10:52 PM   #205
Hodginsa
Always
Hodginsa's Avatar
Okay, so after a long transport, she arrived, but not without issue... lol
Hood flipped up on the highway while on the trailer that she was moving on. Driver didn't strap it down, whatever, **** happens. I have her in my possession now, and it was a cheap tow for 550km
Does anyone have a coffin hood? Or maybe Ill just flat hood it. But I was really starting to dig coffin hoods. I put the piece of wood there and I was able to pop out the dent, but the hinges are so f'ed, and the hood is like a mountain range.
Broken taillight too. Little help? anyone have a spare?
First thing I did was clean all the grime off, she has been sitting for 2 years(damn time flies).
I forgot I had gotten the engine all ready to pull out! Should make quick work of that this weekend so I can fix the clutch. Also going to try and bend the clutch/brake pedal box back into position instead of buying one. Anyone have a picture of a not bent clutch pedal box?
So if anyone in the Ottawa/Montreal area has some parts, I would love to get some to get this car going. I was on the lookout for a hydro clutch setup too.
Old 07-14-2018, 12:28 AM   #206
GTJordan
Been here for too long
GTJordan's Avatar
Jesus Ontario corrosion sure is taking its toll on any bare metal
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 07-14-2018, 08:05 AM   #207
Hodginsa
Always
Hodginsa's Avatar
I think that is just from sitting in humid weather. The car hasn't seen any salt in the last two years, it was parked at the end of a long driveway away from the road. I guess that would still be Ontario corrosion! haha The exhaust is actually in great shape and it was sitting on the ground under the car for over a year and a bit, just a bit of surface rust. You can see the downpipe in the trunk. That bare metal turbo rusted so quick. Probably should take it off and clean it, maybe coat it.
Old 07-15-2018, 10:02 PM   #208
Hodginsa
Always
Hodginsa's Avatar
I will not give up on this car.
Most of the tar stuff is gone! Only minor heat stroke today.
The stuff on the tunnel is super tough to get off.
Next step is to remove the center seat support, the whole thing, get new floor pans and weld them in.
Old 07-18-2018, 07:55 AM   #209
Hodginsa
Always
Hodginsa's Avatar
Progress is slow, but I started extending the clutch pedal to accept a hydro cylinder.
Cut it 3cm down from the shaft.
Started working a piece of 1/4" plate steel.
Snug fit.
Have to do the other end, and weld it together, with some reinforcing as well.
Old 08-21-2018, 07:31 PM   #210
Hodginsa
Always
Hodginsa's Avatar
Finally got the engine out, the extent of the bent fork was worse than I originally thought. Look where the pivot point is(not supposed to be collapsed there).
I need to do the synchros on the T5, shop quoted $1300, so nope! Ill do them myself.
I'm considering putting in a stock pressure plate instead of the 3000lb one. Thoughts? I would like to drive the car, and not break it.
Also scored some RSX seats that seem to fit perfectly and easily modified for the stock location.
and finally managed to get the middle support out of the car so I can start fixing the floor. I'm thinking of cleaning it up and reusing it and keeping the stock seat mounts.
Floor is going to be fun.
Old 08-26-2018, 05:15 PM   #211
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
arrr i hate rust!!!
Old 08-27-2018, 08:48 PM   #212
Hodginsa
Always
Hodginsa's Avatar
Tell me about it... The car was rust proofed too, some places just started the cancer and it continued to move, the places that were rust proofed are mint. Really annoying.
Old 08-28-2018, 04:16 AM   #213
JerryJS8
der Junge
JerryJS8's Avatar
I need to tear out my carpet and check for rust and remove the sideskirts and do the same. Seeing this kind of stuff makes me nervous.
Keep courage though, it doesn't look like fun...
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 08-28-2018, 07:15 AM   #214
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
it can be.. sheetmetal work just takes time and patience.. and if you start to loose oversight it is just snipping paper with scisscors bringing it to metal and then hammersmash the **** out of it to make it fit :D I learned to just stop watching what is still left and concentrate on the sheet im working on.. you cant speed up the process.. you just can acceppt, that your car is rusty like **** :D
Old 08-28-2018, 09:50 AM   #215
Hodginsa
Always
Hodginsa's Avatar
Yeah, all welding work makes my head hurt when planning it out. But once I have the materials and start actually cutting and welding stuff, I start to relax.
Old 09-09-2018, 08:57 PM   #216
Hodginsa
Always
Hodginsa's Avatar
More slow progress.
Got the pedal welded together.
Pieces Fit together nicely.
Drilled two holes and welded for extra support.
Who needs a laser cutter? I literally get everything lasercut, so I like doing stuff manually when I can.
Not the best welds, but they'll hold.
