Old 11-30-2017, 01:45 AM   #251
cwdodson88
Oh, ok, so this next one is all new ish. I would definitely send the injectors out for a quick clean and whatnot before getting too crazy. Or at least give them a quick diy cleanup.
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-30-2017, 09:23 AM   #252
esmth
dirty swede
esmth's Avatar
do this or something similar to check the pattern before you pay to get them cleaned. I made an adapter from a cracked fuel rail to test mine
https://www.youtube.com/watch?v=rUUgR94drxg
Old 12-01-2017, 10:22 PM   #253
Cwazywazy
Single jingle
Cwazywazy's Avatar
The engine bay got my pristine oil pan all dirty...
I don't know what I have
Cwazywazy is online now   Reply With Quote
Old 12-03-2017, 12:04 AM   #254
Cwazywazy
Single jingle
Cwazywazy's Avatar
Finished it up and put about 70 miles on it today. Works pretty well, loving the 15g. The idling down problem that I've been fighting since I got the car is completely gone. I'm happy, it runs well and all the engine internals are still internal.
I'll be buying a wideband before turning up the boost this time...
EDIT: It's possible that I accidentally set the old engine's base timing to -20 and not -10...
Old 12-04-2017, 04:07 PM   #255
Cwazywazy
Single jingle
Cwazywazy's Avatar
Is 15g boost creep a common issue? It holds WG pressure until it gets over about 3k then it slowly goes up to about 12psi..
Also the exhaust is amazingly loud. Need to look into that.
Old 12-04-2017, 04:49 PM   #256
57plymouth
57plymouth's Avatar
Never have I considered an engine to be on borrowed rime as much as this one. That car is cursed.
Sven, the 1991 245
Old 12-04-2017, 05:27 PM   #257
cosbySweater
cosbySweater's Avatar
its probably the marbles trying to escape
1990 Volvo 245, Efan conversion, tcam, Aw71 FOR SALE
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
2013 VW Passat TDI
Old 12-04-2017, 07:12 PM   #258
MrBrown
You like popsicles?
MrBrown's Avatar
If it’s holding pressure until 3k rpm and then creeping then you need to make sure the flapper is actually opening up. Put some pressure to the WG and see if the arm is moving out like it should.
GhettoFab build thrizzie
Old 12-04-2017, 07:41 PM   #259
Cwazywazy
Single jingle
Cwazywazy's Avatar
Ahhhh, it's fine.
Anyway, I touched my turbo to install coolant lines and now it's leaking oil really badly.
The feed line won't fit any other way with the coolant line in. Guess I gotta find an angled one.
Old 12-04-2017, 08:19 PM   #260
iHateVolvoPeople
Lord_Athlons daddy
Is it leaking near the washers? Are they forsure good copper crush washers?
In one instance, i used copper crush washers that had an inside diameter slightly too large. It leaked.
I have since ditched the rubbish banjo bolt setup (it sucks, they’re garbage metal if you got it cheap) and went to a m12x1.5>4an fitting. Wayyy better.
Here you go. Well with the switch in my opinion.
https://m.ebay.com/itm/AN-4-AN4-4AN-...-/160487676730
(I’m assuming your feed is already 4an by the way, i didn’t read though)
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 12-04-2017, 08:47 PM   #261
Cwazywazy
Single jingle
Cwazywazy's Avatar
I think it got hung up on the clampy dealy, already ordered one of what you linked.
Old 12-04-2017, 08:55 PM   #262
iHateVolvoPeople
Lord_Athlons daddy
I haven't noticed it in anything but 4th so far. I floored it at like 50 to hear the turbo noises and as the boost rose to 14 the engine suddenly revved higher.
Also don’t do this unless you wanna launch some more engines. 50 in 4th is what, maybe 2k rpm? Too low of an rpm with such high load. That’s how you ping/knock especially with na injectors, 14psi, and 9.8:1 compression.
In my opinion, i stay out of the boosts until above 2.5k. Higher the revs the less risk of knock.
Old 12-04-2017, 09:34 PM   #263
Cwazywazy
Single jingle
Cwazywazy's Avatar
Is it possible to use the WG actuator off a T3? I'm not really sure how much I trust the cruddy one on the 15g.
Old 12-04-2017, 09:35 PM   #264
thismachine13
Love this thread because it makes me feel so much better about my turbo install.
Old 12-04-2017, 09:51 PM   #265
iHateVolvoPeople
Lord_Athlons daddy
Me too
Old 12-04-2017, 09:53 PM   #266
iHateVolvoPeople
Lord_Athlons daddy
the whole 175whp thing is either bs (high reading dyno) or these things respond better than we thought.
Old 12-04-2017, 09:58 PM   #267
Cwazywazy
Single jingle
Cwazywazy's Avatar
Heh.
I have almost 200 miles on it so far and it has yet to explode. Hopefully, with some luck, this time I'll make the M47 explode and not the engine. I'm surprised how long that clunky noisy box has lasted already.
Old 12-04-2017, 10:04 PM   #268
iHateVolvoPeople
Lord_Athlons daddy
Heh.
The Chrysler ignition system is very aggressive. I would be surprised if it didnt knock above 5-7 psi even with 93 octane.
Old 12-04-2017, 10:11 PM   #269
Cwazywazy
Single jingle
Cwazywazy's Avatar
I don't think I ever ran more than like 9PSI before I swapped to EZK. But yeah, the knock sensor wasn't even plugged in.
Old 12-04-2017, 10:12 PM   #270
iHateVolvoPeople
Lord_Athlons daddy
Ohh you already switched to ezk, good. I was under the impression that lh2.2 240s did not have a knock sensor (only lh2.2 740s with ezk did), guess i was wrong..
Old 12-04-2017, 10:22 PM   #271
Cwazywazy
Single jingle
Cwazywazy's Avatar
I think it had a single spade connector sensor, dunno how effective that would've been. But yeah, I switched over to EZK a long time ago.
Old 12-05-2017, 10:23 AM   #272
iHateVolvoPeople
Lord_Athlons daddy
I wish someone would chime in. I really don’t think that single wire connector is a proper knock sensor, if a knock sensor at all. I know the 2 wire unit on all the lh2.2 7s and all lh2.4 cars is though.
Old 12-05-2017, 10:26 AM   #273
Cwazywazy
Single jingle
Cwazywazy's Avatar
I really don't know for sure, but the single wire sensor was replaced with a 2 wire when I got EZK.
Speaking of the knock sensor, how much does torque affect that thing? I torqued it properly on the rebuilt motor, but on the old one that lasted 700 miles it felt pretty tight getting it off.
Old 12-05-2017, 10:32 AM   #274
iHateVolvoPeople
Lord_Athlons daddy
The tighter it is the more sensitive it is to knock. You’ll have to find the specs but in your case i think having a sensitive sensor is a good thing. You want to avoid any knock at all.
Old 12-05-2017, 01:36 PM   #275
Stiggy Pop
Stiggy Pop's Avatar
didn't you put real injectors in it?
If not come back and get the orange tops I offered up with the turbo.
'79 242
943 pickup
