Old 05-17-2019, 01:50 PM   #1
missthe1122
missthe1122's Avatar
Default Need advice - 1990 760 ECC error code 233
I'm trying to get my ECC system to work, but I get the flashing AC button and no fan function. The diagnostics test issues error code 233 Fan motor excessive starting current. This is the only error code present. In the winter I rigged up a manual switch + resistor pack to run the fan for heat and defrost function. This worked just fine, providing 3 fan speeds no problem. Now I need AC, so I bought a new VDO blower fan in case the old fan was actually "drawing too much current" but I get the same error code. I also swapped out the ECC control unit with another known good one and I got the same 233 error code. What's strange is when I first installed the new fan, the fan switch ran the fan at all the speeds. I thought my problems were over, but it hasn't worked since the initial try, and as soon as I turn the switch from AUT or 0 position, the AC button begins to flash. FYI I can trigger the AC compressor clutch by jumping 12V to the output side of the AC pressure switch but there is no voltage on the other terminal of the AC pressure switch. I read the article about converting from MCC to ECC and I noticed "ECC is not only more sophisticated and advanced, it can also be controlled manually just like MCC if you donít like what the computer is doing." How do you do make this happen? My thought is if I can't figure out the excessive starting voltage problem, I would try to re-wire the system to bypass the control unit and convert the system to MCC. Not sure what to do at this point. Any suggestions?
missthe1122 is offline   Reply With Quote
Old 05-17-2019, 02:05 PM   #2
I always do blowers and resistors as a pair. The blower gets old and starts pulling too much current and fries the resistor.
Old 05-17-2019, 02:25 PM   #3
The panel in the dash indirectly controls the fan. There is a control unit mounted to the heat/AC case just to the right of the transmission tunnel. Usually when you are getting no blower, or, that code, the control unit is the problem. This controller also switches all the vacuum actuators.
Old 05-17-2019, 02:59 PM   #4
missthe1122
This car uses a different system than the MCC. Instead of a resistor pack , the output to the blower comes from a servo motor??? Whatever that is. It's near impossible to find that unit. I have a manual switch and a resistor pack from a chevy which I used in the winter to run the fan at 3 speeds. I powered it via a fused 30A line switched via a relay. It worked fine for the heat and defrost. But now I want to get the AC going. I installed a brand-new VDO blower fan so it shouldn't draw too much current. I could put the resistors and switch back in but I'm not sure how to wire the AC. I was going to go directly to the compressor but someone said without pressure control, I'd blow up the system. I'm wondering could I just put 12V to the input side of the pressure switch on the AC dryer?
Old 05-17-2019, 03:05 PM   #5
missthe1122
I thought about that unit. The vacuum actuators work because I can switch between vents and it did run the fan at all 4 speeds the first time I turned it on. I'm wondering what the controller uses to sense "too much starting current" maybe I can "trick" the controller that way. That servo unit is impossible to find. I've tried. I know the 960 used the same system, but there are not many junked 760's or 960's around here.
Old 05-19-2019, 09:43 AM   #6
A tough rowing ho
Put ad on the wanted section, someone will have one.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 05-19-2019, 03:19 PM   #7
missthe1122
I'm not confident that the servo control is the problem and I don't want to wait weeks to find out. I'd rather just bypass the ECC system entirely and activate the AC manually. I'd appreciate advice on how to do that. I already have the parts to hook up the blower fan. I just need to know how to wire the AC system to safely trigger the compressor. I was thinking that I could just run 12V to one side of the low pressure switch since the other side goes directly to the compressor, but I don't know too much about Volvo AC systems.
Old 05-20-2019, 10:34 AM   #8
Mapleleafer
There is a Darlington power transistor module mounted near the blower. This allows a low current signal from the dash unit to control the high current to the motor. Opposite of many control devices; the motor is powered directly from the fuse and the power control is on the ground side. Part of this module is a low value resistor used for current sensing. One of the two small wires is the control wire to the base of the transistor, the other is the current sense output back to the dash unit.
First, disable your added stuff to put the system back the way it was. Then backprobe the heavy black wire of the power module with a voltmeter and connect its other end to a known good ground. Ignition on and read the meter when you turn the fan selector to 1. If you see it rise to more than 0.1 volts, you have a bad ground to the module. And if this low setting is enough to trigger the error, the failure is inside the module - suspect bad solder joints - although the transistor itself can fail.
Mapleleafer is offline   Reply With Quote
Old 05-20-2019, 02:21 PM   #9
^^^The voltage drop test is a good idea. You could also use a current clamp and do some tests.
Old 05-20-2019, 02:38 PM   #10
missthe1122
This sounds like a good way to move forward. Thank you for the explanation. I've already returned the system to factory and installed a brand-new blower fan. I see the module where the fan wires are attached to. I was beginning to suspect a bad ground, but your test is very explicit. I'll try it and report the results. Apparently error code 233 is fairly common, but the advice I found so far just says replace parts. I prefer troubleshooting as you've described.
Old 05-20-2019, 06:27 PM   #11
lummert
lummert's Avatar
I replaced the blower motor on my 88 765 before figuring out that there was nothing wrong with the original. I ran a switch to a radiator cooling fan ballast resistor and a ground wire to the blower motor. I found the wiring points needed on the rear of the relay panel. there is a ground point on the trans tunnel in back of the relay panel. Relay panel is on passenger side behind the radio console.
Old 05-20-2019, 06:38 PM   #12
Mapleleafer
Original poster said he already replaced the motor with new and got the same result. That is practically a guarantee that there is not excessive current draw. This is a sensing issue.
Old 05-21-2019, 03:27 PM   #13
missthe1122
I thought the same thing, but a voltage test is valid. A bad ground could cause excessive current draw even with a new replacement. I have two control units and they both issue the same error code. It's hard to believe that I have two control units failing in the same way - especially since one of them was working in the car I removed it from. I really want this mystery solved, so I'll try all the advice I receive. Thanks to all for the assistance.
Old 05-21-2019, 03:32 PM   #14
missthe1122
Following another post, I installed a mechanical switch and a resistor array, which gave me 3 fan speeds using the original fan so I could have heat in the winter. Now I want AC and would like to get the original factory setup working. I'll just keep trying to figure this one out. I know you recommended using a chevy blower motor, but I purchased an original replacement made by VDO expecting that to work. So far it returned me to my original problem.
Old 05-21-2019, 03:33 PM   #15
missthe1122
Following you advice from another post, I installed a mechanical switch and a resistor array, which gave me 3 fan speeds using the original fan so I could have heat in the winter. Now I want AC and would like to get the original factory setup working. I'll just keep trying to figure this one out. I know you recommended using a chevy blower motor, but I purchased an original replacement made by VDO expecting that to work. So far it returned me to my original problem.
Old 05-21-2019, 04:38 PM   #16
What do you mean when you say control units? The panel in the dash with the temperature and fan speed control on it, or, the vacuum solenoid control unit?
Old 05-21-2019, 09:25 PM   #17
Mapleleafer
A bad ground will reduce the current draw across the motor. That said, I found the wiring diagram and see that the motor ground circuit includes a common ground for the dash (control) unit, making it lower on the list. That makes bad solder in the module my #1 suspicion (like every other Volvo module, controller relay or gauge that I've seen which doesn't work correctly). Resolder the 2 pins at the transistor itself, and all the ones where the plug connector meets the PC board. If solder does not cure the error code, the transistor has failed.
Here is a list of the wire functions:
Heavy wires
1 VIO fused power from battery
1A BL-BK neg side of blower motor
2A BK Ground
Smaller wires
2 GN-Y to A/C compressor low pressure switch
3 BL-R hi blower relay coil
4 PK PWM blower speed signel (transistor B)
5 BN A/C compressor relay coil
6 PK blower current sense
Old 05-22-2019, 08:24 PM   #18
lummert
lummert's Avatar
Heavy wires
2A BK Ground
Smaller wires
Question about the blower current sense wire. How many volts should be going to this using a resistor? I don't need to worry about my a/c as the compressor is no longer in place seeing as the a/c hasn't worked for as long as I've owned the car (13 years).
Old 05-22-2019, 08:30 PM   #19
lummert
lummert's Avatar
The climate control parts on your car are manufactured by Harrison France (GM). This is why the original blower motor is GM, but the aftermarket replacement part for GM cars doesn't fit the same.
Old 05-23-2019, 03:35 PM   #20
missthe1122
Heavy wires
2A BK Ground
Smaller wires
I agree that the power unit must be faulty. See my post below.
Old 05-23-2019, 03:36 PM   #21
missthe1122
There are three components in play. The control unit, a servo motor which is wired only to the control unit and a power unit wired directly to the blower fan and also connects to the low pressure switch on the accumulator. The control unit works the vents flawlessly. I centered around the power unit that feeds the blower fan. This is what I found. The BLK wire from the power unit is GND with no voltage variation when running. There is a GRN/YEL wire from the power unit to one side of the low pressure switch on the accumulator. The fan wiring is VIO and BLU/BLK. Weirdness: Both of these wires have the full BATT voltage when running and when the car is turned off! That ain't gonna run a fan! And, why are they powered when the car is turned off? Looking at the terrible schematic I have from my Haynes manual, the Control Unit feeds the input to the Darlington pair transistor via A RED/BLK wire. It looks like a relay in the power unit switches the output of one of the transistors to GND. The other output of the transistor is wired directly to the BLU/BLK fan wire. I can't really understand how it works from the schematic. Anyway I don't believe it is a bad control unit, because I have two and they both do exactly the same thing and issue the same error code (233). I did open them up and look for solder problems, but a close inspection didn't show any. I believe the problem could be the power unit and of course I can't find another one of those. I believe this is the case because I measured full battery voltage in respect to GND on both fan wires when the engine is running and the engine is off. That can't be right. I can run the fan by disconnecting the BLU/BLK wire from the power unit and grounding it. What is going on?
Old 05-23-2019, 04:09 PM   #22
Do voltage drop tests.
Old 05-23-2019, 04:51 PM   #23
jwernerny
jwernerny's Avatar
...suspect bad solder joints - although the transistor itself can fail.
I remember chasing a similar problem on more than one 960 with ECC, and I remember the issues traced back to soldering. Well, actually not soldering, but delamination of the circuit board traces from the circuit board where the connector came in. Reflowing the solder solved the problem.
Now, which modules in the fan control system is lost in the pit I call my memory. I know I was put on to it by a post somewhere here, probably from before 2010. You might want to search "ECC bad solder" and see what it gets you.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 05-23-2019, 04:55 PM   #24
jwernerny
jwernerny's Avatar
Man I am good. Found a thread about it (from 2006!): http://forums.turbobricks.com/showth...ghlight=solder
Old 05-23-2019, 04:56 PM   #25
missthe1122
I'm referring to the in-dash unit. I say control units because I have two of them - the original one and a replacement one I obtained.
