Old 09-16-2013, 01:41 AM   #1
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Default The Buchka 242 Street Car
Alex and I have been talking about doing a simpler project for a while. Something closer to stock that we can screw around with and not be too serious with.
We've had an '83 242DL roller sitting around and when we came across a B234f with a T5 attached, it seemed like a good opportunity to realize the idea. Alex went to California in late June, so I've been solo on this one for most of the build. I've also been working in Boston. With the car down at the shop on Cape Cod I've only been able to work on the car itself during the weekends.
So here are the basic specs:
B234f
Yoshifab rods
Ported 90+, Yoshifab adapter
Yoshifab valve springs
Shortened B234f intake manifold, 960 tb
T5wc, 4-puck disc, flat flywheel machined for 60-2
HX35, hogged out divider, enlarged internal gate
VEMS
800cc injectors
4" downpipe, 3" exhaust
4" core ebay IC
The "subject" at the shop, ready for surgery. The '83 DL is my favorite year and trim of the 240s. You get skinny bumpers, 5-panels, and no sunroof. This was originally a California car, so it's largely rust free.
B234f, as received. We were led to believe it was a solid engine that was ready to run. That turned out not to be the case. The valve cover was cracked and it was probably left outside for a number of months, which led to water ingress and rust on the cams and bores.
Alex tore the engine down and did an awesome job shortening the intake runners and porting it for a 960 throttle body.
Cleaned the pistons with simple green in the ultrasonic cleaner at work.
Yoshifab rods installed in the stock pistons.
The head itself is stock and has just been cleaned up. I nuked the valves in an ultrasonic cleaner and lapped them before installing them with Yoshifab springs.
Fabricated new engine mounts out of a hacked up torque rod. The vehicle side uses the front subframe pickup points.
Added a 60-2 to a flat flywheel in the CNC.
Upskirt of the HX35. Since I'm running a 90+ I have no use for the divided housing. I roughed it out in the mill and did the cleanup with a die grinder. Also opened up the wastegate port.
Mounted the IC and the 7" rounds from my old car.
Welded up some 3" tubing for charge pipes.
Added a compression fitting to the pan for an oil temperature sensor.
Plugged balance shaft ports. Turns out a 240 wheel stud with the threads cut off makes for a nice press fit plug.
Stripped and painted the block.
Got an uncracked valve cover from Poik that I added two baffled -10 vent fittings to.
BMRS ProGold -10 oil return, courtesy of Homer. There's also a Swagelok fitting on the header that I'll use to log exhaust backpressure.
Stripped, power washed, and masked off the engine bay.
Went with a Yoshifab-inspired battleship gray, with black behind the slam panel and headlight surrounds.
4" downpipe.
Mounted the VEMS, resistors, and fuse panel on a brushed sheet of aluminum. It bolts to the passenger side kickpanel.
Re-assembled and dressed.
Re-installed.
That brings us up to date. There are tons of little jobs that aren't pictured, but for anyone wanting a more detailed look, here's a link to the gallery where I've been keeping all the photos.
https://picasaweb.google.com/1091212...keStreetCar242
The photos I've posted here represent the last ten weeks or so. I have worked on the car literally every single day for that period. It's been a grind. Getting the engine in is a huge milestone. I'm looking forward to getting it on the road.
Fake Race Car
Old 09-16-2013, 02:30 AM   #2
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Gonna be sweet!!!! You know I've been enjoying watching
Old 09-16-2013, 02:48 AM   #3
Dauntless
The Brapmaster™
Dauntless's Avatar
Nice work. Those engine mounts are interesting, I'm guessing they'd work for any redblock 240?
Dauntless is offline   Reply With Quote
Old 09-16-2013, 02:55 AM   #4
2fast242gt
Do you have a cobalt?
any b234 240.
i have to ask, why the b234? less work than b230 besides mounts? by the way very nice! cant wait to see more!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-16-2013, 03:40 AM   #5
volvobrage
Looks awesome, as always!
The welds on the pressurepipes are so beatiful
Any plans for suspension also?
Stå på!
volvobrage is offline   Reply With Quote
Old 09-16-2013, 03:41 AM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
jeeeez... you do on one weekend where i need years for.. grml.. nice project..
One question.. did you drop in in the springs right on or did you measure seatpressure and do some shiming?
Old 09-16-2013, 07:10 AM   #7
The Full Banana
not yet good enough
The Full Banana's Avatar
Neat. I will be eagerly watching.
-Tom 1980 242 T5
Old 09-16-2013, 08:06 AM   #8
gear whine
advocate of k-jet
gear whine's Avatar
Nice job guys, your idea of "simple" is more overdone than most here on TB, lo
400 klubb!!!
For Life.
gear whine is offline   Reply With Quote
Old 09-16-2013, 09:42 AM   #9
gdogg16
You're a Subtotal
gdogg16's Avatar
I like the BFH job on the strut tower.
Greg
'66 Locort
'72 Fulvia 1600HF Lusso
'74 142
'83 911SC
'99 2500 Ram
'13 TDI Sportwagen
'15 TDI Sportwagen
gdogg16 is offline   Reply With Quote
Old 09-16-2013, 10:08 AM   #10
Homer
OEMplus++
Homer's Avatar
I won't be watching. This is ridiculous. DIRY?
-Jacob:
2017 allroad - Comfy DD
Old 09-16-2013, 10:16 AM   #11
towerymt
the real Towery
towerymt's Avatar
I had better ship that muffler, huh?
Old 09-16-2013, 12:17 PM   #12
Karl Buchka
Thanks guys!
Originally Posted by 2fast242gt View Post
any b234 240.
Yeah, that's pretty much it. The B234f was there, and it's got some nice features that you don't get on a B230. I wanted to do new mounts anyway. I hate stock 240 mounts.
Stå på!
Thanks! Suspension is up in the air right now. I'll probably get some DIY coilovers together with some manner of camber plates. Kildea has a G80 that I can probably use and I've already got a set of adjustable torque rods from Homer.
I didn't do any shimming. I made some cursory measurements of the installed height and it looked fine, so I'm not terribly concerned.
Probably. :D
Old 09-16-2013, 12:22 PM   #13
Quin
ಠ_ಠ
no originality, no worksmanship. it's like you're not even trying.
Old 09-16-2013, 12:34 PM   #14
Looking great Karl.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-16-2013, 02:04 PM   #15
doucheNozzle
doucheNozzle's Avatar
Bitchin'.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-16-2013, 02:24 PM   #16
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Great idea on the engine mounts.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 09-16-2013, 02:42 PM   #17
Turbosteen
I was born at a young age
Turbosteen's Avatar
Cool project! Put in an oil scraper/windage tray from a B204 for added cool factor
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 09-16-2013, 02:53 PM   #18
Karl Buchka
Sander tipped me off to those earlier. I tried to order one, but the part number is invalid in the US parts system. I'll have to get one when I go back to Sweden.
Old 09-16-2013, 02:56 PM   #19
oldschoolvolvo
oldschoolvolvo's Avatar
very nice as usual, keep up the good work!
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 09-16-2013, 03:01 PM   #20
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
so it's running today then, yes?
Megasquirt Tuning!
Old 09-16-2013, 03:07 PM   #21
regular
Incredible work! Looking forward to updates.
regular is offline   Reply With Quote
Old 09-16-2013, 04:20 PM   #22
katluke
How do you manage to always make things look so easy,great thread
1990 740 GLT Estate
katluke is offline   Reply With Quote
Old 09-16-2013, 04:21 PM   #23
Johann
Johann's Avatar
This is nice.
Also nice DNF mod in the strut tower.
Johann is offline   Reply With Quote
Old 09-16-2013, 05:50 PM   #24
poulrais
poulrais's Avatar
Would one of these fit?
http://www.crank-scrapers.com/Volvo.html
1990, Volvo 740 16v +T
Old 09-16-2013, 07:53 PM   #25
DavoS40
DavoS40's Avatar
Awesome!
1983 245DL, 2011 WRX, 1978 SR500
DavoS40 is offline   Reply With Quote
