Old 08-08-2007, 09:48 AM   #1
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
Default AW71 free accumulator mod
Even better than the valve body mod is the new and heebspeed improved... There are these pistons in the transmission called accumulators and they act kinda like shift shock absorbers.. There function is to make a nice smooth shift and to make old ladies happy with there volvo.. The bad thing about them is that they cause a short slip during the shift to make it smooth but during that slip on high hp volvos the clutches in the trans get super hot and wear out.. By adding a spacer inside of the accumulators spring you reduce the shift time by reducing the time it takes to fill the piston up with fluid.. I took each spring and cut some heavy rod about 1/8 inch shorter than the spring is fully extended.. Do this to each one of the accumulators springs in the trans and you will get much faster shifts and should still have a driveable trans... This was super easy and should actually make the trans last longer..
Sorry there are no pics my camera was dead..
UPDATE 4 years after original post..
Kenny and myself picked up a project to help out a local Tbricker Jim and replace his 850 auto trans.. We dident feel that it would be right to go threw all that work of swaping out the transmission without making some sort of upgrade so here are our pics and video from the same mod done to an 850 turbo transmission..
enjoy the pics and video..
removing the valve body
remove only the 10mm bolts and the valve body should lift right off.. dont forget to carefully remove the shifter arm as your picking the valve body up.. this can be difficult when reinstalling..
whats under the valve body..
on the 850 trans the accumulators are located on the valve body its self.. remove the 6 black 10mm bolts but be prepared its spring loaded..
here is what my shim looks like beside the spring.. the shim is about 1/4 shorter than the spring fully extended.. the shim fits nicely inside of the spring.. We used a cut off 14mm bolt for a shim..
and the shim inside of the spring..
here are a few short clips to give you and idea of how the accumulators should squish after the shims have been added..
Enjoy guys.. and from the looks of things this could be done with the transmission in the car but its defiantly easier with it out..
-Sam
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 08-08-2007, 10:28 AM   #2
IceCold4x4
so is this feasible with the tranny in the car if so ? or anyone feel like getting froggy sunday mornin'?
1992 Volvo 940 Turbo - RIP at the crusher.
2006 S60R - Electric Silver / Nordcap - Ipd strut bars, subframe inserts, H&R spacers, 245/40R18 Michelin Pilot Super Sports. (dreamed about this car for 6 years now I own one YEA!)
2006 XC90 V8 AWD - Triple Black - The gun mobile.
IceCold4x4 is offline   Reply With Quote
Old 08-08-2007, 10:36 AM   #3
RoadRacer4Life
Owner: DeathWagon
yes it can be done in the car and maybe but just maybe..
Old 08-08-2007, 10:46 AM   #4
thelostartof
unbalanced chemical
thelostartof's Avatar
how do you get the pistons out with the trans in the car? mine would not fall out and could not be pulled down
Old 08-08-2007, 10:48 AM   #5
IceCold4x4
hmm guess i'll get there early 'cause with the extra power from teh td06 i really need to get it to shift quicker and harder would be nice
Old 08-08-2007, 11:10 AM   #6
RoadRacer4Life
Owner: DeathWagon
I used an air nozzle and there are 3 holes that you will squirt oil out if you push the pistons in lightly blow air into those holes and it will pop the pistons out...
Sam
Old 08-08-2007, 11:12 AM   #7
IceCold4x4
^ dang great idea
Old 08-08-2007, 11:15 AM   #8
TerribleOne
ZoomZoom
TerribleOne's Avatar
Sounds like sam has been hangin out with Hydramatic guys..
Be really careful about where you shoot air in those things.. Wear safety goggles.
75 242GL - LS turbo, 4L80E, narrowed four linked 9"
89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters
94 945- Beater
93 965- For sale
91 940SE- Roller, for sale
TerribleOne is offline   Reply With Quote
Old 08-08-2007, 11:30 AM   #9
RoadRacer4Life
Owner: DeathWagon
yea for real one of them shot out like a rocket almost taking kennys head off..
Old 08-08-2007, 11:45 AM   #10
Sp3aK
Sam you'll have to give me a ride in it so I can do a butt comparison to my AW70 that I have now, the slipping one I had with the last car, and the AW71 i repalced it with I do hate how it's soo soft and dull.
Volvo defector. Hate me I drive a Honda.
91 Volvo - Sold but not forgotten.
Sp3aK is offline   Reply With Quote
Old 08-08-2007, 11:47 AM   #11
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
maybe next time
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 08-08-2007, 12:39 PM   #12
RoadRacer4Life
Owner: DeathWagon
yea its no biggie accept for the mess of ATF all over the place its an easy mod...
Sam
Old 08-08-2007, 12:41 PM   #13
TerribleOne
ZoomZoom
Originally Posted by benflynn View Post
maybe next time
LMAO.. I did it in class.. with one that was kinda stuck.. when it broke loose it cracked one of the pastic light housings
Old 08-08-2007, 12:41 PM   #14
benflynn
benflynn's Avatar
is this what a shift kit dose on a th350
Old 08-08-2007, 12:48 PM   #15
TerribleOne
ZoomZoom
Yup.. it's what makes it chirp gears. Instant engagement.
Old 08-08-2007, 01:19 PM   #16
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
If you guys do this on Sunday someone needs to get some pictars!
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 08-08-2007, 01:23 PM   #17
smurf244
The smurf is no more
smurf244's Avatar
Originally Posted by Chris_R View Post
If you huys do this on Sunday someone needs to get some pictars!
+1*10000000
1988 244: RIP.
1991 780 Bertone aka The Dyno Killer: Sold. RIP.
1994 945 Turbo: Voxx 16x7 MG, A cam, 240 parts, & DD
1994 965: Parted out, PM with needed parts
1983 244 GLT: Factory/dealer turbo and intercooler, black on black, B21F intake, 850 seats, Voxx 17x8 MG, B&G springs, HD's, NPR, M46etc.
1979 242 GT: Project
smurf244 is offline   Reply With Quote
Old 08-08-2007, 01:25 PM   #18
740ATL
Guest
PS... Sam=God
Old 08-08-2007, 01:48 PM   #19
hockey930
good work sam
08 535xi wagon 6sp
99 Miata
Exocet
hockey930 is offline   Reply With Quote
Old 08-08-2007, 01:59 PM   #20
benflynn
benflynn's Avatar
make a kit, add a trans filter and gasket and get rich!
Old 08-08-2007, 03:04 PM   #21
MetalgodZ
Bored Member
MetalgodZ's Avatar
+1
And get me some pics, dammit! Nice mod.
Originally Posted by stevemd
You know you have a good lawyer when he gets a charge of sodomy reduced to "following too closely".
Originally Posted by Lord_Athlon
This is like Zip-Ties and JB Weld for the legal system.
-'79 242 - Rusting
-'91 940 SE - Damn you, crippled power seats!
-'92 745 - Crippled DD
-'90 760ti - Crippled DD - Thanks, AAA!
MetalgodZ is offline   Reply With Quote
Old 08-08-2007, 03:16 PM   #22
RoadRacer4Life
Owner: DeathWagon
pics are great and all but you dont need them to do the mod.. make a spacer that will fit inside the spring under each accumulator.
Old 08-08-2007, 03:31 PM   #23
ovlo
it is pretty easy to do. I have an aw71 apart now that I am rebuilding all you have to do is remove the valve body and look for the accumulators 3 round things in the case of the trans. when you find them push on them and watch where the fluid squirts in the case of trans. from there blow compressed air in the hole you just found and the piston and spring will pop out and cover your face with trans fluid.
I was going to look for stiffer spring rates to replace the stock springs. not just putting somthing in there so they wont work at all
ovlo is offline   Reply With Quote
Old 08-08-2007, 09:21 PM   #24
mikep
The MP
mikep's Avatar
No, but you can do the same thing. A shift kit is usually a valve body plate with some different holes, and you leave out some check balls. You can usually remove the springs if you want it to shift abusively, or you can shorten them and/or drill out the hole where the fluid goes to make it harder shifting but not as bad as no accumulators.
mikep is online now   Reply With Quote
Old 08-09-2007, 01:21 AM   #25
RoadRacer4Life
Owner: DeathWagon
it really shifts nice.. it feels like our old studiebaker with GN turbo v6 drive train in it.. The trans had a shiftkit and it feels alot like that old car.. second night of abuse and i think this one might hold up....
sam
