Old 07-19-2015, 11:19 AM   #1
cortezit
Default Battery keeps loosing its charge
I purchased a 1993 Volvo 240 for our daughter several years ago while she was still living in California. We stored it up here in the Great North West for a couple of years. When she finally came home she started driving it. We have put 4 new batteries in the car in the last 6 months. I have replaced the alternator and have put a battery shut off switch in it. We have trouble shot the electrical system for possible "phantom parasitic discharge culprits" but to no avail. What am I missing?
I charged the battery again 2 days ago and isolated it from the system. Yesterday our daughter went out to take her Volvo "Edward" (she names all of her cars) and turned the battery shut off switch to the on position the battery was dead?????
Is there a battery that our beloved Volvos prefer over others?
cortezit is offline   Reply With Quote
Old 07-19-2015, 12:42 PM   #2
johfraser
Any battery should be ok.
What is the voltage at the battery terminals when the engine is running?
Is the battery fully charged (12-14V) after the engine is turned off?
What is the battery voltage before re-connecting?
Does the switch completely isolate the battery (are there any small wires connected directly to the terminals)?
Old 07-19-2015, 08:10 PM   #3
nel621
The shut off switches are known to fail, you think you disconnected but there is still current going through. The overhead dome light delay is another sneaky culprit, the light is almost completely out but still drawing current. Also the power lock solenoid in the drivers door can be a source.I think the 93 has a bunch of crap connected at the battery terminal yes? Clean every thing.Look at the car at night, in dark. Any glowing lights? Glove box light? Do you have a light in the engine compartment, trunk? How are you checking for a parasitic drain?
nel621 is online now   Reply With Quote
Old 07-20-2015, 01:21 PM   #4
cortezit
Default central locking system????
Originally Posted by nel621 View Post
The shut off switches are known to fail, you think you disconnected but there is still current going through. The overhead dome light delay is another sneaky culprit, the light is almost completely out but still drawing current. Also the power lock solenoid in the drivers door can be a source.I think the 93 has a bunch of crap connected at the battery terminal yes? Clean every thing. Look at the car at night, in dark. Any glowing lights? Glove box light? Do you have a light in the engine compartment, trunk? How are you checking for a parasitic drain?
To answer the questions of the 2 members who responded. And thank you for the responses!!
1. Battery has 13.13 volts at full charge after coming off of the battery charger/battery still has 13.1 volts after being reinstalled-sitting all night with the disconnect switch in the disconnect position. Conclusion-Battery can hold a charge and disconnect switch-when used- does its job.
Parasite leak check conducted by disconnection the negative terminal and connecting a V/O meter between the negative lead and the negative terminal and reading milliamp draw. 70 milliamps.
How do I go about checking the central locking system??
Old 07-20-2015, 06:51 PM   #5
1choice
ah the faulty solenoid drain.
There is a molex connector looking connection right under the dash on the left side of the drivers side near the front.
that's how to disable those solenoids. when you disable this, the central locking stuff doesn't work.
I'll take a photo as im about to go, and post it when i get back.
1choice is offline   Reply With Quote
Old 07-20-2015, 10:40 PM   #6
Owsley
Owsley's Avatar
I just copied this from one of my Toyota forums - similar issue
Originally Posted by jack8745 View Post
I know it's hard to believe that someone wants (on turbobricks) to make things work the right way. My extensive search shows this hasn't happened since 2005 when there was a ziptie shortage and Tbrickers were forced to buy and use the correct parts
Originally Posted by Lord_Athlon View Post
This is the only forum in existence where people get mad that their cars are worth more than 500
Originally Posted by Johnnysalt View Post
I don't know how to do anything, help! Whats the quickest easiest dumbass proof way to fix this besides taking it to someone who knows how?
Owsley is offline   Reply With Quote
Old 07-20-2015, 10:49 PM   #7
smokeyfan1000
Guest
is the alt ground cable that runs from alt to block broken into?
Is also possible for a remanned alt to have bad diodes...this allows it to discharge the battery slowly, because it'll charge battery at a rate slower than it requires when car is being driven.
Diodes are like a "one way valve" for the alternator's current. And yes have seen new (& old) alts with bad diodes.
It's also possible to blow the diodes of a new alt if you arc the alt's positive terminal to ground while installing it.
Also is alternator BELT tight enough?
Take car to A/Zone or such and have charging system tested for FREE.
Old 07-21-2015, 11:42 AM   #8
coonmanx
Definitely make sure that the alternator ground wire is attached and in good condition.
Jim C.
Don't own a Brick anymore. It got crushed.
coonmanx is offline   Reply With Quote
Old 07-21-2015, 09:48 PM   #9
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
Check the voltage at the battery (everything off) with a DMM.
Should be above 12V+
While the engine runs it should be between 13.8-14.4
If less than those #'s (running) it'll most likely be a loose alternator belt, a bad alternatorground, or a shot alternator.
Get a DMM on it to get some actual #'s and take the guessing game out of the equation.
There's no way you went through 4 batteries in 6 months without having something wrong with the car. Double check that ground right at the alternator first!
No ground = not charging the battery
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
