Old 11-10-2013, 10:37 PM   #1
242R
Default B234 an header
Just picked up a 744 gle 16 valve 5speed. Where can I find a header looking to keep n a. Did a search on here didn't see anything. Thanks.
242R is offline   Reply With Quote
Old 11-10-2013, 10:40 PM   #2
John V, outside agitator
Sweden
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-10-2013, 11:08 PM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
Or you can make one yourself.
Old 11-10-2013, 11:27 PM   #4
olov
doing something stupid
there was a guy that took the chinabay 8v turbo one(it's upside down and the collector is at the firewall) and used it as NA, i liked the idea. not sure if the 16v one exits in the right place or the firewall, if it's the firewall you could do similar to what that guy did
Old 11-10-2013, 11:58 PM   #5
the.spine.surfs
the.spine.surfs's Avatar
I like the idea of modifying a turbo header; also, ask around at local exhaust shops. If someone's got a mandrel bender, they might be up to the challenge.
Also, a 744 with a factory 5 speed? Awesome. Is that a real thing?
Haunted '84 242ti, formerly lsdmt's
the.spine.surfs is offline   Reply With Quote
Old 11-11-2013, 12:47 AM   #6
BassGuy
BassGuy's Avatar
Yes. A lot of later 740s were M47, even with the B234F
2003 Volvo XC70
1991 945GLE - 16v Wagon! (in pieces)
1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably
1987 760 Turbo Intercooler - dead 07/14/2011
Feedback Thread
BassGuy is offline   Reply With Quote
Old 11-11-2013, 09:01 AM   #7
BigMatteson
Camel City Brick Squad
BigMatteson's Avatar
I've got the 16v ebay header. It exits in the right spot so it wouldn't work as NA without lots of rework.
How about using an adapter from Yoshifab with the upside down flange ebay header?
'79 242DL-crushed
'84 245GL-crushed
'82 244DL-possibly in the works?
Originally Posted by TalkingGoats View Post
Never force it as you'll blow out your o-ring and possibly paint the centers brown.
Feedback Thread
BigMatteson is offline   Reply With Quote
Old 11-11-2013, 09:38 AM   #8
mark244turbo
mark244turbo's Avatar
You want to keep the car stock and N/A (natural aspired).
What's wrong with the stock header, or is it missing?
mark244turbo is offline   Reply With Quote
Old 11-11-2013, 10:11 AM   #9
242R
Stock is there just looking to upgrade if I could. guess ill just leave it. yes its a 5 speed should be a fun car!
Old 11-11-2013, 10:34 AM   #10
the.spine.surfs
Way to go, driving a car is generally more fun than thinking about if it could be better.
Old 11-11-2013, 07:55 PM   #11
fivealive
fivealive is offline   Reply With Quote
Old 11-11-2013, 08:01 PM   #12
Cameron
ドクターマリオ
Cameron's Avatar
Originally Posted by fivealive View Post
The best "bang for the buck" on 16 valve N/A is going to be a high-compression build with a nice set of pistons and some stronger connecting rods. Just that right there would get you close to 200HP at the crank (total estimate).
Sounds a lot like a certain 242 that you saw in my garage once upon a time
Cameron is offline   Reply With Quote
Old 11-11-2013, 08:04 PM   #13
fivealive
Old 11-11-2013, 08:57 PM   #14
The stock N/A header (cast iron) and downpipe (steel) actually flows pretty well. It's not going to be much of a restriction for a stock car.
If you do a high compression N/A build, and have a machinist work the head and intake manifold, and also install racing cams from Sweden, then a full custom exhaust would probably be warranted. But if it were my car, it wouldn't be highest on my priority list.
The best "bang for the buck" on 16 valve N/A is going to be a high-compression build with a nice set of pistons and some stronger connecting rods. Just that right there would get you close to 200HP at the crank (total estimate). After that, then I would start worrying about intake and exhaust work.
That and some real camshafts...and valve springs....then some 48 ITBs, then that would be closer to 240....(good estimate)
