Old 11-20-2017, 05:16 PM   #226
Cwazywazy
Single jingle
Cwazywazy's Avatar
What happened here? Chunk of melted piston get chewed up?
I don't know what I have
Old 11-20-2017, 05:37 PM   #227
freevolvos
freevolvos's Avatar
detonation it looks like
Old 11-20-2017, 06:21 PM   #228
Broke4speed
Broke4speed's Avatar
That's detonation...ooh ya.
Old 11-20-2017, 08:14 PM   #229
esmth
dirty swede
esmth's Avatar
RIP. Wideband now on the xmas list?
Old 11-20-2017, 08:29 PM   #230
Cwazywazy
Single jingle
Cwazywazy's Avatar
I'm still amazed I did this on 7psi when the last engine took 15psi to break.. But yeah, injectors and a wideband are definitely in my letter to Santa.
Old 11-20-2017, 08:53 PM   #231
MrBrown
MrBrown's Avatar
Sorry Sam but I hate to say this: just when I think my life sucks and my car always breaks, I come to your thread and feel much better.
But you will prevail!
GhettoFab build thrizzie
Old 11-20-2017, 09:26 PM   #232
Cwazywazy
Single jingle
Cwazywazy's Avatar
Glad to be of service, lol.
When the car is broken I feel like I should sell it, but I won't get any money for a broken car. Then when it isn't broken I won't sell it because I love driving it too much. Endless cycle.
Old 11-21-2017, 11:26 AM   #233
soclosenotnear
Originally Posted by Cwazywazy View Post
When the car is broken I feel like I should part it, but I won't get any money for a broken car. Then when it isn't broken I won't sell it because I love driving it too much. Endless cycle.
Probably all of us. Lol. And ftfy.
Old 11-21-2017, 11:58 AM   #234
Update. Its got some leaks.
Drove it about an hour on the highway. Managed to leak engine oil, powersteering atf, and coolant. And it made this weird noise in boost. But the clutch slip seems to have gone away somehow. So that's good.
Zapped a flex pipe to the exhaust, putting in a new water pump, and ordered a rebuild kit for my spare T3 which (I think) leaks oil into the exhaust housing. Still need to take a look at the steering rack. I should also try and set the ignition timing, or something.
Uh...that funny noise was massive detonation
Old 11-21-2017, 12:34 PM   #235
Cwazywazy
Single jingle
Cwazywazy's Avatar
That vid was when the headgasket blew. How can it detonate if it's got water injection?
Old 11-21-2017, 02:37 PM   #236
Welp, it detonated. Looks like user error left and right.
Old 11-21-2017, 04:16 PM   #237
Broke4speed
Is this a serious question?
Old 11-21-2017, 05:03 PM   #238
Cwazywazy
Single jingle
Cwazywazy's Avatar
Oh, for sure. I'm trying to make it explode less this time.
Old 11-22-2017, 06:34 PM   #239
freevolvos
freevolvos's Avatar
did it go lean on that hole? partially plugged injector? carbon on piston to hot a plug? that's can be done n.a. do with 7#s I'm not surprised that video makes me wince
Old 11-22-2017, 09:23 PM   #240
Cwazywazy
Single jingle
Cwazywazy's Avatar
The piston was steam cleaned when the headgasket blew. Injector is my guess. Was running NGK BPR7ES, I believe.
I never heard it make that noise after doing the HG, but I'm pretty deaf.
Old 11-25-2017, 01:54 AM   #241
Cwazywazy
Single jingle
Cwazywazy's Avatar
How much JB Weld will this take?
Old 11-28-2017, 03:07 PM   #242
cosbySweater
cosbySweater's Avatar
Jesus.....
2005 v70r
2002 BMW 540i Msport 6speed
1995 Porsche 993
2013 VW Passat TDI
Old 11-28-2017, 04:01 PM   #243
SmokesLetsGo
PooPoo Pee Pee
SmokesLetsGo's Avatar
Dude,
I think you need a new hobby.
If trump has to destroy the country to get rid of the juggalos, so be it.
SmokesLetsGo is offline   Reply With Quote
Old 11-28-2017, 04:26 PM   #244
Cwazywazy
Single jingle
Cwazywazy's Avatar
Third time's the charm, right?
I got lazy and didn't clean the head. Turbo pistons in the '93 block the car originally came with and a T cam. New rod bearings and seals all around.
Old 11-29-2017, 04:25 PM   #245
57plymouth
57plymouth's Avatar
With the luck you've had with this car, I'm betting that motor is out again before December 31.
Sven, the 1991 245
Old 11-29-2017, 04:28 PM   #246
Cwazywazy
Single jingle
Cwazywazy's Avatar
Ehhh, 50/50.
Engine probably goes in today and everything I'll need for the 15g arrives later this week.
Old 11-29-2017, 11:12 PM   #247
MrBrown
MrBrown's Avatar
Get them injectors?
Old 11-29-2017, 11:17 PM   #248
cwdodson88
How bad was that cylinder? Judging by that piston, It couldn’t be in very good shape.
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-29-2017, 11:22 PM   #249
Cwazywazy
Single jingle
Cwazywazy's Avatar
Get them injectors?
I did indeed, thanks. They look great.
Engine is mostly in, just need to bolt in one of the engine mounts and the bell housing. In the passenger mount I used a Land Rover Defender mount with some washers. Looks a lot beefier vs the standard one and was like $5 on Rockauto.
Old 11-29-2017, 11:23 PM   #250
Cwazywazy
Single jingle
Cwazywazy's Avatar
Head and block are trash. Wasn't a very good engine before I broke it anyway.
