Old 12-20-2017, 05:01 AM   #1
jsdevel
jsdevel's Avatar
Default KL Racing 8v NA Header 2017
My quest to purchasing one of these originally started out as a group buy feeler for a KG Trimning Type 2 Header. Ronald (culberro) sold me on KL Racing. Total cost was $288.48 (after shipping). It's essentially the KG Trimning Type 2 Header with the exception that the collector is advertised as 2.5" OD (just a smudge above 63mm). I placed the order on their website on November 18th, and received it December 1st. 13 days isn't bad considering it shipped from Sweden to Phoenix, AZ over Thanksgiving weekend and made it's way through customs!
Packaging
Here's how it came. Didn't appear to have any dings. Right around 3' in length.
It also came with a sticker and a bottle opener. Free swag anyone?
Collector
Measuring the collector:
I like the flow inside the collector:
Size Comparison
Comparing it against the stock header assembly. The secondary and primary tubes are clearly longer:
Weight Comparison
I wanted to compare the weight with the stock header assembly.
Weight of the stock header assembly was roughly 27.7 ibs:
Weight of the KL Racing header was roughly 13.8 ibs. 14 ib reduction isn't bad!
Overall I'm very satisfied with the purchase.
Missing Bell Housing Bracket An Issue?
Has anyone had any issues without the bracket to stabilize the header to the bell housing?
Not needed with the 1 piece header?
jsdevel is offline   Reply With Quote
Old 12-20-2017, 06:19 AM   #2
JW240
All idiot, no savant
JW240's Avatar
Looks good. Nicer than the Folkrace header I installed on a 745.
I made a bracket to support the header. Just a piece of 6-8mm thick steel stock welded across both runners (secondaries) and a threaded hole in the plate. Mating to the original springy-wire style holder. Fits like stock.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 12-20-2017, 06:20 AM   #3
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Now all the stress hangs on the header bolts ;) not good but not that bad either... could crack, but mustnt
Old 12-20-2017, 11:35 AM   #4
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
It is less weight though
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 12-20-2017, 11:48 AM   #5
jsdevel
jsdevel's Avatar
Yea, I think I'm calling BS on the bracket with the new header. I mean, look at all the hooker headers out there for 350 Chevy's. You'd think if headers cracking was an issue then they'd have brackets on them as well, but they don't.
Old 12-21-2017, 06:06 PM   #6
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Yep. Replaced A LOT of header gaskets over the years. It isn't going to break the header, but the additional support would take the stress of the bolts to head- that is welcomed even if a lot lighter. Less movement at the gasket interface. YMMV
If one did not want to weld on the nice, new header, an exhaust clamp could be used with a fabricated bracket.
2013 Audi Q5
Sold- 2006 V70R
Old 12-21-2017, 08:54 PM   #7
Bready
board deviant
Bready's Avatar
Curious what mods you've made to the car.
Someone said “gavin” three times, and a troll appeared.
Keep your minds out of my pants.
Bready is right.
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Old 12-22-2017, 09:36 AM   #8
jsdevel
jsdevel's Avatar
Dang. Well, I think this alone is going to make me weld on a bracket. The exhaust pipe I picked up is fairly heavy. I could see the lack of a bracket causing unneeded pressure on the header bolts.
Old 12-20-2017, 06:33 AM   #9
TurboDenny
Why am I here?
Nice weight savings! Might have to pick one of these up for the daily.
I would probably weld on a tab to mount it to the bellhousing, just for peace of mind.
Instagram: @itstotesdenny
Old 12-20-2017, 12:01 PM   #10
photoman327
photoman327's Avatar
Do yourself a favor and have is ceramic coated . It will add years to the life. Also post thought and gains in performance and mileage. Real interested in one
photoman327 is online now   Reply With Quote
Old 12-22-2017, 09:55 AM   #11
jsdevel
jsdevel's Avatar
Yes. I'd really like to have it coated. A local coating company said the lead time was about 2-3 weeks as ceramic coating is a bit of a process.
In addition to improving velocity (due to a reduction in heat loss through the tubing), the engine compartment should stay cooler. In Phoenix AZ that would be huge.
Old 12-22-2017, 06:07 PM   #12
photoman327
Ther is a place in Jonesboro Ga that should be quicker. Do t remember the name but I have spoke with them several times but found some one local to do it cheap on a plus 90. Problem is he stopped doing it. You all got me wanting to order one and my money is funny right now. Going to trim some fat and will see!
Old 12-20-2017, 06:49 PM   #13
brian smith
Is the tubing close to 0.060" / 1.5mm thick?
the howdeedoo:
http://forums.turbobricks.com/showthread.php?t=288872
brian smith is online now   Reply With Quote
Old 12-22-2017, 09:54 AM   #14
jsdevel
jsdevel's Avatar
Measured with a micrometer, and it was around 1.5mm thick (which is close to 16 gauge).
Old 12-27-2017, 09:12 AM   #15
brian smith
Nice. Thanks for measuring and reporting back.
Old 12-21-2017, 10:29 AM   #16
jjona5
Do they offer it coated?
Old 12-22-2017, 09:53 AM   #17
jsdevel
jsdevel's Avatar
I don't believe so. A local coating company quoted me around $160 to have it ceramic coated.
Old 12-23-2017, 12:17 AM   #18
Tentshedtrev
Tentshedtrev's Avatar
very cool, I would like to change out my old stahl 4-1 header for one of these. Assuming any website navigation issues, it was a fairly straightforward process??
Life is too short to stay redblock..
1990 740 SE, Eaton m90 + Holset he351, twincharged b230F drift car
1983 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1983 244 (on blocks, currently parts storage)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth
1983 245 m46 b230f Stahl header Toyota 4age ITBs MS2extra
Tentshedtrev is offline   Reply With Quote
Old 12-23-2017, 11:39 AM   #19
jsdevel
jsdevel's Avatar
How come? Wouldn't the 4-1 design provide better low/mid-range torque?
Yes it was. The only issue I ran into was this: I registered on their site and added my address to my profile. I live in a condo with 4 digit unit numbers. When I was checking out my unit address appeared correctly (i.e. all four digits displayed); however, the email confirmation I received had the 3rd digit missing. I quickly emailed them to inform them, and they responded right away to let me know that they updated the shipping label. Didn't have any issues other than that.
Also, if you're like me and you check tracking information every 5 minutes, customs felt like an eternity! No updates we're posted for almost a week, then one day it was Arrived in Phoenix
Old 12-26-2017, 04:08 PM   #20
John V, outside agitator
Hmmmmmm no. the 4-2-1 thing is supposed to be all about broader powerband, isn't it? You see in invariably on rally cars and they have to operate from 3000-7000.>
ya know? a 90L just out of the woods and you snap throttle shut and brake like hell and initiate...ebgine revs dropped from 7000 down to say 1400 (idle) so you jump on the gas and it sure as fawk better PULL NOW!.. Your cornering--balance everthing depends on it pulling... 4-2-1
4 into 1 I have seen on roadrace cars....and non-poofter road race car with have a box that close enough the motor drops no more than 1000-1200 rpm on a shift so PEAK POWER is the overarching concern..and what do you see? 4 to 1..
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 12-26-2017, 03:34 PM   #21
300+hp on the shelf club
You can always paint it with some POR20 and put more coats of paint on later. The inside will get covered with carbon so it will get coated from your engine.
Old 12-26-2017, 11:12 PM   #22
940wagon
Might have to get one of these for my otherwise stock b230f... would look good in the engine bay and would give me a chance to re-do the rest of the leaky ass exhaust... I'm assuming for an otherwise stock motor there would be basically 0 performance gain with one of these?
940wagon is offline   Reply With Quote
Old 12-27-2017, 02:07 PM   #23
You should have a tangible seat of the pants performance gain. Long ago we put a IPD header on our 76 245 with a B20F in it and got a reasonable performance gain. That was with a 4 to one header.
Old 12-27-2017, 03:45 PM   #24
An enem V15 will work very well. While a V16 is also a great cam. The V15 is called the street performance torque cam for a reason.
Old 12-28-2017, 03:48 AM   #25
jsdevel
jsdevel's Avatar
Where can one of these be purchased?
I'm loving the info in this thread BTW. If I could travel back in time, I probably wouldn't've purchased the VX cam. It was one of the first purchases I made some 3 years ago when I used to believe IPD was the best place for Volvo performance parts
My engine is likely due for a rebuild, as it has well over 300,000 on it. My plan was to get the exhaust re-done as it's 30 years old, rusted, and leaky. I've had trouble dumping fuel from the false lean readings. The main reason for the header was I didn't want to invest any more $$ into this old system, and if I could fab up 2.5" cat back from the header, then I'd be in a good place to +t in a few years (unless I could get decent performance out of an NA DD).
